2.7L Gas Mileage Tracked for One Year Results
Discussion in '4 Cylinder' started by jdonal05, Jan 12, 2013.
  1. Jan 12, 2013 at 3:25 PM
    jdonal05
    jdonal05 [OP] New Member
    NJ
    2001 2.7L standard trans extracab
    265/75 R15 BFG A/T tires, Lund tri-fold tonneau cover, frame replacement by Toyota in 2010
    Hi all,
    I have been using this website for tips for a long time now but this is my first contribution. Although not a scientific experiment by any means, I did observe a few things:
    -if you want to increase MPG, lay off the gas and drive highway
    -a tonneau cover does help at highway speeds, but only 1 MPG or less
    -even though the results posted dont show it, synthetic oil also slightly helps mileage (I still have the vehicle)
    -for those of you who get gas on military bases, AAFES gas tends to yield slightly less mpg
    Hope the data helps some! I am absolutely attached to my Tacoma--people try to buy it from me all the time.
    2001 Toyota Tacoma Extracab 2.7L 4wd Manual Transmission + tri-fold tonneau bed cover + 265/75 R16 BFG A/T KO tires
    * trailer is 450 lb single axle Carry-On landscaping type 2K lb capacity
    Fillup Date MPG Description
    12-Apr-11 16.8 most city 1/5 hwy + occasional 4wd use
    25-Apr-11 17.6 most city 1/4 hwy
    9-May-11 17.7 most city 1/3 hwy + both O2 sensors replaced
    25-May-11 18.8 most city 1/4 hwy + A/C use + occasional trailer use
    5-Jun-11 18.4 most city 1/3 hwy + A/C use + rear catalytic convertor replaced + bedcover down
    5-Jul-11 18.4 AAFES gas most city + A/C use + front catalytic convertor replaced
    5-Aug-11 18.2 AAFES gas most city some hwy + A/C use
    5-Aug-11 16 AAFES gas most hwy + A/C use + pull trailer
    7-Aug-11 16.9 BP gas most hwy + A/C use + pull trailer--avg speed 55 mph
    7-Aug-11 18.3 BP gas most hwy + A/C use + pull trailer--Interstate speeds
    22-Aug-11 16.8 Gulf gas most city
    9-Sep-11 17.1 AAFES gas most city 1/3 hwy
    7-Oct-11 16.6 AAFES gas most city
    9-Oct-11 21 AAFES gas most hwy + bedcover open--avg speed 70 mph
    10-Oct-11 21.7 Citgo gas most hwy + bedcover closed--avg speed 70 mph
    16-Oct-11 19.9 Liberty gas most city 1/3 hwy + bedcover closed
    16-Nov-11 15.3 AAFES gas most city--added HEET water remover and STABIL
    6-Dec-11 16.8 AAFES gas most city
    28-Dec-11 14.9 AAFES gas most city--warmups in AM
    13-Jan-12 14.7 AAFES gas most city--warmups in AM
    14-Jan-12 19.8 AAFES gas most hwy + bedcover closed
    16-Jan-12 18.5 BP gas most hwy + bedcover closed--some 4wd and mtns drove across 2 ft deep river
    17-Jan-12 20.5 Valero gas 2/3 hwy some city + bedcover closed
    18-Feb-12 14.8 AAFES gas most city + warmups in AM--switch to synthetic 5W-30 oil and filter change Mobil 1 Extended Performance
    7-Mar-12 16.5 AAFES gas mid-grade most city 1/4 hwy--warmups in AM
    25-Mar-12 17.8 AAFES gas most city 1/5 hwy
    24-Apr-12 14.8 Gulf Gas almost all city
    9-May-12 17.2 AAFES gas most city 1/4 hwy
    Low: 14.7
    High: 21.7
    AVG: 18.2
  2. Jan 12, 2013 at 6:42 PM
    TwzteD
    TwzteD Well-Known Member
    Kyle
    St Lucie Fl
    2013 4x4 reg cab Auto
    2013 4x4 reg cab, 2011 4runner sr5 rims, 265 general grabber at2's, 5100's All 4 corners with fronts at .85, De badged, Egr Rainguards, Led tail lights, Int wipers, fog lights, Trailer Hitch, POwer locks+ keyless entry, Extang Solidfold Bed Cover, WeatherTech Mats, Stubbie Antenna, Trd Skid Plate, Tint, Scanguage, Cargo net in bed, Sound Ordnance B-8PT, FULID FILM Under Coat.
    I am just curious is it normal for a new engine to get bad mpgs? I have like 1300 miles and every tak is getting better but I started at like 13 mpg on the first tank, btw welcome and where in jersey u from?
  3. Jan 12, 2013 at 6:50 PM
    TwzteD
    Kyle
    St Lucie Fl
    Well it is winter I have bigger and heavier tires and rims and an auto my last truck got 20-23 mpg per tank but it was stick, I'm getting 16 mpg now it's going up but it could be the winter blen gas and warmup times also killing it.
  4. Jan 12, 2013 at 6:59 PM
    HomerTaco
    HomerTaco Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    good job OP
  5. Jan 13, 2013 at 2:58 PM
    jdonal05
    NJ
    Thanks for the compliments on the record-keeping all. I'm currently located at McGuire AFB and soon to move to Milwaukee, WI.
