2.7L Block heater
Discussion in '4 Cylinder' started by 4X4SUPERWHITE, Nov 5, 2012.
  1. Nov 5, 2012 at 5:39 AM
    4X4SUPERWHITE
    4X4SUPERWHITE [OP] Active Member
    MA
    Stock,V6 SR5 DC
    stock
    Looking for info & photos, on installing a oem block heater on a 2011 with 2.7L?
  2. Nov 5, 2012 at 7:05 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    I am also very interested!
  3. Nov 5, 2012 at 7:53 PM
    n0rth
    n0rth Well-Known Member
    J.W.
    Idaho
    09 Tacoma 4X4 SR5
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    I know the block heater on my truck is a freeze plug style, not sure if the newer models are diferent. Here is the part # Tacoma 2.7cu in I4 2TR-FE Toyota (#00213-02141) frost plug heater bought from Toyota Canada it was installed by the dealer in AK when I bought the truck.
    Install thread (not mine) write up only
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/18890-successful-install-block-heater.html
    TRDparts4u lsiting
    http://www.trdparts4u.com/scripts/prodView.asp?idproduct=-5128
    PDF description Pg. 8
    http://trdparts4u.com/ProdPDF/TOYOTA_080411.pdf
  4. Nov 6, 2012 at 8:24 AM
    4X4SUPERWHITE
    MA
    Stock,V6 SR5 DC
    stock
    Thanks for the great info,Here is another question. What about the element clip direction o'clock mean ? What is that? any photos?
  5. Dec 10, 2012 at 7:42 PM
    skiomax
    skiomax Pro skier
    Ottawa, Ontario
    2013 Tacoma TDR Sport DC
    Extang cover Thule roof rack pop & Lock Short antena Weathertech floor liner TRD skid plate Leather Seat package
    anyone would have a tread for the installation on a 2013 V6 engine?
  6. Dec 10, 2012 at 8:00 PM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    if its the 1GR-FE in the 2013 still, then it should still be the same skiomax
  7. Jan 11, 2013 at 1:20 PM
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Hey guys, just saw this...
    Honestly I wouldn't go through the hassle of installing a freeze plug-style block heater in our engines. Just went out to find a coolant leak for the 2nd time... I'm going to pull it out and replace it with a freeze plug.
    I feel like the design of these plugs is inferior, and it's not worth the risk of losing your engine.
    Money better spent on a good battery and battery/oil pan blanket.
    Just my .02
  8. Sep 15, 2014 at 1:25 PM
    pat2330b
    pat2330b Member
    Montreal, Canada
    Base 2,7 extra cab
    very nice info thx!
