2.7L engine power opinions?
Discussion in '4 Cylinder' started by Soundwave, Dec 28, 2008.
  1. Dec 28, 2008 at 7:37 PM
    Soundwave
    Soundwave [OP] Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    I have been wanting a 2nd gen Tacoma ever since they came out in 2005 and now I am going for it. I was excited to learn that for the first time here in Canada they are offering the 2.7L 4 banger 4x4 access cab! So I quickly orderd one in Magnetic Grey. The fuel economy and $3000 less msrp than the V6 Access cab made it affordable for me to get a new Tacoma. Will I be missing out on the V6 power? I haul a full size quad and plan on towing a tent trailer wit it. How are your experiences with the 2.7 4x4?
  2. Dec 29, 2008 at 9:40 PM
    darkturtleninja
    darkturtleninja 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    although i havent had any experience with a stock tacoma 4cyl.. im impressed by the ability of a 4 banger to break 34inch tires loose on dry pavement..... other than that i wouldnt call it a powerhouse by anymeans... low rpm power sucks, but it does viciously build power in the higher rpms but then drops off after about 5500rpm. id say the 4cyl is a good truck to play in but it isnt a towtruck.....
    then again i have the first genn
  3. Dec 30, 2008 at 2:30 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    The problem isn't power, the 2.7 is a great engine, it's the gearing, My base runs 2400 RPMs @ 75mph with manual 5 speed!!, Truck seriously needs more gear. It's going to get the appropriate rear gear change in the spring. I want to be running 2600-2700 RPMs @ 75 mph.
    Motoretro
  4. Jan 1, 2009 at 4:57 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I have a 08' PreRunner w/ the 2.7L 5spd manual. It has 265/70 tires on the stock wheels. The rear end gear ratio is 4.10 in the PreRunners and at 75 mph I'm running around 2700-2850 rpms. Makes all the difference on the hills in my opinion but can hurt the mileage a little. I still manage to pull off around 19 to 21 mpg in the city. (those tires are pretty heavy too, 10 ply rating)
    It would be nice though if they had a 6 spd in these and spaced the gearing out so you could use 1st as a LO gear and start off in normal circumstances from 2nd. The 4 cyl really lacks the torque to make it up very steep hills without having to keep moving fairly fast (5-7mph) otherwise it just lugs like crazy.
  5. Jan 1, 2009 at 5:19 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    I hauled two quads before with my old POS gmc sonoma, def. wasnt suppose to haul that much but it did.......
    you'll be good with a 4 banger taco though
  6. Jan 1, 2009 at 5:24 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    man stick with the 2.7 i love it, yes i wish the gearing was a lil better but if its a few grand go spend it on the v6 or change the bloody gearing and put a detroit trutrak in it while youre at it
  7. Jan 1, 2009 at 5:27 PM
    SC4333
    Grant
    FL
    ^^^^^ You got the idea! ;)
  8. Jan 1, 2009 at 7:34 PM
    motoretro
    Michigan
    I priced it......about $885.00 plus shipping for complete rear pig. I'm going this route in the spring. Aside from the improved performance, I feel it's effect will also help with some of the other complaints I have with the truck.
    Motoretro
  9. Jan 1, 2009 at 7:51 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    donde es pesos?
  10. Jan 1, 2009 at 8:39 PM
    SC4333
    Grant
    FL
    According to Motoretro that would be 12,111 pesos... apparently the Mexican economy isn't fairing well to the us dollar. Oh and dont forget the tax + shipping and that 18/100ths of a peso I left out.;)
    better buy it quick before that dollar goes up!
    EDIT: Ha, I am a moron. I just noticed you were asking where is the money, now how much money...
  11. Jan 3, 2009 at 12:05 PM
    Soundwave
    B.C. Canada
    OEM Roof rack
    Thanks for the input! So the Pre-Runner has a lower gear ratio than the non-prerunner Tacomas, does this also mean that the 4x4 3.7L Tacomas also have this lower ratio than the 2wd's?
  12. Jan 3, 2009 at 1:11 PM
    SC4333
    Grant
    FL
    My PreRunner has a 4.10 rear axle ratio where as (dont quote me on this either) im pretty sure the late model tacoma 4x4 autos come with SOMEWHERE around 3.73 gears. Keep in mind the PreRunner is 2wd setup, just with a beefed up rear end, different gears, and higher stance. Now for your 3.7, I am not sure if its any different. I would imagine you could find out exactly whats in your diff via the vin number if all else fails. Someone around here would know what should have come with it though.
