2.7l Cylinder 3 misfire
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lukegoes14, Jun 1, 2023.
  1. Jun 1, 2023 at 10:16 PM
    Lukegoes14
    Lukegoes14 [OP] Active Member
    Luke
    2001 2.7l single cab
    My truck recently started throwing a code for cyl. 3 misfire (P 0303).
    Initially I started with the usual suspects. I installed new spark plugs, new coil (distributorless) on cyl. 3, and took the fuel injectors in to get cleaned and tested.
    After this I was still getting the misfire. I ran a compression test and got the following results:
    Cyl. #1 - 170 psi
    #2 - 180 psi
    #3 - 195 psi
    #4 - 185 psi
    These values seemed normal to me so I ran a fuel pressure test that read at ~46psi.
    I then performed a noid test on the #3 injector which strobed indicating that it was firing.
    To check for spark I took a spare spark plug and grounded it to the engine while connected to the coil and it looked like it was firing.
    Last test was at the ECM injector terminals which all read ~8.3V for all 4 injectors. Toyota shop manual says these should be between 9-12V? Is this part of the issue?
    I also replaced the MAF sensor to see if that would do the trick, no dice. Still throwing the code.
    I don’t really know where to go from here, I believe the problem is some kind of electrical issue but do not know how to narrow it down, can anyone point me to some kind of testing that can narrow it down for me? I am not good with automotive electric so layman terms would help a lot.
    Thanks guys
  2. Jun 1, 2023 at 10:50 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Boroscope the cylinders to see how they look? It’s a relatively cheap tool for what it allows you to see. Carbon build up can also cause increased compression depending on where it is. It’s easier to diagnose from knowledge than guess why they’re different. You might have already fixed the cause but not the consequences.
  3. Jun 2, 2023 at 3:12 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    when was the last time you changed your plug wires. I had a misfire and the culprit was a bad spark plug wire.
  4. Jun 2, 2023 at 5:35 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How many miles on it? Have valve clearances been checked ?
  5. Jun 2, 2023 at 7:04 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    M e too. Cylinder misfire was new plug wires. Our trucks kill wires
  6. Jun 2, 2023 at 7:10 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check for control at Pin 1 (Red) of injector number 3 with a test light or plug a noid light into the injector 3 connector.
    If you use a test light you need to connect the ground lead of it to battery positive.
    With the engine running the light should flash.
  7. Jun 2, 2023 at 7:22 PM
    Lukegoes14
    Luke
  8. Jun 2, 2023 at 7:25 PM
    Lukegoes14
    Luke
    Didn’t even know that was a tool, I like it. I’m guessing I just feed the scope through the spark plug insert?
  9. Jun 2, 2023 at 7:31 PM
    Lukegoes14
    Luke
    I tested #3 injector with a noid light and the electric pulse seemed to be firing. Am I missing another type of test, I went through the shop manual diagnostic flow chart and am still stumped.
  10. Jun 2, 2023 at 7:33 PM
    Lukegoes14
    Luke
    My 3rz has distributorless plugs so I don’t have plug wires.
  11. Jun 2, 2023 at 7:35 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    My 3.4l has no distributer either, but it still has spark plug wires running from the Coils to the other side of the engine.
  12. Jun 2, 2023 at 7:36 PM
    Lukegoes14
    Luke
    285,000+ miles, I just wanted to rule out all other possibilities before I start pulling the head cover
  13. Jun 2, 2023 at 7:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Seems like you have ruled out all the "easy" stuff, without getting into technical testing beyond DIY the only other thing I can think of is make sure the exhaust valve is opening.
  14. Jun 2, 2023 at 7:41 PM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    I think it's time for an engine analyzer. A look at the spark pulse curve will tell you volumes, and only take a few minutes.
    Let us know what you find.
  15. Jun 2, 2023 at 7:41 PM
    Lukegoes14
    Luke
    Are they in a big loom? I looks like my spark plug wires feed into a loom that also has the fuel injector wires as well. Loom feeds to firewall on passenger side.
  16. Jun 2, 2023 at 7:42 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Perform a valve adjustment. Won't hurt to try.
  17. Jun 2, 2023 at 7:48 PM
    Lukegoes14
    Luke
    Okay I think you guys have helped point me in the right direction. I will check valve clearances tomorrow and see if they need adjustment and report back. I think the boroscope was a good idea also so I’ll take a peek into the cylinders while I have everything taken apart.
  18. Jun 2, 2023 at 9:39 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    You can look in the spark plug holes or look through the throttle body to see the intake valve tops.
  19. Jun 2, 2023 at 10:09 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I have a stupid question....since 2 and 3 fire simultaneously
    cant you just swap those two coils including its wire with it and see if that follows to no.2....
    rule out a global electrical problem...
    and then go backwards from there....see if its the coil or the harness plug...
    Also made me think for these coil over plugs.....since both piggy back on the same fire signal from the ecm......that if one of them is shorted, bad, or going out....it may affect the other....
    The coil over plug is not a superior design....its a cheaper way for them to make em......so I'd keep a couple spares around if mine was a 2001 or later....
    One of the first things I did when I got my truck was I ran a dedicated ground strap straight from the neg post to the engine block/head....
    instead of depending on the round-a-bout hooky way they did it thru the body panels...
  20. Jun 3, 2023 at 1:31 PM
    Glamisman
    Glamisman Well-Known Member
    If swapping plugs and injectors does not transfer the problem to the test cylinder then it is mechanical in nature. Next step is do a leak down test. Requires a special tool and an air compressor. The 4 cylinder motors have a tendency to burn a valve and/or develop cracks in the head at that mileage.
