2.7L LCE Stage 1
Discussion in '4 Cylinder' started by 06HAOLE, Oct 27, 2014.
  1. Oct 27, 2014 at 9:04 PM
    06HAOLE
    06HAOLE [OP] Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    The point of this thread is to document the LCE Stage 1 parts and if they make a difference.
    My cylinder head is done on my 2.7L 3RZ. My buddy did a compression test and my #1 cylinder is at 80 psi while the other cylinders test at 150 psi. My bottom end tests fine so down the rabbit hole we go.
    I ordered the following parts:
    LCE Stage 1 Cylinder head
    LCE Stage 1 cam
    LCE metal cylinder head gasket
    ARP head bolts
    Doug Thorley header
    The parts come in at the end of the week so I'm stoked to get my truck fixed. This all stemmed from a check engine light for cylinder #1 misfire. Word to the wise: buy a scanner and check your motor. It's a lot cheaper in the long run.
  2. Oct 28, 2014 at 9:00 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    We did a wet compression test and all cylinders checked out ok.
  3. Oct 28, 2014 at 10:36 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I'll be following your thread with interest. :)
    LCE makes good products, so it will be fun to see the results.
    Greg
  4. Oct 30, 2014 at 3:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sub'd Good luck
  5. Oct 30, 2014 at 4:21 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Parts are showing up tomm except for the Doug Thorley header..... I guess starting on Thursday instead of Monday while I wait for parts.......
  6. Oct 30, 2014 at 4:22 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    u have a dyno lined up?
  7. Oct 30, 2014 at 8:47 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    I wish but no.
    LCE told me 15+ hp and a better low end torque. I live in San Diego so my "Dyno" will be climbing the mountains above Riverside to get to the high desert to go off-roading. It's a 3000ft elevation change that makes my little truck work.
  8. Nov 15, 2014 at 8:45 PM
    bsprelude
    bsprelude Member
    Paul
    Phoenix
    03 Tacoma Prerunner Regular Cab Black
    K&N Intake Modified Stock Exhaust Bilstein Suspension on all 4 Corners Tradesman toolbox Husky Molded Floor Mats Bushwacker Bed Caps PIAA Driving Lights Goodyear MTR's Eagle Alloy Wheels McGard Spline Drive Lugs Optima Yellow Top Grillcraft Mesh Grill Toyota Bed Extender
    Any progress on the install?
  9. Nov 16, 2014 at 4:12 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    It's coming along. The LCE Stage 1 head requires a lot to be swapped from old cylinder head. Also needed a machine shop to shim can and adjust valve train.
    Overall, I feel like I should have just rebuilt my stock cylinder head or dropped in a whole new rebuilt motor. I probably have about $2000 into this cylinder head swap in parts and that's the price of a rebuilt 3RZ anyway.
  10. Nov 16, 2014 at 4:15 PM
    bsprelude
    bsprelude Member
    Paul
    Phoenix
    Thanks for the update!!! The 3rz massaged by LCE is supposed to be a great powerplant! I hope it lives up t the hype!!!
  11. Nov 16, 2014 at 10:49 PM
    tooter
    Greg
    Los Angeles
    Was there a reason you got the DT header and not the LCE? Long tubes make more low end torque than short tubes. I ran an LCE long tube header on my 2RZ for a decade with no other mods...
    e52895f6-6db6-4a5b-befa-9b228b5797f0_zps_84bb15420a962ad56595e531217a67154b48958a.jpg
    ...and it really increased the low end pull. It also eliminates the small stock down tube, because the four separate runners go all the way down to where the collector bolts directly onto the cat flange.
    Greg
  12. Nov 16, 2014 at 10:59 PM
    bsprelude
    bsprelude Member
    Paul
    Phoenix
    Tooter, I also have the Doug Thorley. The LCE header is only a bolt on if you have 1 cat. I have a 2003 3RZ with 2 cats. DT header is bolt on whereas the LCE is not
  13. Nov 16, 2014 at 11:13 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    I agree with you 100%. However, I live in Commiefornia and had to run the Doug Thorley to be smog legal. The LCE is only smog legal until 99' and I have a 2000.
    I'm running dual cats and EGR too.
  14. Nov 23, 2014 at 10:51 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    So I finally got it all back together.
    I found out that the LCE head Stage 1 is a stock Toyota head with their street performer valve train. The Stage 1 cam is not noticeable at idle.
    The Doug Thorley shorty header is pretty quiet as well.
    I also added a K&N cold air intake that seemed to wake the motor up a bit. Yesterday my buddy made a custom bracket to secure the intake. I have no body mounts at all on the front of my truck. It's all tubing so anytime I want to change anything brackets have to be made.
    The last thing I need to replace is the throttle body. We cleaned it when rebuilding everything but it idles really high even after adjustment. I will idle at like 3000rpm until I blip the throttle to get it to go back down.
    It's almost ready to pass smog.
  15. Nov 23, 2014 at 10:53 AM
    bsprelude
    bsprelude Member
    Paul
    Phoenix
    Thanks for the update! Have you taken it for a test drive? How does it feel?
  16. Nov 23, 2014 at 11:52 AM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    I have taken it for short test drive and you can feel a bit more low end torque than before. Overall, it's more smooth than before in the whole rpm band. Having all four cylinders making power instead of three is nice. Haha
  17. Nov 23, 2014 at 12:08 PM
    bsprelude
    bsprelude Member
    Paul
    Phoenix
    That's great to hear!
    I have a 2003 3rz with the Doug Thorley header and a K&N intake. I'm planning on doing the LCE Supercharger with the 4PSI pulley. After that I wanted to do the Stage 1 Head and LCE Big Bore Throttle Body
  18. Nov 23, 2014 at 12:16 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    I was thinking about the big bore throttle body as well as the intake manifold for my next upgrade.
    That supercharger sounds legit and the 4psi version is smog legal.
    If your cylinder head is fine don't buy the LCE Stage 1 head. It's literally a stock Toyota head with no porting. Just buy the $250 valve train and have your head cleaned up. The Stage 2 head is ported and the cam is more aggressive but they aren't smog legal.
  19. Nov 23, 2014 at 7:58 PM
    tooter
    Greg
    Los Angeles
    I hear ya. Mine was a '96 and smogged with no problems, and I'll be taking the LCE header off my 2012 when smog time comes. :rolleyes:
    Greg
  20. Nov 26, 2014 at 10:24 AM
    TacoBow
    TacoBow Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    Opinions on which one made the most noticeable low end improvement?
