2.7L Manual Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sdcanoe, Aug 13, 2013.
  1. Aug 13, 2013 at 7:01 AM
    sdcanoe
    sdcanoe [OP] New Member
    Halifax
    09 4x4 SR5 4cyl
    I am hoping someone can help me out. I am confused about the location of the fill/drain plugs on the 5 speed manual transmission in my 2009 2.7L Access Cab 4x4. The information I have read indicates the plugs are on the drivers side but mine appear to be on the passengers side. I can see a plug near the bottom that takes a 24mm socket and on the same side, up high there looks like a plug that should take a hex key??
    The only plug I see on the drivers side is a 24mm in the middle of the transmission. The drain plug seems obvious but I am unsure of the fill plug. If someone can confirm the location of the fill/drain plugs on my truck, it will be greatly appreciated. Thank you.
  2. Aug 13, 2013 at 7:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    The 24mm plug in the middle on the driver's side is your fill.
  3. Aug 13, 2013 at 12:07 PM
    sdcanoe
    Halifax
    09 4x4 SR5 4cyl
    BamaToy,
    Thank you, that is good news. The other plug did not look fun to get at.
