2.7L Fuel Filter Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by AGumbus11, Oct 16, 2009.
  1. Oct 16, 2009 at 7:47 AM
    AGumbus11
    AGumbus11 [OP] Member
    Andy
    Milford, CT
    Any DIY's on Fuel Filters for a 1997 4x4 2.7L?
  2. Oct 16, 2009 at 7:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    None that I know of. Its under the intake manifold. You need to access it from the driver side wheel well. Its a tight fit with your hands.
  3. Oct 16, 2009 at 7:51 AM
    AGumbus11
    Andy
    Milford, CT
    Ouch. My lexus' fuel pump dumped almost a gallon onto me when i took it off...any similar issues with the tacoma's?
  4. Oct 16, 2009 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No. It lets out about 8 ozs at the most
  5. Oct 16, 2009 at 7:54 AM
    AGumbus11
    Andy
    Milford, CT
    Do you think its best to go after it with a universal joint? I'd guess its probably a real tight spot to work...I found that out last night trying to get off my oil filter.
  6. Oct 16, 2009 at 7:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....
  7. Mar 22, 2011 at 4:32 PM
    JVannett
    JVannett Member
    Fargo, ND
    1996Tacoma Reg 2.7 4WD
    31" Tires 31x10.5 15"
    I'm just replacing my fuel filter. just bought it from my cousin and the whole truck works GREAT. It has 135000 miles and just thought it would be good to give it a tune up... i think its a terrible place for fuel filter. anyone know any other way to replace it with out taking the intake manifold off or through the wheel well..
  8. Jun 18, 2015 at 1:45 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Does anyone know the size or sizes of the crush washers? The filters usually do not include these.
  9. Jun 18, 2015 at 6:31 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    yes, it is very easy to reach it from the top.
    you feel for the bolts with your hands and then remove it from the top and its not hard at all, the key is you need to be able to turn a bolt without having to be able to see it as you turn it.
    also I suggest you relocate the filter once you remove it so see my thread here: https://www.tacomaworld.com/threads/diy-2-4l-2-7l-fuel-filter-relocation-mod.349406/
  10. Jun 18, 2015 at 6:32 PM
    keakar
    karl
    louisiana
    if you get the wix filter it comes with 4 new crush washers
  11. Jun 18, 2015 at 6:46 PM
    Caligula
    Los Angeles, CA
    Good news. I just heard back from my guy at BMA Auto Parts (www.bmaparts.com)
    Fuel Filter Seal - 90430-12026 - $0.45 each
    I think they are just an odd M12 washer, ill measure once they arrive.
  12. Jun 18, 2015 at 8:25 PM
    trx125
    trx125 Well-Known Member
    Jack up vehicle, remove the driver's tire and rubber splash guard. It's a straight shot at the FF clamp bolts. Loosen the bolts only, then from the top remove the bolts and band clamp that holds the filter. Pull the filter away from the motor and undo the hoses from the holders attached to the fender well and fire wall. This will allow you enough movement in the FF to undo the banjo bolts from the front and rear of the FF. Reinstall in reverse order. Shouldn't take more than 20 minutes(this includes drinking a couple cold ones and some choice words thrown in for good measure). It is 100x easier than doing the FF replacement on the older 22re's.
  13. Oct 12, 2015 at 8:08 AM
    Wolverinesam
    Wolverinesam Well-Known Member
    New York State
    2013 Tacoma Prerunner 2.7L
    What's a banjo bolt? Have seen that on a couple of threads. Thanks.
  14. Oct 12, 2015 at 10:29 AM
    trx125
    This is what holds the fuel lines on the fuel filter.
  15. Oct 12, 2015 at 11:11 AM
    Caligula
    Los Angeles, CA
    The post above ^
    The hollow bolt that allows fluid to pass through it into the banjo fitting to the left.
  16. Oct 12, 2015 at 1:35 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I let a good local shop swap mine out. It was original from 1995 and nasty.
  17. Oct 21, 2015 at 3:31 AM
    Wolverinesam
    New York State
    Any recommendations for the filter? Dealer? Autozone? Somewhere else?
  18. Oct 21, 2015 at 3:36 AM
    Caligula
    Los Angeles, CA
    Call a real parts counter like BMAauto.com or any local place. OEM replacement all the way. Mine was a Mann filter. You may need to order 4 of the gasket rings, i posted the part number above.
  19. Oct 21, 2015 at 8:03 AM
    Wolverinesam
    New York State
    Never mind. Stopped in at dealer and found out that the fuel filter for at least the '13's are part of the fuel pump. Not user serviceable. "It should never need to be replaced. ".
  20. Oct 21, 2015 at 8:19 AM
    keakar
    karl
    louisiana
