2.7L MPG
Discussion in '4 Cylinder' started by dustinclm, Oct 12, 2010.
  1. Sep 5, 2011 at 6:13 AM
    #121
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I'm pretty sure that the scanguage II will display something like "xxx" when engine braking. I don't have one myself, but I've read a lot of reviews on them.
    And I use the same methods as you as far as coasting in neutral and engine braking.
  2. Sep 5, 2011 at 8:03 AM
    #122
    ohdrj1all
    ohdrj1all Well-Known Member
    AZ
    2003 XtraCab 4x4 SR5 2.7L 5spd
    I have noticed that excessive idling (especially with the AC on) wrecks havoc on mpg on the 2.7L... more so than on other engines I've had in other vehicles.
  3. Sep 5, 2011 at 8:08 AM
    #123
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I'm running 33x12.50x15's, and also have a really heavy speaker box with four 10 inch subs. I'm getting about 18mpg. I'm watching, or should I say listening, to my rpm's to see how good I can get it with th tank I have right now.
  4. Sep 5, 2011 at 8:20 AM
    #124
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    i hit 400 miles when the needle is on the last line.
    About 21-22. 70mph freeway and 55 expressway mostly.
  5. Sep 19, 2011 at 8:40 PM
    #125
    saltwater taco
    saltwater taco Well-Known Member
    Brandon
    Telluride, CO
    2001 3.4 5spd 4x4 TRD
    softopper, sleeping platform
    I got 26.2 Saturday!! So excited! I was on country back roads doing 55-60 for almost 4 hours with very few stops. It would've been better but I had to do 70-75 for a little while to avoid getting run over in Little Rock.
  6. Sep 20, 2011 at 9:35 AM
    #126
    zdog
    zdog Well-Known Member
    Oregon
    2010 5lug Access Cab SR5 2.7/5speed
    I just made the exodus from Oregon to Arizona for the winter. We went through Boise, Salt Lake, Las Vegas and across to Phoenix. There were two of us and the back end had about 500 lbs of stuff in it. Since I was pretty heavy I kept the speed at about 67mph. I was astounded when I did the math. I got 29mpg plus or minus 1/2 mpg. I am sure that getting away from the ethanol required by law in Oregon helped a bunch.
    Zdog
  7. Sep 20, 2011 at 9:53 AM
    #127
    sabre19
    sabre19 Member
    Phoenix, AZ
    2011 i4 Auto SR5 4x4
    GROM-USB2 w/ iPod and BT interface, OEM hitch and trailer harness, OEM tube steps, AFE Pro Dry S
    2011 Access Cab 4x4 Automatic, stock tires & wheels. I did the math at the last fill-up: 19.5 MPG combined, using 87 octane.
    Mostly in-town driving at around 25-35 MPH, occasional short hops on the highway.
    I've got less than 4k on the odometer, so maybe the numbers will improve some with time. I expect that first they'll get worse when the winter blend gas shows up.
  8. Sep 20, 2011 at 2:53 PM
    #128
    zdog
    Oregon
    Be careful about running out of fuel. It is not a good thing for the in tank fuel pump to cavitate or run dry. It will cost big bucks to fix.
    Zdog
  9. Sep 21, 2011 at 7:44 AM
    #129
    rbishopp
    rbishopp Well-Known Member
    Rich
    Webster, NY
    2009 4WD Reg cab Taco. Keepin it simple.
    So far I've added an Advance folding bed cover and since removed it. Gave it to my son in Maine, he has an 05 2wd. GT perfect fit seat covers. Weathertech floor mats and window vent visors. Waag center brush/grill guard. Hose clamp tailgate mod. Turned off the seat belt chime. Added Ultra-Gauge. Trailer hitch. Softopper. Replaced sun visors with slide out style. Toyota bed extender. Had Firestone Destinations and now Michelin LTX AT2 in stock size. More mods to come; Fog lights, locking storage in bed, intermittent wipers. Now looking for Radio/HU upgrade. and maybe a lift way down the road.
