2.7L Modifications
Discussion in '1st Gen. Tacomas (1995-2004)' started by Romba, Jul 26, 2020.
  1. Jul 26, 2020 at 7:37 PM
    Romba
    Romba [OP] Member
    Isaiah
    2002 Tacoma 2.7l extended cab
    Whats up TacoGang. Just had a few questions about my truck. I have a 2002 2.7l extended cab tacoma, with everything stock. Truck is great, but is starting to have some problems. Cracked exhaust manifold, rusted out exhaust, but my biggest problem was uphill power; the truck loses power instantly when climbing uphills. It is my little project truck, but i was looking at putting an air intake, headers, and possibly a magnaflow exhaust. Any tips or suggestions about what i should do or what mods fit best together would be great. Thanks
  2. Jul 26, 2020 at 7:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Common issue with those exhaust manifolds cracking.
    Get it fixed.
    After that, no addons will make a difference like a supercharger will so go with that, or just swap gears.
    Especially doesn't help having an automatic; I hear/read better results with having a manual.
    Abeyancer and Ritchie like this.
  3. Jul 26, 2020 at 7:59 PM
    Romba
    Romba [OP] Member
    Isaiah
  4. Jul 26, 2020 at 8:00 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    I ran an eBay manifold on mine was like 60$. Fit great. Never any issues
  5. Jul 26, 2020 at 8:04 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Make sure its running right before you start chasing power - no check engine light, valves adjusted properly, no cracks in the exhaust, etc. I recently fixed a burnt valve in mine and its noticeably better at pulling hills now, which makes a lot of sense.
    davidstacoma and cruiserguy like this.
  6. Jul 26, 2020 at 8:20 PM
    Romba
    Romba [OP] Member
    Isaiah
    It was in the mechanic about 4 months ago, so I may need to check it again. No check engine lights are on though. Fixed the cats, o2 sensors, fuel sensor, etc. The exhaust is the original one so it was cracked. He did weld it, but it may be to far rusted to have been able to fix completely. Looking at a Magnaflow exhaust, but if you know any good exhausts that still keep the noise down please let me know
  7. Jul 27, 2020 at 12:05 AM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    love my dynomax ultra flo. No drone highway driving but you can hear the truck more then stock if you like that. Has some raspiness to it
  8. Jul 27, 2020 at 6:56 PM
    Romba
    Romba [OP] Member
    Isaiah
    Looked into these. Do you have the exhaust system, or just the muffler?
  9. Jul 27, 2020 at 8:09 PM
    SkunkMan17
    Owen
    Montana
    1997 Tacoma RC 4x4
    I have just the muffler. I can do a sound clip if you want but it’s not gonna do it justice for how it really sounds. I have a 2.5 one with a 2.5inch pipe going back to my tip
  10. Jul 27, 2020 at 8:40 PM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    This is my set up:
    It is on a slightly tuned 3RZ
    https://www.lceperformance.com/LCE-Street-Header-Kit-3RZ-1995-2004-Single-Cat-O-p/1041054.htm
    https://www.lceperformance.com/Catalytic-Converter-49-State-Smog-Legal-3RZ-5VZ-p/1043015.htm
    https://www.lceperformance.com/Pro-Flow-Exhaust-System-3RZ-Tacoma-1995-2004-p/1042023.htm
    The exhaust note is a little bit louder than I wanted it to be but overall its not bad, Pretty satisfied with the set up and took about 2.5 hours to install including the headers and a couple of breaks in between.
    The below video will give you an idea of the system and sound
    https://youtu.be/U2eJhYJ4lhg
    cruiserguy likes this.
  11. Jul 27, 2020 at 10:01 PM
    crazytacoman
    crazytacoman Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    I'm in the same boat as you OP. I also have a cracked exhaust manifold, and some valves that might need an adjustment.
  12. Jul 28, 2020 at 11:54 AM
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    Lce still sell the supercharger for the 2.7 but you will get more power from a turbo, these trucks can do a lot from a properly set up turbo. LCE sells a low boost and a high boost turbo kit. Lots of info for turboing and large power on customtacos.
    Snowman, cruiserguy and Taco critter like this.
  13. Jul 28, 2020 at 6:02 PM
    Romba
    Romba [OP] Member
    Isaiah
    Ive heard mixed reviews about turbo vs supercharged. In a way, I was leaning more towards a supercharge only because my truck will get power at any RPM, which would be nicer for an older manual instead of waiting for the turbo to spool up. Turbo has been popping up, so I will need to do my research on that. Is turbo cheaper? More or less maintenance?
  14. Jul 28, 2020 at 6:04 PM
    Romba
    Romba [OP] Member
    Isaiah
    What route are you looking at in taking choosing parts? Are you going to add performance mods, or buy/fix your old manifold?
  15. Jul 30, 2020 at 12:25 AM
    TacoBike
    Mason
    Turbo would probably be more maintenance though can be around the same, research will tell you the best answer between the two. Either is a good choice.
  16. Jul 30, 2020 at 12:59 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Intakes and exhausts make noise, not power.
    Throw a turbo or SC at it. My little 22R-TE 4Runner was a fun little truck.
    Or just get a v6 (although those aren't exactly power houses either, lol)
  17. Aug 3, 2020 at 11:14 AM
    crazytacoman
    Tacoman
    Taco World
    Color Wheels
    I'm planning on finding all leak points, taking apart the manifold, and taking it to a muffler shop (or somewhere else that's reasonably priced) so that they can close weld the leak points
  18. Aug 4, 2020 at 12:21 PM
    Dan496
    Dan496 meme expert
    New Jersey
    1997 3.4 4x4 LX
    I put a stainless steel Ebay Header. Ive had it for 5 years now works great.
    Taco critter likes this.
  19. Aug 6, 2020 at 3:15 PM
    Romba
    Romba [OP] Member
    Isaiah
    Your right, they do make more noise than factory parts. Alone, I would not just add an intake or an exhaust. Together, they do make a differenc, but I am definitely saving up to supercharge the truck. I think the truck can really show a difference then. LOL, that would honestly be the only complaint about my little truck; i wish it wouldve been the V6 instead of the 4 cylinder
  20. Aug 6, 2020 at 3:18 PM
    Romba
    Romba [OP] Member
    Isaiah
    That also would not be a bad route to take. I bought my truck from my uncle out of Denver, CO so idk how much their weather affected the truck. Here in NM, we have a lot of dry weather, so when I brought it back the truck already had a lot of rust on it. My manifold may be to far gone for them to weld
    crazytacoman[QUOTED] likes this.
