2.7L Coolant bubbling and overflowing reservoir
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bbinSF, Jun 19, 2025.
  1. Jun 19, 2025 at 11:54 AM
    bbinSF
    bbinSF [OP] Well-Known Member
    Hi guys,
    Recently was at 11,000 ft, driving extensive hill climbs in 4LO, not loaded up. Proud of the 4 banger.
    After stopping and cutting the engine, I heard bubbling from under the hood.
    Here's a video:
    https://photos.app.goo.gl/DCJXAgPnPNNQ1tWJA
    Note engine is off!
    I swapped the radiator, cap, and coolant last year. It seems like gasses are flowing from the cooling system back into the reservoir. On another climb the amount of coolant flowing out overflowed the reservoir and spilled on the ground.
    Not having any overtemp situations, engine temp needle is planted firmly in the middle of the range.
    Hm, now thinking its a head gasket. Why else would there be gases in the coolant system.
  2. Jun 20, 2025 at 10:15 PM
    bbinSF
    Anyone?
  3. Jun 20, 2025 at 10:18 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Did you allow the engine to run for a bit to cool off before your turned it off?
  4. Jun 21, 2025 at 1:47 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Coolant boils at a far lower temp at high altitudes plus the engine is working considerably harder. If you were not having issues at the altitudes you normally run it at it only pops up when you are at high altitudes, I wouldn't worry in the least, just make sure that the overflow has enough coolant in it to draw back into the radiator and check it when you are back down. Stop and eat somewhere and check it when you come out and add if needed.
  5. Jun 21, 2025 at 6:03 AM
    bbinSF
    I thought of this but of the 3 times it happened I did not let it run.
  6. Jun 21, 2025 at 6:04 AM
    bbinSF
    This is a relief. I should have run my obd2 sensor to get and accurate coolant temperature.
  7. Jun 21, 2025 at 6:13 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Thats probably why it's boiling, after working an engine very hard you should let it run for a few minutes so it can cool off, turning it off immediately stops coolant flow and can allow it to superheat & boil the coolant in the block if the engine has been ran hard and not allowed to cool off first.
  8. Jun 21, 2025 at 6:39 AM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Change /check the oil if its milky if your really worried about said head gasket ...
  9. Jun 21, 2025 at 7:01 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    I drive in the mountains a lot. When heading up at high altitude, gear down and slow down. Turn the heater and/or defroster on with the fan on full. This can drop the engine temp by 5°F or more.
  10. Jun 21, 2025 at 7:19 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Can have a blown head gasket without oil in your coolant…..or even with passing the combustion gas detector
    bbinSF[OP] likes this.
  11. Jun 21, 2025 at 1:03 PM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DCSB SR5 V6 AT TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Why turn the defroster on? That only activates the AC compressor and puts more load on the engine.
  12. Jun 23, 2025 at 9:29 PM
    bbinSF
    BTW, My temperature gauge needle remained in the middle of the dial and never registered "hot" or "overheating". It heats up normally but never went super hot. Based on its location, drivers side, it could be that the coolant temp is registered on the into the engine side, and missed the hot, boiling coolant on the exit.
    But if my coolant temp sensor didn't catch this boiling then will and OBDII sensor that reads that sensor for coolant temp have any hope of notifying me of an overtemp situation?
  13. Jun 23, 2025 at 9:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    There's only one sensor, it reports to the ECM and the ECM sends the temp signal to the gauge.
