2.7L MPG
Discussion in '4 Cylinder' started by dustinclm, Oct 12, 2010.
  1. Dec 23, 2015 at 7:37 PM
    #501
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    With stock tires the speedometer reads a little high, not a little low. Speedometer says 70 actual speed is 67-68.
    Not in anticipation that you will put bigger tires on, in anticipation that you will get speeding tickets if the speedometer is reading low.
  2. Dec 24, 2015 at 9:29 AM
    #502
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Still a good idea for everyone to double-check them. Some drivetrain combos are off by a lot. With factory 245-75/R16 size tires, my odometer would read 4 miles too many per 100 miles, and to go 70 mph, the needle would have to sit on 77 mph. I swapped the oem 29-tooth speedometer gear for a 30-tooth, which got the odometer within 1% where it belonged; however it still needs the needle about 74 mph to go 70 mph actual. I care about the odometer more so I can live with it.
    The irony? The thing I hated the most about my first Honda was how far off its speedo was. I figured a Toyota wouldn't have that problem since the other Toyotas in the family (including my last Tacoma) are within 1-2 mph. HA! This truck was even less accurate. I'll always bring a GPS for my test drives from now on.
    Lt_Dan likes this.
  3. Jan 7, 2016 at 8:28 AM
    #503
    96coma
    96coma Active Member
    Josh
    New Hampshire
    96 5sp tacoma 4x4
    to much to post lol
    96 4x4 ext cab with the 2.7, ive been getting horrible gas mileage as well haven't calculated it yet but on average i used to get around 330ish to a tank, now im getting alittle more than 200ish, truck has 256,000 miles on er but runs strong, compression isnt bad for the mileage bout 124-126 on each cylinder, maybe its the winter gas up here, mostly drive highway 60 miles to and from work everyday avg 65-75 mph try to stay around 2200rpm cruising in 5th until i hit steeper inclines gotta drop it to 4th (dreaded 3.58 gears), truck has some mods done to it, lifted rear bout an inch, 31/10.5/15 firestone detination at's, aem short ram air intake, trail-gear longtube header, custom 2 1/4 exhaust, i know i need to regear idk if that has anything to do with it ive had theses mods on the truck for years and im just recently noticing the changes this year
  4. Jan 19, 2016 at 7:35 AM
    #504
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    This may be a dumb question but I am always wondering if I convert my L/100km correctly to get mpg.
    Do you guys work with U.S Gal, wich is 3.78L (seems obvious), with U.S Dry Gal wich is 4.4L or with Imp. Gal, wich is 4.54L?
    Asking this because when I compare my consumption, I am getting closer to some of you when using Imp mesurement.
    I know the 2.7 is not that much fuel efficient but when I read that some 4.0 get 22.5 mpg, wich is the best I get off my 2.7 in near perfect driving conditions, I worry about my converting method.
    Thanks in advance!
  5. Jan 19, 2016 at 11:23 PM
    #505
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Just thought I'd chime in... I don't really get involved in mpg related threads well cause I don't really care but I feel this information can be useful so here goes.
    09 2.7 5spd AC, plate bumper front and rear, full set of skids, 4 16x8 steelies, 4 315/75R16 bfg ko2 e, 4.88 gears, tool box full of tools bed bars close to 50/50 city hwy
    I've gone through 3/4 of a tank I've traveled 249 miles. Much better than anticipated the gears are making a huge difference imo
  6. Jan 20, 2016 at 4:29 AM
    #506
    Kemosabe
    Louis
    Didn't you said Mpg was stupid?...:boink:
    Jk
    I am following your build thread a bit and I was wondering if you were cheking you mpg before regear and adding your new bigger tire? Was your Miles per tank stable enough to make an average?
  7. Jan 20, 2016 at 7:22 AM
    #507
    TYetti
    Mat
    Lol well they are but it's still a factor when trip planning, before the tires ad regear I was around 20-21ish after tires it dropped to like 16 lol I'm still collecting data to come up with a concrete avg after the regear so far I'm happy with the results though. I'm expecting it to be similar to other 2.7's on 35's North is my favorite example pre super charger
    Kemosabe[QUOTED] likes this.
  8. Jan 21, 2016 at 4:50 PM
    #508
    TYetti
    Mat
    I'm just gonna leave this here, keep in mind it's in km and this is indicated not actual, actual is more because I'm running 35's
    Kemosabe likes this.
  9. Jan 21, 2016 at 5:07 PM
    #509
    Bennoclarke
    Bennoclarke Well-Known Member
    Ben
    Stockbridge, GA
    2007 Tacoma 2.7 Regular Cab
    Ahem.....
    Mush Mouse and Kemosabe like this.
  10. Jan 21, 2016 at 5:23 PM
    #510
    Kemosabe
    Louis
    Not so bad! I am doing less than that because of winter and still running stock tire size...
  11. Jan 21, 2016 at 5:27 PM
    #511
    Lt_Dan
    Lt_Dan Well-Known Member
    Daniel
    Cincinnati OH
    2017 TRD OR 4x4 DCSB A/T Super White
    What app are you using?
  12. Jan 21, 2016 at 6:54 PM
    #512
    Bennoclarke
    Ben
    Stockbridge, GA
    Gas Tracker +
    Lt_Dan[QUOTED] likes this.
  13. Feb 1, 2016 at 4:41 PM
    #513
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    I'll Leave this here. 28 mpg. 4 banger, 5spd, 4x4 general grabber at2s.NCM_0160.jpgNCM_0161.jpg
  14. Feb 1, 2016 at 5:14 PM
    #514
    fishbill
    fishbill Member
    Bill
    Virginia
    03' 2.7L 4wd
    03' stock suspension,1 size bigger than stock tires. Average 18-20 in town. 20-24 on highway. Best ive ever seen I estimated 30 mpg driving down to the outer banks going easy, averaging 55-65 mph.
  15. Feb 1, 2016 at 5:16 PM
    #515
    Taco302
    Taco302 Well-Known Member
    Greenbow, Alabama
    2003 2.7L 5 spd 4x4 xtracab
    All "winter" on the gulf coast I got 21-21.5 mpg. Before the last fill-up I filled the tires to the recommended level (listed inside driver door jamb). I was low front and back by 4-6 psi. Today I filled up and calculated gas mileage: 22 mpg :)
    Note: I quoted myself from last summer.
  16. Feb 1, 2016 at 5:53 PM
    #516
    Kemosabe
    Louis
    28 is awesome! I'll never get that for sure... What is your secret??
  17. Feb 1, 2016 at 6:04 PM
    #517
    doc1187
    doc1187 Well-Known Member
    new york
    sr5 4x4
    2010 access cab 2.7L 4x4 stock tires 17 to 18 mpg around town 20 to 22 mpg highway 87 octane.
  18. Feb 1, 2016 at 6:17 PM
    #518
    Kemosabe
    Louis
    I have the same truck but with 1.5" lift in front and 2 in back. Doing pretty the same mpg as you. Feel much better thab seeing people having 28 haha
    doc1187[QUOTED] likes this.
  19. Feb 1, 2016 at 6:50 PM
    #519
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    IT helps to be a 2ft above sea level, a max speed limit of 55 and flat land except for the bridges.
  20. Feb 2, 2016 at 8:52 AM
    #520
    Lt_Dan
    Daniel
    Cincinnati OH
    What year is your truck? Is it an access cab or a regular cab?
