2.7L MPG
Discussion in '4 Cylinder' started by dustinclm, Oct 12, 2010.
  1. Apr 18, 2012 at 12:05 AM
    #181
    anhnoff
    anhnoff Active Member
    SR5
    I am doing exactly what you stated. I run my tank till the light comes on though, Can you explain to me how 17.37 is over 18 mpg?
  2. Apr 18, 2012 at 6:01 AM
    #182
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    He's really saying that your odometer is slightly off.
    Your odometer measures by taking the tire rotations against a known tire size to get miles. If you have tires that are 4% bigger, you'll have gone 4% more miles than the odometer will say.
    Therefore, you really burned a gallon per 18 miles, but your odometer is only reading as though you went 17.37.
    Therefore, if you have oversized tires, calculate your mileage and then multiply it by the difference.
    Edit: But you're right. If 235/70R15 is stock for the 5-lug, then yeah, no adjustment is necessary and you really got 17.37.
  3. Apr 18, 2012 at 11:43 AM
    #183
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    August 2009, got my 2006 2.7 access cab automatic 2wd SR5 with 41k miles on the odo. Opened a fuelly account around May 2010, average across all fuel-ups is 23.6mpg IIRC. I drive like a sissy most of the time, nice and easy on the throttle and brakes, coasting to red lights from a distance, etc. Only a few mods: aFe pro dry drop-in air filter, magnetic drain plug and rare earth magnets stuck on the oil filter, slightly elevated tire pressures when the roads are dry, plus a friction-reducing additive in the differential gear oil (FYI only these last two are aimed at fuel economy). Has stock 215/75R15 tires, will go up slightly to 235/75R15 in a couple years when the stocks wear out. I know bigger tires will hurt my fuel economy slightly but this is literally my *only* cosmetic indulgence... the only thing my truck needs in the looks dept IMHO is slightly larger tires because the stock tires are like rollerskate wheels in those big open wells, LOL.
  4. Apr 18, 2012 at 2:16 PM
    #184
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Warm weather, and different fuel blend in warm months. Also, at 5,900 you are just getting broken in.
  5. Apr 18, 2012 at 5:58 PM
    #185
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Stock for 5 lug is 215/70r15
    235 is oversize, whether it came from the dealer with them or not. Dealers play all kinds of games to make vehicles more attractive... we had one that was putting 20" rims on 2003 Tundras.
  6. Apr 19, 2012 at 6:04 AM
    #186
    Stephup
    Stephup Member
    Borger, Tx
    06 Toyota Tacoma
    Cool air intake, Borla 3" exhaust
    I have a access cab 4cyc 4wd, the only thing I,ve done to it is, a cool air in take with a k&N air cleaner, and 3" magna flow exhuast, other then that it stock. I'm getting between 17 and 23 just depending on how I drive and the wind. When I'm asked what kind of milage it gets I say 20. thats most generally real close. So your milage dosen't sound to bad to me, If anything at all you might try plugs and gap them just alittle wider then normal, not much though, that would make the plug run hotter and maybe give you a more complete fuel burn, But ,,,be careful and dont go to much wider.
  7. Apr 20, 2012 at 4:13 AM
    #187
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Hopefully when it's broken in (when's that?) my mileage will go up at least to 22mpg........ hoping. Still love this truck!
  8. Apr 21, 2012 at 9:04 PM
    #188
    Deeks
    Deeks New Member
    Dustin
    06 Tacoma Regular Cab 4x2 2.7L AT
    K&N air filter
    I was getting 22MPG combined before I made two simple changes:
    1. Changed my driving style: Specifically, keep my RPMs at 2000 or less (this works out to be about 70MPH), accelerate slowly (especially in traffic to reduce start/stops), and generally maintain a constant speed as you drive on the highway.
    This change increased my fuel economy to 24MPG.
    2. I inflated my tires to 40PSI.
    This change got me to 24.5-26MPG consistently.
  9. Apr 21, 2012 at 9:06 PM
    #189
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I get 24 with 20-24 psi in my tires....
    With that being said, you willing to spend hundreds of dollars for improper tire wear to save ~1mpg? Have you tried to do the chalk line test with 40 psi to ensure you are running the tread flat with the road?
  10. Apr 21, 2012 at 10:39 PM
    #190
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    20psi is way underinflated, you will get more uneven wear at that pressure.
    I run 44 psi and have for decades and haven't seen the uneven wear that people always warn about.
  11. Apr 21, 2012 at 10:41 PM
    #191
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I get about 19-20 mpg with plate bumper, winch, sliders, and roof rack, 3" lift, and 33s.
  12. Apr 25, 2012 at 12:39 PM
    #192
    anhnoff
    SR5
    Thanks for the explanation brotha! :)
  13. Apr 26, 2012 at 6:02 AM
    #193
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    Well I'm getting about 21.5 mpg and my speedo is off bu 3 mph. It shows 40 I'm going 37 per gps and speed gun. Stock tires and all. No mods. So is my mileage off too. I checked a short distance with gps but no more than a couple miles. maybe 10 miles and it seems accurate.
    It just sort of bugs me.
  14. Apr 26, 2012 at 8:07 AM
    #194
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    keeps you from getting a ticket since youre going slower than it says lol
    but seriously unless a speedo is a certified police unit they are gonna be off slightly
  15. Apr 26, 2012 at 9:42 AM
    #195
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    I've consistently increased mine to 23-24. I did the secondary air filter mod and picked up 2-3 mpg.
  16. Apr 26, 2012 at 12:39 PM
    #196
    rbishopp
    Rich
    Webster, NY
    Yeah. Po Po friend of mine told me how much it was off.
    Just annoying.
  17. Apr 26, 2012 at 3:16 PM
    #197
    tlh178
    tlh178 Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    on my last fill up, i jumped up to 23.4. i have 2300 miles on my truck. engine is getting broke in finally. plus i used a lite foot, not my usual driving habit.
  18. Apr 26, 2012 at 5:07 PM
    #198
    Rich91710
    Rich
    Los Angeles
    08 Base
    My speedo is also off by about 3mph at 70.
    Odd because it seems to be consistent (meaning it could be corrected by shifting the needle) rather than a percentage error... I mean it's 3mph off at 70 or 35.
    I checked my odo against both my GPS and mile markers on a roadtrip and it seemed that I was only off by around 0.2 over the 70 miles that I tracked it, so that's about as accurate as it can get and still allow for tire wear.
  19. Apr 28, 2012 at 12:32 PM
    #199
    shredgar1
    shredgar1 Well-Known Member
    So Cal.
    2011 PreRunner SR5 AC
    so i decided recently to try out the lead foot delete mod :p and when i would drive like i didnt care, id usually get around 310 to the tank, but after driving slower and more effeciently i got 350 to the tank :) which is a +2mpg for me. truck only has 7k miles on it, i think the tacos finally breakin in.
  20. May 10, 2012 at 5:29 AM
    #200
    wags
    Had my best yet mpg: 23.6mpg. It was all highway (70mph) driving. Mileage now is 6950. Must be breking in and summer blend of fuel. Whew, finally cracking 23pg.