    So what do you save in gas vs. the cost of a new clutch ? Seems you'd be using the clutch alot more and causing excessive wear.
    :notsure:
  10. Sep 21, 2011 at 8:15 AM
    #130
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Cost of what new clutch?
  11. Sep 21, 2011 at 1:08 PM
    #131
    zdog
    Oregon
    I notice that you getting extraordinary mpg on your 2005. Must be that mile high altitude.
    Zdog
  12. Sep 21, 2011 at 1:52 PM
    #132
    worthywads
    Definitely helps, maybe 2 mpg, hard to say I haven't been at low altitude much to compare, and when I was it was pedal to the metal trying to make time.
  13. Sep 21, 2011 at 3:09 PM
    #133
    zdog
    Oregon
    It must be more than 2mpg. It has become almost an obsession with me to maximize my mpg and there is no way I can foresee getting to 32.5 mpg average. I would be interesting if you had a chance to get a good read on your mpg at a lower density altitude. Do you still have the stock tires on your rig or did you go to a taller tire to act as an overdrive.
    Zdog
  14. Sep 21, 2011 at 3:32 PM
    #134
    worthywads
    My best was with the stock tires, I have stock size michelin hydroedge on now and they have much worse rolling resistance, I'm more than just disappointed with them. I've posted this before but since you bring it up..... I got the tires between aug-sept 2009 and it was all down from there. A road trip to Memphis can be seen May 2009 which is down from 33 to 27-29, but again I was doing 75-80+ then, not the 55-60 I do normally at altitude.
  15. Oct 8, 2011 at 4:16 AM
    #135
    Hook & Ladder
    Hook & Ladder Well-Known Member
    Maine
    16' TRD Tacoma
    The project @c4_fabrication-Sliders, HC bumper w/ swing out @kb_voodoo_fabrications-Bed rack @tepuitents-RTT @cali_raised_led-Fogs, ditch lights, bed stiffeners @prinsudesign-Roof rack @kingshocks-2.5 with adjuster @totalchaosfabrication-UCA @rcioffroad-diff skid plate Follow at @wicked_overland #nacrew
    my tuck with 265/60/r18 stock engine im getting 23-25 up from stock tires. Better then my old car !
  16. Oct 11, 2011 at 7:05 AM
    #136
    Roberts23
    Roberts23 Active Member
    Cole
    Ga
    97 Tacoma 2.7l 4x4.
    Lower gears, Pro Comp Suspension, 33-12.50 Tires, All new audio system (Pioneer), intake system soon.
    I get about 16 i have no mods or nothing i have 9in total lift and 33 12.50 15's and thats all the aftermarket stuff i got :(
  17. Oct 12, 2011 at 6:42 PM
    #137
    wanderingwayne
    wanderingwayne Active Member
    Wayne
    Pacific Northwest
    Stock 4x4, 3.58 gears, 30" tires, man. hub
    You must have low gears and a V6. Automatic? My 95 GMC, 4WD stock everything, automatic was getting 10 MPG around town 13 freeway. New transmission and it does a little better but not much. I couldn't live with that so I bought the Toyota for the gas mileage and kept the GMC for hauling stuff. I really like the Toyota and it is the same and sometimes easier to work on. The 2.7 runs so smooth and I get 22 to 23 MPG around the back roads. Toyota's are nice trucks.
    So if your talking 16 mpg around town? Well, it could be worse.
  18. Oct 24, 2011 at 12:14 PM
    #138
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    2011 AC 4x4 with 3" lift stock tires and shell. I get 20 to 21 city. Just took a 350 mile trip from 4500' to over 7000' with a lot of up and down in between & back. Mostly hwy (70 to 75 mph) and some 40 to 65 mph dirt roads and got 23.5 mpg.
  19. Oct 24, 2011 at 2:43 PM
    #139
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    thats solid. I usually hate the highway because the MPG go way down with the 5 speed gears
  20. Oct 24, 2011 at 6:25 PM
    #140
    worthywads
    I don't find that with the 5-speed, I love the open road, just keep it below 65.
