2.7l Cam Dots & TDC??
Discussion in '4 Cylinder' started by todntes, Jul 20, 2010.
  1. Jul 20, 2010 at 4:43 PM
    todntes
    todntes [OP] Member
    Todd
    Seattle
    00 Tacoma SR5
    Re-installing the head on my 2000 Tacoma and don't see the marks. The "book" says to line up the marks on the cams. The intake cam is clear with only one option for dots but the exaust cam has 3 different dots to choose from. Does anyone know which one to use?
    The book shows a v mark on the inside of the pulley to line up top dead center (tdc) but I only see a mark on the outside of the pulley. Is this the one?
    One last question from the rookie...
    Is this a interference engine? I had it together but think it may have been incorrect. Turned over but didnt start. Ruined?
    Thanks for any info!
  2. Jul 20, 2010 at 6:20 PM
    todntes
    todntes [OP] Member
    Todd
    Seattle
    00 Tacoma SR5
    Found the v mark on the pulley, reset the cams and it started right up. Just wondering now if I did any damage when I was turning it over before?
  3. Jul 20, 2010 at 6:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You would know pretty quick if damage was done.
  4. Jul 21, 2010 at 4:34 PM
    todntes
    todntes [OP] Member
    Todd
    Seattle
    00 Tacoma SR5
    Gates.com says it is non interference.
    When I first fired it up yesterday it sounded great and throttled up no problem but I was missing a couple bolts so I didnt drive it. Today I installed the manifold stud and a valve cover bolt then tried to start it. It started very hard, idles low and the rpm's surge up and down when I idle it up. Any ideas? Back to the 3 dots on the cam? Thanks
  5. Jul 21, 2010 at 4:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check the timing, and vacuum lines. You may have bumped one loose/off.
  6. Jul 27, 2010 at 5:32 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    If I remember the dot lines up with the square stock key on the cam and gear then there is a single dot on the exhaust and the double dot on the intake and they should all line up
