2.7L oil drain plug
Discussion in '4 Cylinder' started by asdfjkl, Aug 22, 2007.
  1. Nov 2, 2008 at 9:26 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    yeah but if your so lazy you want a valve on your oil pan so you dont have to un-screw the bolt...then why would you want to unbolt a skid plate to turn the valve.. he had all the stock skids installed but they had enough room for a little stick to poke through
  2. Jan 27, 2009 at 1:57 AM
    Tacoma Dad
    Tacoma Dad New Member
    06 Regular Cab
    Here is an old trick before putting back the plug; put a dab of grease in the bottom few threads of the plug. Not too much and it'll seal. No need to buy new gaskets or sealer.
  3. Jan 27, 2009 at 11:13 AM
    96Tacoma4x4
    96Tacoma4x4 Well-Known Member
    Memphis, TN
    96 xcab 4x4 LX stock
    32x11.50 and K&N filter drop in
    I've done all my oil changes since I got my truck new and I've never replaced the washer and it's never leaked. Just don't over tighten it is what I say.
  4. Jan 27, 2009 at 11:16 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    I took mine to walmart one time and on my next oil change I discovered no gasket on the screw :eek:.
    I just figured whatever, it didn't leak without it... I might go pick one up for my next oil change...
  5. Jan 27, 2009 at 11:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Pick one up. Its there for a reason. :)
    And what the hell is the matter with you, going to Wally World for an oil change??????
  6. Jan 27, 2009 at 11:32 AM
    TacoNut
    Adam
    Denver, Co
    I didn't have time to do it myself....
    I'll add one next change,
    I've been thinking about getting the 10 pack of filters from the dealer they're like $4 each that way, i'll get them then
  7. Jan 27, 2009 at 11:34 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Didnt have time???? :frusty:
  8. Jan 27, 2009 at 11:37 AM
    TacoNut
    Adam
    Denver, Co
    Yea well at least I'm not a big dick!!!!:mad:
  9. Jan 27, 2009 at 1:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    BAH! Yes you are! :D
