2.7L oil drain plug
Discussion in '4 Cylinder' started by asdfjkl, Aug 22, 2007.
  1. Aug 22, 2007 at 5:58 AM
    asdfjkl
    asdfjkl [OP] Member
    I'm getting ready to do my first oil change on a 2007 Tacoma with the 2.7L 4 cyl. A quick question: Is there a gasket or crush washer on the oil drain plug that needs to be replaced at each oil change?
  2. Aug 22, 2007 at 7:27 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Yes there is a gasket. Get it at your local dealer, they should have a bunch behind the counter and they are only a few bucks or so.
  3. Aug 22, 2007 at 8:20 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    whoa whoa whoa, you have to replace a gasket at each oil change? I changed the oil in all my vehicles myself and have never had to replace a gasket. This doesn't make sense to me. You cant just unscrew the plug and screw it back in when your done?
  4. Aug 22, 2007 at 9:51 AM
    tacopuppy
    tacopuppy Well-Known Member
    I reuse one time just to be safe and for my own assurance. this works well for me. as stated you can get the gasket from your dealer, but don't even think about paying a few bucks for it. You should be paying no more than a dollar for those gaskets, max.
  5. Aug 8, 2008 at 12:37 PM
    Bassetdad
    Bassetdad What if God Smoked Cannabis
    Harrison, Ohio
    2001 De-Badged SR5 Access Cab 2.7 / 5m
    Access Tononu Cover AFE Pro-Dry S Drop-in Filter American Mag Wheels Bilstein 5100's Black Billet Grill Clear Taillights Perma-Tech sprayed Kennesaw Mountain Rear Bumper Michelin Tires PIAA Driving Lights PIAA Headlights Piaa Tail Light Bulbs Tinted Windows – 50% Toytech AAL URD Short Shifter Tranny - Mobil 1 Engine - Mobil 1 Custom Three Bike In Bed Rack New Toyota Undercoated Frame Clear LED 3rd Brake Light
    Since we are discussing drain plugs, which "MM" socket do I need for a 01 - 2.7?
    6 point or twelve point socket?
    Thanks in Advance..
  6. Aug 8, 2008 at 2:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Always use a 6 point socket. Cant remember the mm, sorry. :)
  7. Aug 8, 2008 at 2:30 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    12 or 14 i believe. If you cant get a gasket, just put some gasket sealant or dont worry about it. If its threaded correctly, it wont leak.
  8. Aug 8, 2008 at 4:54 PM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    fumoto it be done with it. the fumoto drain valve will make your life so much easier.
  9. Aug 8, 2008 at 5:03 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    A 14 mm socket or box end wrench
  10. Aug 8, 2008 at 5:44 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    yeah when i change my oil i dont replace a gasket. i just remove plug and replace it.
  11. Aug 13, 2008 at 5:55 AM
    Bassetdad
    Harrison, Ohio
    Thanks for the info on the socket size & how number of points it was.
  12. Aug 13, 2008 at 1:02 PM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    I reused the crush gasket on my old truck for about ten years before I replaced it.
  13. Sep 23, 2008 at 7:00 AM
    NavyNate06
    NavyNate06 yeah i fix F/A-18s
    Virginia Beach, VA
    99 Tacoma SR5
    Toytec 3 inch coilovers, OME springs/shocks, Toytec shackles, rattle can paint job, lc headers,
    theres supposed to be a gasket there? mine never even had one, i bought it used. i've never had any leakage or problems. just german torque it. i don't even think my old mazda had one.
  14. Sep 23, 2008 at 7:24 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    I got one when I did my first oil change a while back. It was $1.00 at the local stealership. I don't know if it's necessary, but all new trucks should come with one. If your truck doesn't have one, then the previous owner didn't replace it. Again... I don't know if it's necessary, but it's on the new trucks, so I keep it on mine.
    Since my last change I bought one of these. (That's a link directly to the type needed for Toyota engines.) I'll put it on next time and never have to worry about the washers or drain plug again. I put one on my wife's car a few weeks ago, too.
  15. Oct 4, 2008 at 4:33 AM
    Mace
    Mace Member
    New York
    08 SR5 Access Cab 4x4
    TRD Rims
    I work for a dealership and if not over tightend you can reuse the gaskets as long as they are the origanal ones, because the origanal ones are metal with a rubber coating. Most of the ones that are sold are just rubber and they will split after you use them 1 time. Or some dealers carry the metal ones. but if that gasket looks smooshed or cracked you need to replace it.
  16. Oct 8, 2008 at 12:47 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    not to be a party killer or anything but a buddy of mine had one of those valves on his oil pan and when offroading a stick hit it and drained oil out while he was just motoring along... luckily he stopped when oil light came on and we all had enough oil to get it back to "safe" level...but this wasnt a hardcore trail with tons of branches it was just a little path... so I think they make those valves alittle too easy to get open...also if any ass wants to at the mall they can just hit the valve and bye bye oil
  17. Oct 8, 2008 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, A friend of mine hit his on a rock! Broke the valve. Fortunatly, he had his stock plug in his tool box. We installed the plug, put in some oil, and he has never looked at those valves again.
  18. Oct 13, 2008 at 10:11 AM
    Bassetdad
    Harrison, Ohio
    I just unscrew the drain plug, drain the dirty oil & reinstall the drain plug. I never have replaceed the cork washer.
  19. Oct 31, 2008 at 4:37 PM
    Toynbyu
    Toynbyu Active Member
    Never changed the gasket for 11 years
  20. Nov 2, 2008 at 7:54 PM
    Zebra
    Millington, TN
    isn't this the purpose of having skid plates?
