2.7L engine ticking noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grover738, Aug 22, 2023.
  1. Aug 22, 2023 at 7:14 PM
    grover738
    grover738 [OP] New Member
    2007 Tacoma SR5 Access Cab / 5-Speed / 2.7L
    My '07 with the 2.7L manual has developed a ticking noise over the last couple thousand miles. Has gotten more noticeable. No noise on cold starts but develops within 30 seconds or so and does not go away. It's RPM dependent, so ticks faster as it revs. Took it to a mechanic, he said it's internal, he took valve cover off but didn't seen anything abnormal. He added an oil treatment (Lucas) and said to drive it a bit, he suspected a stuck lifter.
    Thoughts? Am I possibly causing damage by driving it? What's the fix?
    Here's the sound:
    https://youtu.be/xIRALkGf3FI
  2. Aug 23, 2023 at 3:10 PM
    grover738
    bump....anyone?
  3. Aug 23, 2023 at 6:02 PM
    Avotaco
    Avotaco Active Member
    Eric
    Jersey
    94 PU 4x4 4cyl MT reg cab, 06 Taco 4x4 4cyl MT Acc Cab
    yup sounds like a lifter.
    fwiw- i have a 94 p/u with a 22re that i bought new. i lost a hose clamp and overheated in traffic when the truck was new and have had a very similar lifter slap in that truck for the past 225k miles and 28 years. have you overheated recently?
  4. Aug 23, 2023 at 6:35 PM
    Biblebuilt4x4
    Biblebuilt4x4 Well-Known Member
    Bill
    2014 Reg. cab 4x4 automatic
    Could be a lot of things. Take it to a real mechanic.
    Lucas is not going to fix that. It only makes the oil thicker.
  5. Aug 23, 2023 at 9:01 PM
    grover738
    I had an old 22r also, loved it. Have not overheated my '07. 130k miles BTW. Hopefully something cheap to fix...
  6. Mar 1, 2024 at 11:41 AM
    Smith225
    Smith225 New Member
    Have you figured out what the problem is I have the same exact noise on my 06 tacoma sr5 manual/2.7l
  7. Mar 2, 2024 at 10:34 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That certainly does sound like a stuck hydraulic lifter.
    Has the oil been changed on schedule?
    What did it look like under the valve cover?
  8. Mar 11, 2024 at 4:47 PM
    Tbrom
    Tbrom Well-Known Member
    Tim
    Western Pennsylvania
    2008 reg cab
    I had a similar sound to that. It turned out to be a tensioner pulley. I am sure you have figured it out by now but just in case. To check it dump some water on the belt and see if the noise goes away.
  9. Mar 12, 2024 at 6:29 PM
    Biblebuilt4x4
    Bill
    I would say it could be a lifter. But a real mechanic could tell you for sure.
  10. Mar 12, 2024 at 9:23 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Could be a lot of things....
    Sounds internal but I could be mistaken. Recommend taking of the serpentine belt and starting the truck for about a minute....maybe two. Then you will know if its part of the accessory drive at least.
    I would not take it to a mechanic who puts Lucas in it....that isn't going to really do anything for your truck.
    Biblebuilt4x4 likes this.
