2.7l Engine Failure???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vermontrer74, Nov 2, 2021.
  1. Nov 4, 2021 at 4:43 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    I would drill a hole, tap threads and then plug it.
    willie2, tacotoe, Williston and 2 others like this.
  2. Nov 4, 2021 at 6:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I would like to see a broader picture of the engine, as well as the frame.
  3. Nov 4, 2021 at 8:37 PM
    goforbroke123
    goforbroke123 Well-Known Member
    Montgomery County, PA
    2012 Tacoma TxPro DBcab 6speed
    Mannnnn 10 years in the northeast, let alone Vermont is going to destroy most cars/trucks unless you do some serious preventative maintenance yearly.
    When I was shopping for a Tacoma I looked up north(I was desperately looking for a manual) in VT, NH, and Etc…all of the Tacoma’s up there were priced 4K-5K lower compared to other areas. Well at least the honest people were pricing them accordingly.
    Id like to see the rest of the truck lol.
  4. Nov 4, 2021 at 8:45 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Ditto
    Junkhead likes this.
  5. Nov 5, 2021 at 3:09 AM
    USMILRET
    Including the picture posted by the OP in this thread I have never seen an engine block rust through. That Tacoma possesses some of the heaviest rust.
  6. Nov 5, 2021 at 4:04 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    This, then put a bolt with liquid tape
  7. Nov 5, 2021 at 4:14 AM
    cmoore
    cmoore Well-Known Member
    Charlie
    Dallas, Texas
    PreRunner
    Based on the photo I would say that truck is about done. I would not invest big money in the engine. I can only imagine what the frame and suspension look like.
  8. Nov 5, 2021 at 4:26 AM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I wasn't thinking about a screw, but that's not a bad idea. I'm with everyone else who suggested epoxy/JB Weld. Might even drill and tap and machine screw. Peen it. Lots of possibilities, not like it's a 100 psi in there
  9. Nov 5, 2021 at 4:55 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Id be worried about metal chips falling into the engine using a screw (let alone drilling first). Its a pretty small hole and presumably not under a high pressure or else OP would have lost all oil in very short order. Id think regular old JB Weld (with good surface prep) would be enough.
    And OP, you might consider a trip to another dealer to get a second opinion on the frame. Unfortunately the nasty shit they use on the roads nowadays eats vehicles alive up here in the Northeast. Without some sort of preventative measure like Fluid Film, etc. expectations are for vehicles up here are low. :(
    tacotoe likes this.
  10. Nov 5, 2021 at 10:46 AM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    Cast iron is easy to braze if you have the equipment and know how to braze.
    Jimmyh likes this.
  11. Nov 5, 2021 at 10:55 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    band aid repair
    that freeze plug looks a 1/2 step to the squirtz
    anything could work for a while
    what the heck
  12. Nov 5, 2021 at 2:05 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I mean.....if it's otherwise a decent rig....why not?
    SR-71A and tacotoe like this.
