2.7L oil capacity
Discussion in '4 Cylinder' started by 05RedTaco, Dec 21, 2010.
  1. Jun 1, 2012 at 12:21 PM
    OldDog
    OldDog Well-Known Member
    w.mass
    2010 reg cab 4X4
    The last time I had my oil change at the dealers, I gave them 6qts. mobil 1 advanced fuel Economy oil and a mobil one filter . The tec came out and told me I was .1 qts. short , so he put the remainder in . So when I got home and checked the dip stick it read over full like it always does. Just wish we had the right answer to this
  2. Jun 1, 2012 at 12:47 PM
    OldDog
    w.mass
    2010 reg cab 4X4
    OK , I just called up two Dealers and was told this.......
    When they fill the oil they set their dispenser at 6.1 qts. and that's the amount that goes into your truck.. and thats what they recommend.
  3. Jun 1, 2012 at 3:32 PM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
    I like that green.
  4. Jun 2, 2012 at 11:34 AM
    OldDog
    w.mass
    2010 reg cab 4X4
    Thanks
  5. Jun 20, 2012 at 4:03 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I put in 5.5qt every time and it's barely over the full mark... no problems, no worries. The dipstick is wrong but it's not so far off that engine damage will occur under normal driving conditions, just keep the level between the add and full marks. Most people here on TW are too meticulous to allow the level to get very far from the full mark. Likewise, allowing the oil level to go far below the low mark is asking for engine damage anyway.
  6. Mar 25, 2013 at 7:32 PM
    Dennis
    Dennis New Member
    Dennis
    Temple City, CA
    11 Access cab SR5, 4cyl
    Snug Top Camper
    At 30,000 miles change the oil and filter and added 5.5 quarts and the dipstick shows full in my 2011 Tacoma 2.7. It always showed overfull when taken to the dealer. I'm sticking with the 5.5 since .5 either way won't hurt. Why doesn't Toyoto Corp respond or issue a techical service bulletin?
  7. Mar 26, 2013 at 10:18 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I did my first change last Friday. 5 qt was about 1/8" over the low dot. 5.5 qt is right on the full dot.
    My 09 v6's dipstick wasn't the same as my 2.7. The dots were much farther apart on the v6.
  8. Apr 9, 2013 at 6:52 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Say you knew how to work on vehicles. But you did not have a manual and you bought a used Tacoma. I believe most would use the dip stick to determine when the oil level was full when doing the first oil change for example.
  9. Apr 9, 2013 at 6:54 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    That'd be 5.5 qts with filter.........
  10. Apr 10, 2013 at 6:38 AM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    i was undecided which was right.i use 5.5 with the zzd3 filter.6.1 seemed to definetly be too much.105,000 and still going strong.
  11. Apr 10, 2013 at 6:52 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  12. Apr 10, 2013 at 10:14 AM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
  13. Apr 10, 2013 at 11:15 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    If the 5 to 5.5 qts a lot of folk use was not enough, the roadsides would be littered with dead Tacoma's. 5.5 qt. gets me a bit above the full mark. Good enough for me.
  14. Apr 14, 2013 at 7:44 AM
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
  15. Apr 14, 2013 at 12:35 PM
    #35
    iroh
    michigander
    tonneau
    Anti-drainback valve in the filter keeps oil in the engine's oil passages too
  16. Apr 14, 2013 at 3:35 PM
    #36
    91r100gs
    Dan
    Kansas City area
    Still don't trust that dipstick do ya Gelo. ;) In the end a half qt. makes no difference at all unless your truck uses oil. Then you just need to keep a closer eye on it.
  17. Apr 14, 2013 at 3:38 PM
    #37
    91r100gs
    Dan
    Kansas City area
    And also the counter balancers hold a lot of oil also, that does not drain completely unless you let it drip forever.
  18. Apr 16, 2013 at 1:11 PM
    #38
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    I did my first oil change at 5,000 miles (oil from the factory a far as I know) and decided to measure how much was drained. I poured it back into an empty 5 qt jug and was right around the 5 qt mark. This, with the residual in the oil filter, came out to around 5 qts.
    See here for my findings.
    I'm starting to think that maybe not all 2nd gen 2.7 Tacomas come with the same oil sump. Perhaps Prerunners have slightly more oil capacity to compensate for greater climb angles?
  19. Apr 16, 2013 at 2:59 PM
    #39
    MikeTaco
    MikeTaco Let's do this!!
    Miami, FL
    07 Regular Cab
    A Few...
    I've put 5 quarts in my truck for the past 3 years no issues.
  20. Jul 29, 2013 at 10:52 PM
    #40
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    Maybe this issue of possible overfilling with the 6.1 quarts is why there are tsb's for all these seals going bad on tacomas. It would make sense as overfilling can blow seals. I was curious after I've started to have an oil leak from the front of my engine as to what would cause this. Checked the pcv valve it seems fine shakes around like its supposed too. So when I checked my dipstick it's still way above the two fill dots. That was following the manuals recommendations. I can't even get an accurate reading seems to be so full. So from now on I'm going just a little over 5 quarts.
