2.7L idler bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ram1009, May 18, 2025.
  1. May 18, 2025 at 9:05 AM
    ram1009
    ram1009 [OP] Active Member
    Robert
    Tacoma 2008 Access Cab White 2.7L Engine, Auto Trans
    I'm trying to order both idler bearings but the part descriptions are confusing and contradictory. Are both bearings the same? If so, why are they listed separately and with different prices? What should I buy?
  2. May 19, 2025 at 6:08 PM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Do you want bearings, or pulleys? The pulleys are all different, no idea on the bearings. If you buy bearings on Ebay they will most likely be garbage and won't last long.
  3. May 20, 2025 at 3:47 AM
    ram1009
    Robert
    I misspoke. I want the pulleys. I,m going to call a Toyota store.
    Steve_P[QUOTED] likes this.
  4. May 28, 2025 at 4:20 PM
    Steve_P
    TN
    As an FYI for anyone in the future, one of the pulleys is hard to find in the part diagrams and is on the drawing for the timing chain cover, or similar. Not easy to find.
