2.7L Access Cab thread
Discussion in '4 Cylinder' started by 2004TacomaSR5, Mar 29, 2012.
  1. Oct 22, 2015 at 2:53 PM
    #1001
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
  2. Oct 22, 2015 at 3:12 PM
    #1002
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I've never had this setup so I can't speak on it but I can tell you that the stock v6 and 4banger struts are different because of spring rate. You mention upgrading. Does that mean you are looking at new coils to go along with the 5100s? If that's the case and you have the same question about them being different between the two engines then that answer is no. You would choose the coil based on spring rate, not the overall diameter. Now if you upgraded to a 2.0 or 2.5 shock then yes those coils are different.
  3. Oct 22, 2015 at 3:22 PM
    #1003
    Kemosabe
    Louis
    Thanks for the reply! I do see that there is a lack of information in my question. To be specific, I would like to take off my front 1.5 spacer and put front 5100 in my stock coils and set them to keep the 1.5 lift.
    Because stock coils of the 2.7 are not the same as the 4.0, I was wondering if there is any issue that can occur? I am pretty new about all those suspension componnent and I try to figure wich option is the best for my DD use.
    Thanks again :p
  4. Oct 29, 2015 at 10:03 PM
    #1004
    CharlieThree
    CharlieThree Active Member
    Vance
    Las Vegas, NV
    2006 White 2.7L Prerunner SR5 5-Speed Manual
    LCE Headers LCE Short Shifter aFe Magnum FORCE Stage-2 Si Cold Air Intake aFe Catalytic Converter Magnaflow Exhaust Secondary Air-Filter Mod Resonator Delete Mod Lockable bed storage boxes Mod LED Interior Lights LED Brake and Reverse Lights ProComp (Ugh) 3" Lift Black FJ TRD Trail Team Wheels ABS Black Mesh Front Hood Grill Blacked out emblems Full window tint Tow Package Toolbox
    Here's my Taco!
    bagdadbilly and Kemosabe like this.
  5. Oct 30, 2015 at 4:29 AM
    #1005
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I dont see how there's anything that can go wrong. Once again, the spring rates only should be different to accommodate the difference in weight between the two front ends. Of coarse this is just a guess on my part but I would imagine that the same setting would achieve the same lift on both setups. Yes the springs are different because of weight but they also sit at the exact same ride height stock so it makes sense by you only adding shocks you will be lifting both applications the same
  6. Oct 30, 2015 at 12:44 PM
    #1006
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    Looks good man,
    Love the FJ wheels!
    Always been a favorite of mine.
  7. Oct 30, 2015 at 1:41 PM
    #1007
    Kemosabe
    Louis
    Thanks! I guess I was thinking too far haha what you said make a lot of sense and I agree with you.
    For now I decided to keep the front as it is right now because it is the rear shocks that need to be changed. I got today 2 adjustable Rancho RS9000XL. I had to return one because the knob to adjust it was already broken in the box... hope it will last on the next one.
  8. Oct 30, 2015 at 2:21 PM
    #1008
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Haha yeah def too far into it. And interesting choice of shock to buy. Why did you go with those?
  9. Oct 30, 2015 at 4:00 PM
    #1009
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    who's running 885's with there 2.7 acc? they say 884's but I'm leaning towards 885s
  10. Oct 30, 2015 at 7:07 PM
    #1010
    Kemosabe
    Louis
    I went with those because I can adjust it to be more stiff or smooth. Sometimes I do load my bed pretty much and I think it will help if I set it stiffer and when driving empty I'll keep it smooth. I do hope it will work like I think it will. I not I will be stuck with it for a while haha.
    I red on the forum some people having it and liking it, and some who don't. They are not very popular. Most prefer the billies 5100. I don't know why but I felt like the Rancho were the ones that would fit my needs the best.
  11. Oct 31, 2015 at 8:03 AM
    #1011
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I question their quality is all. How much do they cost? People on here go with 5100s because Bilstein makes one of the best quality products in the world. It also doesn't hurt that a pair is less then $200.
    The dampening adjusters do work as advertised. Fox even makes adjusters that individually adjusts rebound stroke and compression stroke and they make a noticeable difference when turned to full soft vs full stiff. Reason I ask about price of the rachos is a pair of any high end shock is $1000 - $1300 but with price comes quality.
  12. Oct 31, 2015 at 8:09 AM
    #1012
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    If you are running armor then the 885s will be great. With a stock body they will ride slightly stiff. They are a 590# spring. I swapped my coils from 600# to 650# when I put on front bumper, winch and skid plates and it carried the weight much better but def rides a lil stiffer
  13. Oct 31, 2015 at 8:23 AM
    #1013
    Kemosabe
    Louis
    I don't know if the price can be significant for you because I am in Canada and everything
    Is overpriced here... Paid the pair 300$ but + tax. A pair of Bilstein were a bit under that but not adjustable...
  14. Oct 31, 2015 at 8:24 AM
    #1014
    yesmar
    Ramsey
    Harrisburg, PA
    A couple cars
    cool, I'm putting on a heavy duty skid plate, and plan to do sliders and that hidden usoffroad winch plate with a winch in the future. i also feel the high rate spring will net me closer to 3" without spacers ect.
    still leaning toward the 885.
    thanks for the input!
  15. Oct 31, 2015 at 10:50 PM
    #1015
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Added a 1" body lift and front and rear bumpers
    ikarus likes this.
  16. Oct 31, 2015 at 10:58 PM
    #1016
    ikarus
    ikarus Well-Known Member
    Utah
    2020 TRD OR 6MT
    Got my full size spare mounted -
  17. Nov 1, 2015 at 4:09 AM
    #1017
    Greenbean
    Zack
    Western NC
    I want that tire gate bad.
    But I've almost got the wife convinced about a RTT, so one step at a time. Lol...
  18. Nov 1, 2015 at 7:10 PM
    #1018
    TYetti
    Mat
    Mine bought the rtt for me :)
  19. Nov 2, 2015 at 4:01 PM
    #1019
    Greenbean
    Zack
    Western NC
    Sweet man,
    How you liking the Tepui?
    Any words of wisdom that helped in your decision?
  20. Nov 3, 2015 at 12:39 AM
    #1020
    TYetti
    Mat
    I love my tepui. I'll never go back to a regular tent. Mainly what helped with my desicion was seeing them in action first hand a lot of local guys have tepui tents and gave them great reviews. A few guys have run other brands with similar success. I also preferred the designs of the tepui tent as well
