2.7L Access Cab thread
Discussion in '4 Cylinder' started by 2004TacomaSR5, Mar 29, 2012.
  1. May 1, 2019 at 7:38 PM
    #1901
    Garfunkel
    Garfunkel Well-Known Member
    Awesome thank you for the help, Go tech
    Casper66[QUOTED] likes this.
  2. May 1, 2019 at 7:43 PM
    #1902
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    :thumbsup:
  3. May 1, 2019 at 10:14 PM
    #1903
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    The 6112s I have come with 600 0r 650 lb coils from Bilstein already installed. The 6112s are only front shocks not rears and are simply a slightly beefier shock which is better for my style of offroading.
    The 5160s are just a better performing version of the 5100 but not by much as far as I have noticed. For the camper shell I would recommend getting a new set of leaf springs for a solid lift
    If you have no shell and are just into easy-mild off roading I'd say get 5100s along with a three leaf AAL with 885 or 886 OME coils
  4. May 2, 2019 at 7:58 PM
    #1904
    Garfunkel
    you're the man thank you for the help
    edit: actually 885 coils on the 2.7L? I was considering the 884s I believe
  5. May 2, 2019 at 8:00 PM
    #1905
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    No problem man, I understand how confusing it can be looking for lifts
    Post a pic when you install them!
  6. May 2, 2019 at 8:01 PM
    #1906
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    I think those are fine too, I forgot which coils were for a truck with no extra weight on the front
  7. May 3, 2019 at 5:29 PM
    #1907
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
  8. May 4, 2019 at 6:53 AM
    #1908
    amRRussel
    amRRussel A guy with a truck
    Andrew
    2011 Access 4banger 4x4
    Driver Mod
  9. May 8, 2019 at 8:38 PM
    #1909
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    2009 5spd PreRunner w/ 4.88s & 295/70/17s
  10. May 20, 2019 at 9:17 AM
    #1910
    TacomaMike25
    TacomaMike25 Well-Known Member
    2012 Tacoma SR5 4cyl 4x4
    2 inch lift, Level 8 Mk6 wheels 16x8 with a 275/85r16, Aftermarket fogs with yellow bulbs, AVS bug deflector, Weather Rain guards, secondary air filter delete. PIAA halogen bulbs
    My 2012 2.7l Access Cab on 5100 set at 1.85 front with a 1.5 aal rear on stock shocks. Tire set up is 265/75r16 Cooper Discoverer with Level 8 Wheels 16x8...
  11. Jun 17, 2019 at 10:02 AM
    #1911
    Nate31
    Nate31 Member
    2.7 Tacoma
    Here’s my 2010 2.7l with a 2.25 inch leveling kit and LT235/85/16 tires.F6531B96-2BDE-445A-AB90-547475AB2059.jpg E53D0844-60EA-4D51-9858-279B4738EF5C.jpg
  12. Jun 25, 2019 at 5:10 PM
    #1912
    Slappymane
    Slappymane Member
    Kaveh
    SF CA
    2017 Manual 4banger
    stock gang
    Here is my 2017 SR MT after a car wash with some good lighting :taco:
  13. Apr 29, 2020 at 9:02 AM
    #1913
    BassAckwards
  14. May 25, 2020 at 8:39 PM
    #1914
    JL911
    JL911 Psshh
    PA
    5 spd 4 bngr
    Added a cap last Fall. The long bed makes the perfect sleeper.
    TPMO, Snaeper, BassAckwards and 2 others like this.
  15. May 28, 2020 at 4:39 PM
    #1915
    NEoffgrid'r
    NEoffgrid'r Well-Known Member
    Todd
    New England
    2023 TRD Sport 4dr SB
    None Yet
  16. Jun 6, 2020 at 2:56 PM
    #1916
    SoCalTbird
    SoCalTbird Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    Just picked this up
    so i have have heard the short shift mod is practically necessary?
  17. Jun 7, 2020 at 12:12 PM
    #1917
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
  18. Jun 16, 2020 at 11:08 PM
    #1918
    Fever_Dog
    Fever_Dog Member
    2016 SR AC 2.7 4wd
    SLAYER shift knob
  19. Jun 25, 2020 at 8:02 PM
    #1919
    lennyw3
    lennyw3 Member
    Pennsburg, Montgomery County
    2016 SR5 4x4
    Leggooo 2.7L AC. My 2016 SR5
    SilverBulletII likes this.
  20. Jun 25, 2020 at 8:15 PM
    #1920
    lennyw3
    lennyw3 Member
    2016 SR5 4x4
    Like I posted above, I got the 2016 SR5 2.7L 4x4. I'm looking into grabbing the eibach pro lift kit with a leaf pack for the rear and 3" of lift when I pick up some armor. What tires do you recommend for 17s? Is this all too much for the 4banger. I plan on it mostly being show, some light trails, occasional towing. I want the lift kit for tire clearance and to improve road ride quality. Suggestions?
