2.7L MPG
Discussion in '4 Cylinder' started by dustinclm, Oct 12, 2010.
  1. Mar 25, 2017 at 11:32 PM
    #601
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I have a 2.7 4X4 and the best I ever gotten was about 23mpg. I average about 19. When it comes to MPG I really don't care because I own the vehicle I own and I have to do what I have, or want, to do and need to go or want to go where I want. There has never been an oil or gas shortage so I don't pay any attention to it. I just "afford" it because it's necessary. It's no different than a house payment, rent or paying for underwear.
  2. Mar 31, 2017 at 7:06 PM
    #602
    McNice
    McNice Well-Known Member
    Ken
    2006 Access Cab 5sp... the small motor.
    Update?
  3. Apr 6, 2017 at 3:28 PM
    #603
    mako fisher
    mako fisher Well-Known Member
    Michael
    Cape Fear
    2008 Impulse Red 2.7L MT RC 4X4
    Int. wipers, fog lights, cruise control
    Got my first good mpg read on my 08 MT RC 4x4 which I bought a couple weeks ago. 235 miles on 10 gallons in 50/50 mixed conditions... used the yellow light as my starting and stopping points. Better than I was expecting considering EPA rating is 19 for overall. Plus, I tend to drive kinda fast.
    Key to saving gas IMO is driving in a fashion which requires as little braking as possible and I dont downshift to a gear unless Im going to use it. My car which I still drive went 135K on factory brakes and original clutch is still going with 140K.
    LocoLocal and Kemosabe like this.
  4. Apr 10, 2017 at 5:46 PM
    #604
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    The secret is temperature... wasn't able to get "decent" mpg for a while now. Had my winter tires on and they are heavier than my summer set and I thought I would do better with the summer set on but no... and then this week end and today the weather was nice and hot and guess what? My mpg has improved! Will be able to give numbers tomorrow or wednesday when I fuel up! For now I average 18.5 (whole winter with cold starts, winter tires and fun in the snow). I think I'll hot close to 21 for this tank
  5. Apr 13, 2017 at 10:24 PM
    #605
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    2013 Tacoma AC 4x4 M/T 2.7L
    Given: Actual speed is the same
    Questions:
    1. Based on the "given", is it true that changing tires from 245/75/16 to 265/75/16 will give me a slightly lower RPM reading?
    2. Higher RPM (on the same gear) = higher gas consumption, right?
    I'll gladly accept any corrections and clarifications. Thanks.
  6. Apr 14, 2017 at 7:04 AM
    #606
    JKesler
    JKesler Member
    2012 5 speed 4x4 access cab
    265/75 r16 Dynapros
    I average 19+ regular city driving and commuting. Road trips are low 20s.
    265/75 and 2 inch lift.
    I've seriously only seen less than .5 mpg difference from stock.
    It's 2-4 mpg better than my previous Rodeo 4x4, so I'm delighted.
  7. Apr 14, 2017 at 7:14 AM
    #607
    electricmarauder
    electricmarauder Well-Known Member
    2014 | Tacoma | RC | White | 4×4 | 5-speed
    I'll try to answer this but anyone else feel free to correct me.
    1. If the tire diameter is the same (and in this case it looks like they are), they should rotate the same speed at any given RPM. However, weight should be taken into account. The 265s will likely weigh more and that additional load would require more power/higher revs to counteract.
    2. Yes.
  8. Apr 14, 2017 at 8:47 AM
    #608
    mako fisher
    Michael
    Cape Fear
  9. Apr 14, 2017 at 9:01 AM
    #609
    mako fisher
    Michael
    Cape Fear
    Results are in on my 2nd measurement. 23 mpg ... identical to first run, conditions similar with maybe a little higher percentage of driving in traffic.
  10. Apr 14, 2017 at 10:41 AM
    #610
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    265/75R16s are a bit taller than 245/75R16s. Therefore, the engine will be turning at lower RPMs at a given speed. The additional weight will have no effect on the engine speed. Any compensation for the extra weight would show up in fuel consumption.
  11. Apr 14, 2017 at 2:08 PM
    #611
    electricmarauder
    You're right about the diameter, I didn't realize there would be a difference.
  12. Apr 14, 2017 at 4:36 PM
    #612
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    So, it looks like RPM is directly connected to tire revolutions. Am I over-thinking it if I want to factor in the RPM while the engine is on idle?
    I just recently did the tire change. I'm at 265/75/16 now. Going to work this morning, I measured the total distance from parking slot to parking slot.
    GPS: 27.1 miles
    Trip meter (in truck): 26.1 miles
    Approx. 3.8% difference
    First time I filled my tank yesterday having the new tires installed. I'll report back with my fuel consumption on the next fill.
  13. Apr 14, 2017 at 9:17 PM
    #613
    PintSize
    PintSize Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
  14. Apr 17, 2017 at 6:23 PM
    #614
    azreb
    azreb Geezer
    TN
    If nothing in the transmission (auto) or clutch (in manual transmission) is slipping, the engine RPM is directly related to the tire revolutions. It could be an interesting exercise in math to calculate the speed at a given RPM, knowing the transmission and differential gear ratios and tire diameter. I recall doing that back in the dark ages before tachometers were common.
    I don't understand your second question. I suspect you are overthinking it.
  15. Jun 21, 2017 at 10:45 AM
    #615
    SOUPBOY
    SOUPBOY (bochok)
    Soupboy
    California
    I've finally had a decent test on MPG where 95% of the tank was used for home-work-home driving.
    • Distance from home to work (relatively flat 100% of the distance): 27 miles (6 city, 21 highway)
    • Tires: Cooper ST Maxx 265/75/16
    • PSI: Rear: 26, Front: 32 (went with chalk test, about half an inch of chalk left at the edges of the treads on all tires)
    • Cruising speed: 55 mph (RPM at about 2,000)
    • RPM range during acceleration: 1,200-1,600
    • MPG (odometer): 22.184 (+3.831417624521073% for actual GPS distance = 23.033)
  16. Jul 5, 2017 at 6:07 PM
    #616
    saratogajoe
    saratogajoe Well-Known Member
    2011 base 2wd … my last trip 28.3
  17. Jul 5, 2017 at 6:10 PM
    #617
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    Still 16, but I live in Austin.
  18. Jul 13, 2017 at 1:49 PM
    #618
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    Good work, I'm getting about the same readings (best is 20-23) on my Scangauge. Still waiting for the second fill up to fully calibrate it, but manual calculations are showing its very close.
  19. Jul 14, 2017 at 6:36 AM
    #619
    uwu
    uwu Well-Known Member
    I got a few 20mpg tanks in Utah last week, usually running 70mph on the hwy in 4th gear, 3200rpm, 700lbs of crap in the bed. Usually accelerated to 4500rpm or so climbing hills. Stock tire size, all 4 at 35psi
  20. Jul 14, 2017 at 7:53 PM
    #620
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
    This was my daily commute of 15miles each way, curvy, hilly roads and in town driving 30-65mph and ~75 highway miles at 75MPH. Been steadily rising since new. Tanks have been 18-22 with this being the best yet.
    441.5/18.648= 23.67 MPG
