2.7L oil capacity
Discussion in '4 Cylinder' started by 05RedTaco, Dec 21, 2010.
  1. Sep 21, 2013 at 9:47 PM
    #61
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Correct, but unlike a dry sump system, overfilling can bring the oil level high enough so the crank counterweights dip into it.
    This windage whips the oil up into a froth, and air whipped into the oil is not good for lubrication and can cause the pump to cavitate.
    OTOH, going low reduces the thermal mass of the oil (our engines are oil cooled, the coolant and radiator draw the heat from the block, not the bearings). It also increases the ratio of contaminants in the oil per mile driven. If the oil is extremely low, the pickup may become uncovered during hard cornering or hill climbing, especially off road.
    But 1/2 qt + or - is not going to hurt the engine.
    Run 5, run 6... your Tacoma will do just fine with anything between the low and high marks on the dipstick.
  2. Sep 22, 2013 at 12:13 PM
    #62
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    these dipsticks do suck
  3. Sep 22, 2013 at 12:23 PM
    #63
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Last oil change I did was with one of the jugs of oil from Walmart.
    Just over 5qrts and the dipstick says oil level is full.
  4. Sep 22, 2013 at 12:36 PM
    #64
    coffeesnob
    VA
    ya, that's where I got mine ga jug full synthetic for less than 25bucks
  5. Mar 12, 2015 at 6:28 PM
    #65
    duypham389
    duypham389 Member
    Mobie,AL
    2012 Tacoma 2.7L,4 door
    I have changed the oil on my 2.7 L twice (2012 model) : First I put in 5 quarts, it seemed full, after i drove for an hour then checked the dip stick again, I added a haft more, so 5.5 quarts seems full on the dip stick.
  6. Mar 26, 2015 at 6:42 AM
    #66
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I just changed mine two days ago. It took just under 6 qts with the filter. I fill using the dipstick as the gauge. I change it then run it, let it sit for 5 or 10 minutes and then top it off.
  7. Mar 26, 2015 at 6:46 AM
    #67
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    no no no...........it takes 5.479457834586345709543986368903268754360987 qts with OEM filter at sea level and 5.6803547634089567234098564310956498762457465 qts at 10,000 ft
  8. Mar 26, 2015 at 6:30 PM
    #68
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    My son changes my oil for me. 6 QTs with filter every time. I don't bother to check the dipstick afterward, it's full.
  9. Mar 31, 2015 at 8:27 AM
    #69
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    It "seemed" full? 5.5 quarts "seems" full? LOL
    Did you check the oil level or not?
    For ease and simplicity, on the 2TR-FE we can dump in one 5-qt jug and call it done, no bothering with 1/2 quarts. This brings the level well into the area between the add and full marks, assuming a standard size filter is used. It's not necessary for the level to be exactly at the full mark. Sure it makes some people more comfortable to confirm FULL on the stick but it doesn't make a difference to the engine. As long as it's between the add and full marks, you're golden. That's why that area between the marks is called the safe zone (on some vehicles, this area says "OK" on the stick).
    Even under heavy towing or abuse conditions, another 1/2 quart of oil won't make a difference. Unless you have a leak.
  10. Mar 31, 2015 at 10:12 AM
    #70
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Better to have too much oil then not enough oil
  11. Mar 31, 2015 at 2:20 PM
    #71
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Not always.
  12. Mar 31, 2015 at 2:59 PM
    #72
    tacogringo
    tacogringo Member
    Green Mountains
    13 reg cab taco
    bilstein 5100s front and back, front at 1.75". Wheelers 1.5" single add a leaf. afe pro dry filter. secondary filter delete. Toytec swaybar relocate. tailgate secure mod
    5 quarts fills mine to the line, thats with filling the filter
  13. Apr 5, 2015 at 12:05 PM
    #73
    subaru07
    subaru07 New Member
    Gary
    Harpursville, N.Y.
    09 SR5 4wd
    K&N kit
    After checking with the dealer, I decided to go w/ the stated capacity, (6 Qts.) and not worry that the stick show it's too high.
  14. Jun 29, 2015 at 9:40 AM
    #74
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    The dipstick is off...not sure why Toyota did that though. I use Mobil 1 0W-30. I fill the new oil filter w/ nearly a full quart before re-installing it (2.7L) and then dump the rest of 6 full quarts in the engine. I've only ever used 6 quarts and at 171k miles, the engine is spotless inside and runs flawlessly. I replaced the valve cover gasket 2k miles ago and the mechanic said the engine was totally clean.
  15. Jul 20, 2015 at 7:09 AM
    #75
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    +1. Let it drain, put in 6 quarts and drive it. I never even look at the dipstick.
  16. Jul 20, 2015 at 9:41 AM
    #76
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    I did the first oil change my self, measured the amount that poured out including oil filter and it was no where near 6qts, unless Tacomas normally burn a quart of oil during break in...
  17. Jul 20, 2015 at 12:07 PM
    #77
    BDL5589
    NE Georgia
    '14 MGM 4WD RC
    Wouldn't surprise me if it did.
    Maybe the oil fill guy was having a bad day and didn't fill it to the top originally? Who knows? They DID however say 6.1 quarts is what is needed for an oil and filter change so that's what mine gets.
  18. Jul 20, 2015 at 1:03 PM
    #78
    TKyota
    TKyota Well-Known Member
    I am going by the 6.1 and the 5.4
    I cannot read the dipstick at all till the oil gets some miles on it. For me, the partial amounts are confusing me a bit, because ive never heard of impartial amounts like this before, no big deal though.
    I just changed the oil today, no filter. So had the previous quart from the 6.1 w filter and eyed it to the 5.4
  19. Aug 3, 2015 at 3:38 AM
    #79
    TRVLR500
    Wyoming
    Update on amount. My Haynes manual says 5.7 qts for my 3RZ and I just changed the oil and filter. 5.7 qts put the dipstick right on the full mark whereas 6 qts was showing a little past the full mark when I changed it the last time or two.
  20. Aug 3, 2015 at 7:16 AM
    #80
    DGXR
    Friend
    Sacramento, CA
    I bet a single 5-quart jug would put it well above the add mark.
    I mention this only because I hate dealing with partial quarts...
    0.7qt is annoying and IMHO unnecessary so long as the oil level is in the safe zone.
