2.7l PCV valve location?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ray07tacoma, Oct 9, 2013.
  1. Oct 9, 2013 at 10:22 PM
    Ray07tacoma
    Ray07tacoma [OP] Well-Known Member
    Ray
    Phoenix
    07 Tacoma access 4x4
    turbo KN Filter 3" Lift Kit Rock Sliders TRD Skid plate ProComp 285/75R16, Removed. FJ Wheels w/ 265/70R17 Delay wiper switch 168xxx miles, engine lost compression at cyl 1. Replaced with pulled engine with 63k miles (non Turbo).
    idling at about 1k and dying at stop lite.
    did MAF Cleaning, replaced plugs with Denso iridium, new KN air filter, new o2 sensor. check for vacuum leaks.
    still running rough at idle, runs great on freeway.
    only thing left is PCV valve. Could not find in truck. :confused:
    look for a couple hours in here, + still no pics of its location.
    anyone out there has any idea or picture, it is for a 07 2.7l
    thanks
  2. Oct 10, 2013 at 8:40 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The PCV Valve is called a " Ventilation Valve " in the service manual under emission controls section.
    On the 2.7 liter engine it is in the Passenger Side Rear Corner of the Valve Cover, pointed back towards the firewall.
    Markcal, TnShooter and Canufixit like this.
  3. Oct 10, 2013 at 9:40 PM
    Ray07tacoma
    Ray
    Phoenix
    yep, finally found that bugger...
    HOPE THIS HELP SOMEONE ELSE.
    I had a heck of a time finding this info...
  4. Oct 10, 2013 at 10:09 PM
    Ray07tacoma
    Ray
    Phoenix
    thanks for the reply Jimmyh...
    The darn thing was painted blue, the same color as the engine and valve cover. this truck has 130k on it, does it mean that this valve has 130k on it too? Took it out and it rattles when shaken but I will replace it anyway.
  5. Oct 10, 2013 at 10:20 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It's probably never been replaced.
    Blue? Someone has painted your engine. The valve cover and intake parts are black, engine is bare aluminum.
  6. Oct 12, 2013 at 3:31 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    You should be able to blow through the valve cover side and not through the intake side. Think check valve.
  7. Oct 13, 2013 at 9:50 AM
    Ray07tacoma
    Ray
    Phoenix
    Bought PCV Valve from local Toyota dealer $6.99
    replaced, ran much better.
    But engine hesitate when press on accelerator and revs down instead.
    been looking for vacuum leaks....
    JimmyH, "check valve" ? location? what is its function?
  8. Oct 13, 2013 at 9:44 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I was just saying the PCV Valve operates like a check valve ( it only allows flow in one direction ).
  9. Feb 7, 2018 at 9:53 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    12261, ventilation hose - Can someone find full part number for that hose?
    I tried. Thank you.
    Caboverpete likes this.
  10. Feb 8, 2018 at 6:23 AM
    Ray07tacoma
    Ray
    Phoenix
  11. Feb 8, 2018 at 10:48 AM
    egres
    DELCO PA
    Thank you. By any chance you know diameter of that hose? 1/2" ?
  12. Feb 18, 2020 at 7:05 PM
    MrsPib
    MrsPib Well-Known Member
    Angie
    Texas
    TOYOTAS, TOYOTAS EVERYWHERE
    3/8" ID
