2.7L engine knock
Discussion in '4 Cylinder' started by wgerow, Dec 9, 2010.
  1. Jan 2, 2016 at 8:44 PM
    #61
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Nothing like a quick warm truck,,when it's a bit chilled outside. Your truck will thank you. Your oil should be fine,,for quite a bit colder.
    Some of those pad heaters can get damn warm. Just a heads up. My buddy uses one for a coffee cup warmer in his shop, and if you accidentally lean on it,,you immediately know you did :bananadead:.
  2. Jan 6, 2016 at 7:03 AM
    #62
    kwrnh
    kwrnh New Member
    2011 access cab 2.7 - 5 speed
    My 2002 2.7 had the knock on cold mornings, and I just discovered my 2011 (which I bought used in August 2015) has it too.
    From everything I've read here and elsewhere, it's not uncommon. In fact, I just got back from the Toyota dealer (where they replaced my catalytic converters under a special service campaign) and I asked about this issue. The tech said yes, it's not uncommon and yes it is the piston skirts slapping the cylinder walls. In a nutshell, their answer was "<shrug>, just let it warm up until it goes away". That doesn't change the fact that it's an incredibly alarming noise!
    On the plus side, Toyota replaced the frame on my 2002 and now just gave me brand new catalytic converters, for free! So I'm willing to cut them a little slack.
  3. Jan 6, 2016 at 2:40 PM
    #63
    40950
    CR, WA
    stock
    Since I went to alky free fuel,,no severe cold knocks the last handful of years. Imagine that.
    I can induce it,,if I'm stupid late and get greedy, but we try not to be that way. My windshield has been iced over every morning,,so plenty of warmup. Needle level operating temp as a matter of fact.
  4. Jun 6, 2016 at 7:20 AM
    #64
    boricua41
    boricua41 Active Member
    Check and change the PCV valve. I had the same thing and was changing a few things. Like the injectors seals and the PCV valve and its2not doing it now more. Hope this helps.
    Chay
  5. Jun 9, 2016 at 11:47 AM
    #65
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    This issue is well-documented. These engines knock when cold because of the hypereutectic pistons: https://en.wikipedia.org/wiki/Hypereutectic_piston
    Some prefer to deal with it by using a pan heater/coolant warmer, or letting the engine run and warm up a little before driving. Others (like me) don't worry about it and drive away gently when fast idle comes down, but I very rarely see anything below 30*F. Either way, they will happily run many times 100,000 miles with this knock.
    Other kinds of knocking (fuel or emissions related, etc) should be investigated pronto.
  6. Jun 10, 2016 at 4:27 AM
    #66
    boricua41
    Mine was the same way. It use to know when engine was cold. They changed the pvc valve and injectors O rings because engine light on from code p0440, and after they changed that, the engine sound went away and hasn't sound any more. That knock was also driving me crazy. It started around 40,000 miles and mnow had 60,000 miles. 02 tacoma 4x4. By the way the P440 was the fuel pump gasket.
  7. Jun 14, 2016 at 1:51 PM
    #67
    Albino Taco
    Albino Taco Member
    Helotes, TX
    '10 Super White Tacoma Reg. Cab 2.4L 4x4
    Brush guard, winch
    Yall should have heard my engine knocking the other morning...wound up being a raccoon taking a snooze!
    ToyotaJim, CusterFan and PROseur like this.
  8. Jun 14, 2016 at 2:01 PM
    #68
    DGXR
    Friend
    Sacramento, CA
    What?! Yall gun kill that snoozy coon!!! KILL!!!!! lmfao
  9. Nov 29, 2016 at 1:09 PM
    #69
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    My 01 does this, it has the 2.7L and 193K miles. Temps under 40F this week, and the piston slap in the morning. Quite embarrassing, if parked not at my own house. Sounds like an old jalopy :(
  10. Nov 30, 2016 at 7:31 AM
    #70
    40950
    CR, WA
    stock
    Let them warm up for 5-10 minutes or more,,if you have audible piston slap right after cold startup. Don't try and drive on that noise. Just because the noise suddenly disappears during warmup does not mean take off immediately. Let it run for a few more minutes after that.
    PROseur likes this.
  11. Nov 30, 2016 at 7:32 AM
    #71
    PROseur
    Pussy
    Appreciate the heads up
    I was driving it after the noise goes away
    But will give it some more warm up time
  12. Dec 1, 2016 at 8:10 PM
    #72
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    My 2.7 had 120,000 on it when I bought it. I heard the slap for just a second or less a couple of times. It wasn't cold outside either. Maybe around 65 or 70. Thicker oil can help with piston slap. I've been running 10-30 Amsoil since and haven't heard that noise since. Actually, I did run Mobil 1 for a few changes and then went to the Amsoil. Depending on where one lives thicker oil is an option. It gets well below zero where I live in the winter and the 10-30 hasn't caused a problem. It "is" a full synthetic though and that makes a huge difference. A dino 10-30 wouldn't fare as well at temps like that.
    As far as letting it warm up that's very good advice as well. Putting a load on the engine with the pistons slapping is a no-no. I let my engine warm up even in the summer time. I wait until it gets at least to the "cold" mark on the temp gauge before I take off.
  13. Dec 1, 2016 at 10:07 PM
    #73
    PROseur
    Pussy
    Interesting. Mine seems to be temp dependant only.
  14. Dec 2, 2016 at 12:40 PM
    #74
    DGXR
    Friend
    Sacramento, CA
    Is it OK to drive gently with piston slap? Technically that is still loading the engine, but not much. I've been doing this for years, gentle driving with light piston slap. After the high idle comes down and I roll away, the slap goes on for about 45 seconds and only when the temp is below 40F. I am extra light on the throttle during this period. So really it doesn't happen very often, and I've never had any problems, but I don't want any problems either. 45 seconds is not very long to wait so maybe I will start waiting until the slap stops.
  15. Dec 2, 2016 at 12:41 PM
    #75
    PROseur
    Pussy
    Same here. I live on a top of a hill. So usually piston slap will die down in 30 seconds. Reverse. Put it in D2, and essentially coast down for about a 1.5 before getting on the throttle
  16. Dec 2, 2016 at 12:46 PM
    #76
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Mine has been knocking now that it's cold.
    Hadn't heard it before (bought new in 2013), but didn't cause me any concern.
  17. Dec 2, 2016 at 12:48 PM
    #77
    PROseur
    Pussy
    seems to be pretty common with the 2.7L
  18. Dec 2, 2016 at 12:49 PM
    #78
    T4RFTMFW
    I love you.
    PROseur likes this.
  19. Dec 2, 2016 at 12:50 PM
    #79
    DGXR
    Friend
    Sacramento, CA
    Get a room.
  20. Dec 2, 2016 at 12:54 PM
    #80
    PROseur
    Pussy
    I tried. But he won't tell me his size.
