2.7l is weak, should I regear???
Discussion in '4 Cylinder' started by 00PreRunner, Apr 25, 2012.
  1. Apr 25, 2012 at 5:56 AM
    00PreRunner
    00PreRunner [OP] Well-Known Member
    New Albany, MS
    '02 TRD 4x4
    2002, auto to manual swap. 35's and 5.29's
    I have a 2000 Prerunner with the 2.7l and auto tranny. The truck is very weak off idle and gets bad gas mileage around town. A friend has a set of 4.30's I can use to swap out my 3.91's. My question is how high will my rpms be going down the interstate and how off will my speedo be? Thanks
  2. Apr 25, 2012 at 6:30 AM
    Devux
    Devux The StarMan
    Devin
    Las Vegas, NV
    2011 PreRunner
    Stone stock.
    I can't quantify anything for you but in general going from a 3.91 to a 4.30 your performance (acceleration distance) will increase, your fuel mileage is going to drop, and your highway RPMs are going to be higher.
    If you're looking for a performance increase it might be worth looking into a good exhaust system, intake, hot ignition and high performance plugs and plug wires. My dad did a mild tune to his '98 Rodeo (4 Cylinder), it gave it a bit more oomph, he's happy with it. Better than messing with the rear gear in my opinion.
  3. Apr 25, 2012 at 6:32 AM
    00PreRunner
    New Albany, MS
    '02 TRD 4x4
    Thanks for the advice. I'd much rather look into exhaust and intakes then gears.
  4. Apr 25, 2012 at 5:44 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
  5. Apr 25, 2012 at 6:01 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The math is really simple.
    Current rpm times 4.30/3.91 or 1.1
    If you are 2500 at 60 now you will be 2500 * 1.1 = 2750.
  6. Apr 26, 2012 at 5:58 AM
    00PreRunner
    New Albany, MS
    '02 TRD 4x4
    Thanks for the help. I'm adding cruise control here in a few days. I'll see if that makes a difference.
  7. Apr 26, 2012 at 7:08 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    I have a 2.7 with automatic, and it has 4.56 gears from the factory.
    Are you sure you have 3.91's? What is your axle code on the door jamb?
  8. Apr 26, 2012 at 7:14 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    have you done a head to toe tune-up on the motor/vehicle?
  9. Apr 30, 2012 at 5:49 AM
    00PreRunner
    New Albany, MS
    '02 TRD 4x4
    The code on the door is B06A. From what I can tell, that means it has an 8" diff, 3.91's, and an open rear end. And no I haven't tuned it.
  10. May 1, 2012 at 10:40 AM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    New spark plugs(platinum or iridium), Afe pro dry or K&N air filter. I bet you will feel a difference. Also, do the seafoam mod. 1/3 bottle in the gas tank,1/3 in the oil (pre oil change, ride on it for about 1000 miles to let it do some work) 1/3 bottle in the intake manifold. Ill try to find the thread on it for you.
  11. May 1, 2012 at 10:43 AM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    I second the tune up. And if that's not sufficient the intake/exhaust options. . .
  12. May 1, 2012 at 11:10 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Usually only regear if you are running larger tires. Do a tune up.seafoam. aftermarket air filter. Your truck is just slow. Buy a v6 or v8.
  13. May 1, 2012 at 12:11 PM
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
  14. May 2, 2012 at 5:45 AM
    00PreRunner
    New Albany, MS
    '02 TRD 4x4
    Thanks for the seafoam link
