2.7l blown head gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mikescollins, Jan 6, 2018.
  1. Jan 6, 2018 at 9:28 AM
    Mikescollins
    Mikescollins [OP] Member
    Michael
    Marshall, TX
    95 Tacoma 4x4
    Hey guys I'm trying to decide if I should just replace the head gasket or go ahead and do a rebuild motor is strong, my mom has been driving it and didn't let it warm up enough with the crazy low temperature we had the other day and I'm 90% it is just the gasket but won't know for sure until I hear it down. What would you do I'm even open to finding a cheap used motor and swapping while I rebuild mine
  2. Jan 6, 2018 at 12:03 PM
    Whitebutler
    Whitebutler No need to compensate!
    From up in dem woods
    06 black sand Perl access cab. 99 T4R
    33s and stryker440 10 meter conversion to 11 radio
    I just did a 2.7 in wife's runner. I did a new head and gaskets and it's almost like a new motor. Way more power and runs great. The head cracked on ours right around the#3 and#2 spark plugs holes. I would pressure test the radiator before anything as well.
  3. Jan 6, 2018 at 12:23 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    same had 4 cracks in mine, happens from having the valves lashed incorrectly.
  4. Jan 6, 2018 at 1:06 PM
    Whitebutler
    That's what I thought it was from. I noticed the head that was on the runner was replaced before. I think someone just threw it on instead of setting the valves correctly first. They came all assembled in the new head. However I found out I had to first get it set in place then turn the cam and check lash. Had to pull three valves and grind the end so they fit right. All the others were perfect.
    Speedytech7[QUOTED] likes this.
  5. Jan 6, 2018 at 7:21 PM
    Mikescollins
    Michael
    Marshall, TX
    95 Tacoma 4x4
    So most likely the head is cracked as well, that leans me even more to a swap and complete rebuild of the original
  6. Jan 7, 2018 at 1:18 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Not likely caused by running cold. If so, my head gasket would have blown years ago. Seems valve lash is the most common cause of head problem on the 2.7l, which reminds me that I need to check mine.
    Dalandser likes this.
  7. Jan 7, 2018 at 2:36 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If your block is good and you don't have an absurd amount of miles, I'd consider keeping the engine in the truck and replacing the head if it's in fact cracked - you're looking at a lot more work to swap in an engine. Plus then you start thinking about spending more money on new stuff to put in there while you have the whole thing apart.
    :anonymous:
  8. Jan 8, 2018 at 7:25 PM
    Mikescollins
    Michael
    Marshall, TX
    95 Tacoma 4x4
    333000 miles, but it still ran great I think I'm gonna tear it down to the head gasket then decide
