2.7l dies when under load. limp mode?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by niktruck, Nov 15, 2021.
  1. Nov 15, 2021 at 9:07 PM
    niktruck
    niktruck [OP] Member
    09 timberland mica ac 4x4 2.7 manual
    Hey there I've tested my truck a bunch and I think I've found the answer but need some more help.
    I have an 09 2.7l tacoma. It had an exhaust leak that burnt the o2 sensor, which I then fixed. After that the truck just ran weird until it seems like it put itself in limp mode, wouldn't rev past 3k and would be bogging hard in 4lo trying to crawl up slight hills in the city.
    I did a compression test which yielded:
    cyl1 - 117psi
    cyl2 - 120psi
    cyl3 - 160psi
    cyl4 - 165psi
    After that I did a leakdown test, and had air from cylinder 1 leaking into cylinder 2. Enough that it couldnt hold compression.
    Cylinder 3 and 4 were leaking into each other as well but not as drastically as cylinder 1 to 2.
    I was thinking cracked or warped block/head but it was consistent no matter the piston position so I'm thinking it's a head gasket that went.
    If anyone has anything to add it would be much appreciated!
  2. Nov 16, 2021 at 1:28 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did the engine over heat at any time prior to all of this? The 4 bangers are not known to blow head gaskets very often without cause.
    Why do you think a cracked or warped block or head?
    Sounds like a rebuild or a used engine is in your future.
    TnShooter likes this.
  3. Nov 16, 2021 at 6:56 AM
    niktruck
    No white smoke, coolant was fine (no oil in it), and didn't lose coolant at all. Engine never overheated at all.
    The cracked/warped block idea was just that. An idea, due to no telltale head gasket signs.
    Honestly the head gasket idea is also just a guess, slightly more educated than the other guesses but still I don't have any proof until I take that head off.
    And this motor got swapped back in March so I'm really not feeling like putting another in there. This is kind of just leaving a sour taste in my mouth for this 4cylinder motor.
  4. Nov 16, 2021 at 7:01 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I think I'd first do an exhaust backpressure check to make sure the catyletic converter isn't plugged, that could definitely cause low power.
    Jimmyh and brandon78lusch like this.
  5. Nov 16, 2021 at 7:45 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Compression test lets you know something id DEF up. Redo it and see if you get the same results. If you do, regardless of WHAT it is, you are pulling the head to either fix a head gasket, valves, and to potentially inspect the pistons/rings/bores.
    Jimmyh likes this.
  6. Nov 16, 2021 at 10:47 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    117 & 120 psi seems really low.
    Did you hear air coming from the exhaust or intake during the test?
  7. Nov 16, 2021 at 11:46 AM
    gtrotter07
    gtrotter07 Well-Known Member
    2007 Tacoma reg cab 4x4 on 37's; 2021 TRD Offroad, 6 speed
    37's,lockers, bumpers, bobbed etc.
    Did you try a wet compression test?
  8. Nov 16, 2021 at 4:46 PM
    niktruck
    Wet compression on cyl1 & cyl2 yielded 123psi in each.
  9. Nov 16, 2021 at 4:47 PM
    niktruck
    Nothing from the exhaust or intake that we could hear or feel. When plugging cyl2 with a spark plug it could be heard down in the motor near the crankshaft.
  10. Nov 16, 2021 at 4:53 PM
    TnShooter
    Deogee
    STOCK
    Hard to say, but that sounds kind like rings to me.
    Jimmyh likes this.
  11. Nov 17, 2021 at 5:04 PM
    niktruck
    Not too confident on motors, but how do bad rings make cylinders leak into each other?
  12. Nov 17, 2021 at 6:08 PM
    TnShooter
    Deogee
    STOCK
    If you hear it down in the engine, the sounds like it’s leaking passed the rings into the crank case.
    Most head gasket failures usually fail between coolant jackets and cylinder.
    Jimmyh likes this.
  13. Nov 17, 2021 at 7:41 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    What makes you think it is leaking between the cylinders?
  14. Nov 18, 2021 at 5:38 AM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    It’s probably blown a head gasket.
  15. Nov 18, 2021 at 6:44 AM
    niktruck
    I can feel air leaving cyl2 when doing a leakdown test on cyl1.
  16. Nov 18, 2021 at 6:50 AM
    niktruck
    Ohh, so then with the fill cap closed leaving through cyl2 is the least resistance for the air. Ok, I'm going to take the head apart and look at those.
  17. Nov 18, 2021 at 6:53 AM
    TnShooter
    Deogee
    STOCK
    With the low PSI you have, the head needs to come off anyways. It’s still possible it the head gasket. But once you get the head off, you’ll have a good idea.
    Jimmyh likes this.
