2.7L MPG
Discussion in '4 Cylinder' started by dustinclm, Oct 12, 2010.
  1. Nov 28, 2015 at 4:01 PM
    #481
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    2003 4X4 Manual Xtra Cab Goodyear Duratracs (very heavy but stock size) I do about 50% City 50% Highways and get about 18-20MPG
  2. Nov 30, 2015 at 8:06 PM
    #482
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    I'm happy to update I sold my cap and installed a 3" lift. With that said I'm getting way more mpg then before. I literally had to get gas at 369miles a tank. I took a recent trip and got into 400 and my light still wasn't even on yet, and I was sitting in some crazy ass traffic at a few points. I ended up getting gas because it was cheap. But I'll update when I get a good full tank.
  3. Dec 1, 2015 at 3:15 AM
    #483
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    What tire size are you running with that 3 inch lift?
  4. Dec 1, 2015 at 12:48 PM
    #484
    yesmar
    Ramsey
    Harrisburg, PA
    A couple cars
    still stock, baby steps
  5. Dec 1, 2015 at 12:58 PM
    #485
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I bumped my tires to 34 PSI.
    Gained MPGs. Only ran one tank through it so far, but my previous tanks are usually 17.5-18.2 or thereabouts, and I was just shy of 19.25 MPG with the air pressure increase.
    We'll see on the next couple tanks.
  6. Dec 1, 2015 at 12:59 PM
    #486
    Lt_Dan
    Daniel
    Cincinnati OH
    Got you. Did you notice an mpg change or power loss just with the lift? I'm trying to figure out if those things come with the lift or bigger tires.
  7. Dec 1, 2015 at 1:06 PM
    #487
    yesmar
    Ramsey
    Harrisburg, PA
    A couple cars
    no man, no changes. tires will deff change the power feel. im hoping not too much. ill probly go with the popular 265/75's but ive been thinking a lot about the tall skinny tires may be better at least fuel wise.
    but just the lift, truck feels the same power wise
    Lt_Dan[QUOTED] likes this.
  8. Dec 1, 2015 at 3:14 PM
    #488
    Lt_Dan
    Daniel
    Cincinnati OH
    Thanks for your reply. I have a 3 inch lift and 265/75r16 tires, I don't know how the truck would feel with smaller tires since I bought the truck with this set up already on it.
  9. Dec 1, 2015 at 3:40 PM
    #489
    GrnXnham
    GrnXnham Member
    Tacoma, WA
    2015 PreRunner Auto 4-Banger
    Hello, new here
    Just got a new 2015 PreRunner auto with the 4 banger.
    1st tank of gas was 21 mpg in mixed driving. I'm happy with that because the window sticker said 19-24.
    The 2012 Nissan Frontier that this is replacing (wrecked) got 20mpg and it was the 4 cylinder with the manual tranny.
  10. Dec 1, 2015 at 3:48 PM
    #490
    T4RFTMFW
    Pay no attention to the window sticker.
    All 2.7 trucks and all 4.0 trucks have the same window sticker ratings (4x2 and 4x4 are different, only).
    Your mileage is on par with what I got, I got a bit better actually but you don't live where I do or use my local gas and roadways.
    Welcome to the club.
  11. Dec 1, 2015 at 4:22 PM
    #491
    yesmar
    Ramsey
    Harrisburg, PA
    A couple cars
    what are you getting mpg wise
  12. Dec 1, 2015 at 4:48 PM
    #492
    Lt_Dan
    Daniel
    Cincinnati OH
    Well, I just started tracking my mpg using an android app, only one tank tracked, 18.8mpg, I have pretty a pretty aggressive thread on the my tires.
  13. Dec 1, 2015 at 5:12 PM
    #493
    yesmar
    Ramsey
    Harrisburg, PA
    A couple cars
    Take in account you may actually be traveling more then 1mile when your truck says it's been 1mile. if your odometer hasent been calibrated to the larger diameter tires then what you are calculating is incorrect.
  14. Dec 1, 2015 at 5:31 PM
    #494
    Lt_Dan
    Daniel
    Cincinnati OH
    I thought about that already, somehow my odometer is spot on, have checked it several times with a GPS. My speedometer is slower, which makes no sense with bigger tires, but my odometer is spot on the for some reason, really weird.
  15. Dec 3, 2015 at 8:18 AM
    #495
    thatprerunner
    thatprerunner Wyatt Reese
    Wyatt
    Hull, Georgia
    I have a 2000 Prerunner Ext Cab auto tranny, stock ratio was 4:10 with 225 75 15, i was getting about 16 in the city, and about 23 highway, then i went to 16 inch wheels with 265 75 16 the bigger tires dropped the final ratio to about a 3:07. I'm getting about 13 mpg in the city and 17-20 on the highway. Not using a large lift, just coil spacers to level the front end, just about 2 inches.
  16. Dec 14, 2015 at 1:58 PM
    #496
    broken1812
    broken1812 Member
    I bought a new 2015 Prerunner Double Cab 2.7L 4 cylinder 4x2 last January and I am kind of concerned about the gas mileage.
    Doing the math it looks like I'm only getting around 16-17 MPG and I was wondering if thats normal or if I should get it looked at.
    Once I fill up it takes about 330 miles for my empty light to come on. I'm not sure how much gas is actually left in the tank once the light comes on, so maybe its fine.
    I drive about 50/50 city and highway.
    Anyone experiencing the same thing? Should I have it looked at?
  17. Dec 14, 2015 at 6:13 PM
    #497
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    Really depends on your driving style, where you live and modifications. I have the same truck. I live in a very flat rural area with 55 being the fastest speed limit around. I'm at sea level, I accelerate moderately and coast a bit before stops, I look ahead and adjust the throttle to what I see coming. I have taken a few highway(interstate trips) and some Pennsylvania/Western MD mountains.
    With those circumstances, I have averaged 23.2MPG over the last 15,000 miles.
  18. Dec 14, 2015 at 6:14 PM
    #498
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Are you dividing your miles traveled by what you pump into the tank? Doesn't matter what's left in the tank but most find there are 3-4 gallons in the tank when the light comes on.
  19. Dec 23, 2015 at 11:04 AM
    #499
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I understand these trucks were designed with a slow speedometer, but an accurate odometer. So with factory-size tires, the odometer will be spot on but the speedometer will read 1-2 mph slower than actual speed. This was done in anticipation of the owners upgrading to larger tires, which is extremely common. So, if someone puts larger tires on their otherwise stock Tacoma, and depending on the exact size of the larger tires, the speedometer may be closer to accurate but the odometer will record fewer miles because the truck will travel farther on fewer tire rotations (larger tire). Your experience with larger tires does seem confusing and contradictory to my understanding as well.
  20. Dec 23, 2015 at 11:06 AM
    #500
    Lt_Dan
    Daniel
    Cincinnati OH
    Finally someone who understands. Thanks.