    I found this quote from a different thread that was oriented towards fuel mileage....
    Originally Posted by 007Tacoma [​IMG]
    Holy CRAP!
    No wonder the V6's are getting such good gas mileage - according to the Toyota website, the V6 (Access Cab and Double Cab) have a 3.73 rear end. The regular suspension 4 cylinders get a 3.31 (manual) and a 3.58 (automatic). So I have the highest gear ratio out of all of them (4.10). No wonder it is so hard for me to hit 27 MPG. :(
    Oh well, at least it has some damn good power. ;)
    Hopefully someone with some more expertice in the area will chime in on this one. I am confident that what i told you is correct, although I might be forgeting something.
  13. Jan 3, 2009 at 1:14 PM
    Soundwave
    B.C. Canada
    OEM Roof rack
    Sorry, I meant 2.7 4 cylinder 4x4
  14. Jan 3, 2009 at 1:22 PM
    Soundwave
    B.C. Canada
    OEM Roof rack
  15. Jan 3, 2009 at 1:35 PM
    SC4333
    Grant
    FL
    Looks like you got it covered! ;)
    I wouldnt trade the 4.10s for nothing. Gives it a big kick in the ass, and my mileage is still around 19-20 mpg city. This is with some pretty heavy and fairly large tires, with a 3 inch lift. Now i dont haul ass all over the place but i do not make it a point to do otherwise.
  16. Jan 3, 2009 at 1:45 PM
    motoretro
    Michigan
    I think the higher gear ratios are there for tire height compensation mostly. The Pre-Runner gear ratio is 4:10 and if the tires are 265/70/16 the RPM's at 75mph with manual trans in 5th gear should be 2701 RPM's.
    An example;
    I have a base truck with 5 speed manual with 3:31 & 26.8" std tire, At 75mph in 5th gear I'm turning 2490 RPMs. If I go to the 3:58 which is used in base trucks w/ auto, My RPM will be 2685 RPMs @75mph. This should help alot with the off the line bog and still have more roll-on than a Pre-runner since I'm not pushing as much air or weight. I doubt it will affect my mileage.....I feel 2700 RPM's is a sweet spot for the 2.7 engine. If is does, I could split the difference by going to one size taller tire(27.4") and get 2640 RPMs @75 mph or two sizes taller(27.95") and get 2587 RPM's @75 mph, still better than stock.
    Motoretro
  17. Jan 3, 2009 at 1:55 PM
    SC4333
    Grant
    FL
    That 2701 sounds right on. After i made that post the other day, I made a point to see what it was. I over guestimated the RPM a little. Your calculations are dead on what im getting on the road.
    For the tire size, I dont want anyone to think that is what the truck came with. It had some dinky little 245/75/R16's when i got it. So its had a pretty drastic change in size. I didnt really notice a change in MPG on the highway after the change. Probably due to the increase tire size and lower rpms? Now city driving took a hit by around 2 mpg.
    EDIT: I also noticed there is a HUGE difference in RPM from 70 to 75. This must be due to the 5 gear ratio.
  18. Jan 3, 2009 at 7:41 PM
    Soundwave
    B.C. Canada
    OEM Roof rack
    The 4.10 gears and the heavier curb wieght of the 4x4 versus 2wd 2.7L makes sense. Ive driven 2wd 2.7L Tacoma so I can't wait to compare the lower gears to the 4x4.
  19. Jan 3, 2009 at 9:01 PM
    wawireguy
    wawireguy Well-Known Member
    If it's a 4x4 you gotta change the front gearing to if you change the rear.
  20. Jan 3, 2009 at 9:34 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Bud I can't speak for the new ones but I have my old 97 Tacoma with the 2.7 and that truck still has balls even at 135K. My dad uses it to haul lawn equipment and whatever he does not want to use his Tundra for more than a car. I used to drive the hell out of that truck and in 5th gear ( I know you are looking at the auto) it would pull a hill when my buddies with the V6 were shifting. If you have the option the manual tranny really helps to bring the 4 banger to life but it will cover your needs.