    Yes, city driving and warmups in the AM kill the mileage significantly. Something you all might notice from my post is that I had both cats replaced. This is because they were clogged with carbon powder. At the time, I had 145K miles on it (I originally bought it 5 years ago with 100K miles on it) and decided to do an experiment driving cross country with those STP fuel additives. What I found was that none have any significant effect on MPG's (most decrease it), but the Octane orange bottle ups it maybe 1-2 MPG's. However, it costs the same as another gallon of gas so no joy. Just before I started to track my mpg, I also bought a can of BG 44K and ran it through the engine. No noticeable effects except the check engine light came on throwing an O2 sensor code. After replacing both O2 sensors, I had the cats replaced by someone I know. He told me there was something I should see after he replaced them:
    He proceeded to grab one of the old cats and knock it against a piece of wood. Carbon powder poured out. Both cats were plugged from the carbon those fuel additives displaced. Just some food for thought if you have an older vehicle.
    I also just found some cake batter in the oil filler cap too--this is the first time I've seen it. I've got 155K miles on the truck now. I've never changed the PCV valve so hopefully that may help if I can just find it!
  6. Jan 13, 2013 at 3:06 PM
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    12' reg cab 4x4 2.7L auto
    ^^ cake batter doesn't sound good. It's not coolant is it?
  7. Jan 14, 2013 at 1:43 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Hometown?
    I was born in Milwaukee & raised in Wauwatosa.
    My '11 4x4 2.7 AC with a 3" lift gets a consistent 20 MPGs hwy on winter gas & 24 MPGs hwy on summer gas with stock tires.
    When I put on the 255/85/16 BFG KM2s my MPGs vary from -2 (hilly) to +2 MPGs (flat) compared to stock tires.
  8. Mar 17, 2014 at 4:09 PM
    jdonal05
    NJ
    Originally from Orange County, VA. Still got the Tacoma with 165K miles on it now. The highway driving up and down I-94 makes sure I get the engine heated up good and the cake batter is now gone.
    Man I love that truck--that thing is a tank. I went sideways down an exit ramp in snow and kissed the guard rail and put another dent in the chrome bumper. It'll buff out. Oh well. Been through some good times in that truck--drove it across the Rapidan river up in the mountains in VA, drove it a couple of miles out on an ice road into Green Bay, survived a camping and deer hunting trip in the Michigan U.P. with it in eight inches of snow, got it stuck in mud in New Jersey (the one and only time), drove it to the summit of Pikes peak in Colorado, and outran a snow storm with it in the panhandle of Oklahoma (totally vaporized a tumbleweed doing 80 MPH too). And hopefully many more good times.
    Also just recently got a linex bed liner installed on it--works great so far!
  9. Mar 28, 2014 at 9:12 AM
    nanney1
    nanney1 Active Member
    jdonal05:
    What is your rear axle?
  10. Mar 28, 2014 at 10:36 AM
    navin
    navin Well-Known Member
    I guess I shouldn't complain. I have a 4x2, 5 speed stick, brand new getting 22 MPG mixed. I still ask, why is this so damn low? That is mostly highway driving, very gentle foot on the pedals. It is pretty much dead on what they expect on the EPA sticker but I just don't get it. I could milk my kids 2010 F-150 V8 to this MPG.
    I love the smaller size but I really thought I'd be getting 25 MPG empty the way I drive it. I was getting nearly the same in a 2003 Mach 1 Mustang with 4.56 gears fer cryin out loud.
  11. Mar 28, 2014 at 4:47 PM
    Swamp Donkey
    Swamp Donkey Well-Known Member
    Fort St John B.C
    2011 4cyl SR5 auto 4x4
    I have been keeping track of my mileage for about 2.5 years.
    17,144.01 liters
    123251 km's
    Overall average of 16.9 mpg
    Any questions?
  12. Mar 28, 2014 at 4:56 PM
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
  13. Mar 28, 2014 at 5:12 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Here's the excel file I use.
    Frank
  14. Mar 29, 2014 at 11:57 AM
    Awakensleep
    Awakensleep Active Member
    Kevin
    San Diego
    03 4WD Access SR5 2.7 5spd
    Receiver (Clarion CX609), speakers (Polk DB 5 1/4 component set up front, Polk DB 5x7 rear), small sub under drivers seat (Sound Ordinance- only available through Crutchfield), Aluminum Xcab window hinge, Weathertech mats, 2010 Tacoma Off Road wheels
    I feel my life is unorganized after viewing this excel file
    jdonal - great info. i have a 2003 with the same specs and get about the same milage. i was curious about the BF A/T KO since they are damn near 10 lbs heavier than other A/T tires out there
  15. May 25, 2016 at 5:10 PM
    Xzyk
    Xzyk (bochok)
    Tiano
    Palm Springs, CA
    2013 Tacoma AC 4x4 M/T 2.7L
    Access LE, Pop&Lock
    I thought I was the only one obsessed with tracking MPGs.
    Here's mine: 2013 Toyota Tacoma Access Cab 4x4 2.7L M/T
    • Access Tonneau Cover installed around August of 2015.
    • Bone stock (other than cover)
    • Factory original tires
    • Only one type of gasoline used: Shell V-Power
    Google Sheets
    Edit: Removed attached file and linked spreadsheet
