2.7L Access Cab thread
Discussion in '4 Cylinder' started by 2004TacomaSR5, Mar 29, 2012.
  1. Feb 22, 2021 at 3:43 PM
    #1961
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    Did you do the work yourself?
  2. Feb 22, 2021 at 7:59 PM
    #1962
    Bizquick
    Bizquick Well-Known Member
    Ethan
    Birmingham
    5 lug 2.7 AC 5spd
    Yes, this truck happens to be quite easy to work on with plenty of room under the hood.
    BassAckwards and SJBrown like this.
  3. Feb 23, 2021 at 10:27 AM
    #1963
    D2.
    Dan
    Nova Scotia, Canada
    excellent,
    how was getting the header off? did any of the bolts snap off in the head? That would be my biggest fear. I'm in need of some exhaust work and have been putting it off due to the fear of snapping bolts in the head
  4. Feb 23, 2021 at 7:35 PM
    #1964
    Bizquick
    Ethan
    Birmingham
    5 lug 2.7 AC 5spd
    Nope, no issue with the studs, I did find that the nuts are made of a softer metal, so when wrenching on them to remove the manifold be careful. I would spray some wd40 on each nut to allow it to come off easier.
    po35042 and D2.[QUOTED] like this.
  5. Feb 24, 2021 at 4:08 PM
    #1965
    Urkle86
    Urkle86 Well-Known Member
    2008 Tacoma 2.7 Base / 2010 4Runner Limited 4x4
    18D88CCC-9EB2-4276-9829-31118C250D5F.jpg She’s older but she still looks beautiful to me❤️
  6. Feb 24, 2021 at 9:44 PM
    #1966
    Bizquick
    Ethan
    Birmingham
    5 lug 2.7 AC 5spd
    I’m a fan of the yellow fogs
    Urkle86 likes this.
  7. Feb 24, 2021 at 9:48 PM
    #1967
    VanGreat89
    VanGreat89 Member
    Squamish BC
    2.7 4 banger 4x4
    285/75/16 Pro Comp Sport A/T Bilsteins 5100s PIAA lights.
  8. Mar 5, 2021 at 1:27 AM
    #1968
    Brenn1017
    Brenn1017 Well-Known Member
    2nd gen access cab
  9. Mar 15, 2021 at 5:38 PM
    #1969
    JBerg
    JBerg Well-Known Member
    Josh
    4x2 2016 SR5
    My baby
  10. Mar 16, 2021 at 7:29 AM
    #1970
    TacoTime10
    TacoTime10 Well-Known Member
    New Hampshire
    2010 ACLB 4x4 SR5 2.7L 5MT
    2021 TRD OR wheels and tires, bed stiffeners, fog lights
    Nice setup. How does the 2.7L do with the bigger tires? I’m thinking about upgrading to 265’s and wondering if it will affect performance around town. I already have to floor it to get on the highway with the stock 245’s!
  11. Mar 16, 2021 at 8:01 AM
    #1971
    JBerg
    Josh
    4x2 2016 SR5
    PERSONALLY the 255/80/17 with the steelies DRAG ya down. They’re heavy. If you get 265/75/16 I would say stay away from the LT size unless you’re loading the truck. But any extra poundage will always hurt a little bit.
  12. Mar 16, 2021 at 10:44 AM
    #1972
    TacoTime10
    New Hampshire
    Thanks man, much appreciated.
  13. Mar 16, 2021 at 11:48 AM
    #1973
    JBerg
    Josh
    4x2 2016 SR5
    I’ll let ya know if the LCE header makes a difference
    Tacoma559 and TacoTime10[QUOTED] like this.
  14. Mar 19, 2021 at 4:54 PM
    #1974
    TacoSRSX
    TacoSRSX Well-Known Member
    Martin
    Ventura County / San Fernando Valley - CA
    2021 MGM SR 2.7 2WD SX
    Ionic Pro 4" tube steps Desert Does-it Seat Jackers ECT PWR always on Kicker Tweeters replacement Tyger roll-up vinyl cover Bed mat
    2.7 SR gang
  15. Mar 19, 2021 at 6:14 PM
    #1975
    JBerg
    Josh
    4x2 2016 SR5
    Where’s this??? Looks familiar
  16. Mar 19, 2021 at 6:26 PM
    #1976
    TacoSRSX
    Martin
    Vista point near the San Simeon Elephant Seal Rookery
  17. Mar 19, 2021 at 6:35 PM
    #1977
    JBerg
    Josh
    4x2 2016 SR5
    Well I was completely off but solid photo my guy
    TacoSRSX[QUOTED] likes this.
  18. Apr 15, 2021 at 9:47 AM
    #1978
    Cmixgo
    Cmixgo Well-Known Member
    2022 SR 4x4 Double Cab
    Age old question that I can’t find a straight answer for: 5100s set at the top on factory coils or 5100s set at 0 on OME 884 coils? Looking to lift my 2011 4cyl access cab 4wd 2” without replacing UCAs. Anyone here have experience with the 884s on a second gen access cab?
    Ive had this thing for 3 years and ready to get the suspension upgraded. Thanks!
  19. Apr 15, 2021 at 10:08 AM
    #1979
    SoCalTbird
    SoCalTbird Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    FWIW, i bought mine used w/ 5100 w/ what i believe are stock coils set at top notch. It apparently never had an alignment after, cuz it drove horribly. I have since got an alignment and drives 100% better, but i still think UCA's would help. I have purchased a "cheap" option(freedom offroad), they have mixed reviews on here from what i have found. I have not installed them as I am also considering the 884's for a better/smoother ride. Hoping someone else chimes in w/ 884's. Pic for reference
  20. Apr 15, 2021 at 10:37 AM
    #1980
    Cmixgo
    Clean looking truck! That’s good to know on the 5100s. Hopefully someone can chime in on the 884/4 cylinder combo. I just got a response from ARB below, I emailed asking what the lift for a 4cyl Access cab on 884s would be. Would like to confirm their claims by someone running the 884s before spending the money...
    “For a 4cyl with no added weight, the 2884 is the way to go. This will get you close to 2" of lift...You will be able to get close to the factory specifications without UCA's. With adjustable or our UCA's, you can get to the exact specification (0 degrees).”
    SoCalTbird[QUOTED] likes this.
