2.7L auto weak with error code p0402 "EGR EXCESSIVE FLOW"
Discussion in '1st Gen. Tacomas (1995-2004)' started by outlaw8950, Mar 18, 2010.
  1. Oct 7, 2014 at 7:51 AM
    mccrickard
    mccrickard New Member
    Virginia
    99 PreRunner 2.7 2wd
    I also have a 99 Prerunner 2.7 with the same darn code. I have replaced the egr, tested the modulator, replaced ALL vacuum lines I went behind my self to double check that they were all in the right spot and on good as well. Now there has not been any power loss at all or smoke I have had this truck since 1999 and have kept it up well. No mods all factory. After I replaced the EGR and hoses I reset the light drove from Roanoke VA to Winston-Salem NC and back around 250 miles before it came back on with the same damn code. Like I said it still runs great no smoke or power loss.:confused: Does anyone know the best way to test the vsv, pwm and the obd? my next step is to test those along with the temp sensor.
  2. Jan 10, 2016 at 6:15 PM
    tonyly
    tonyly Well-Known Member
    Tony
    Los Angeles
    01 Tacoma Prerunner Ext Cab
    Steve - can you tell me exactly where the vacuum switching valve is. I also have a 3rz and I have replaced the egr valve and the temp sensor and the P0402 code still comes on. I do not have any loss of power. I appreciate it if you can take some pictures of the location. Thanks!
  3. Jan 10, 2016 at 7:16 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    this is what to look for. but that is for the OPs 99 2.7. not sure if they have the exact same one for your truck.
    check rock auto to see what yours should look like.
  4. Dec 3, 2020 at 10:21 PM
    The_Sahara_Man_FJ80
    The_Sahara_Man_FJ80 Never Settled
    Ish
    NorCal; Santa Cruz <—> SF <—> Lake Tahoe
    2004 2.7l Tacoma 4WD
    -- OME Dakar Leafs -- ToyTec adjustable shackles —allpro armor— -- Bilstein 5100s all around -- Toytec Coils -- Ebay UCAs w Allpro Uniballs --Toyota bug/wind deflector -- Weld Racing Scorpios -- SnugTop Hi-Liner — BedRug Bedliner --Spyder LED Tails -- Black Horse taillight guards --33"Cooper STT Pros -- 800w Quad row spot/flood LED bar -- Uniden Bearcat CB -- Firestik 5ft antenna -- K&N CAI
    I changed my VCV/VSV however you may refer to it, code still comes back on. Factory EGR valve functions after simple vacuum test. Would replacing my exhaust system which is rusting out help? It can't possibly hurt... This seems to be a common problem now for our Tacomas. Mine has 160k on it now.
