2.7L Performance
Discussion in 'Performance and Tuning' started by Kapahi121, Apr 22, 2012.
  1. Apr 22, 2012 at 1:35 PM
    Kapahi121
    Kapahi121 [OP] Member
    reg cab Tacoma
    What's some good upgrades for my 2010 Tacoma reg cab 4x4 5 speed manual
  2. Apr 22, 2012 at 1:45 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Supercharger
  3. Apr 22, 2012 at 3:11 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  4. Apr 22, 2012 at 3:13 PM
    Doom Elk
    Doom Elk Well-Known Member
    Clinton
    Spokane, WA
    Fawk that
    Go v12
  5. Apr 22, 2012 at 3:14 PM
    Doom Elk
    Clinton
    Spokane, WA
    And in all seriousness, it depends on what you wanna do with it.
    Are you gonna make it into a mall crawler, or are you actually gonna use the truck
    Do you need the bed? Go full LT
    Etc.
    Depends on what you plan on using the truck for, and how much $$ you want to put into it. And if you cherish your gas mileage at all.
  6. Apr 22, 2012 at 8:25 PM
    Kapahi121
    reg cab Tacoma
    Well I hunt and ride dirtbike alot so ya I need the bed and I would like to get good gas mileage since here on Kaua'i our gas is like $5 for regular. But I wouldn't really need top end power probably better torque and stuff like that
  7. Apr 22, 2012 at 8:31 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    There is noting you can do. Your truck already has cold air indunction, already has as close as you can get to headers, chips are junk, you got what you got.
  8. Apr 22, 2012 at 8:33 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    The only thing I've ever gotten any gains from was my LCE Headers. Get a set and accept the fact you got a 4 banger ;)
  9. Apr 23, 2012 at 6:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    LCE header with turbo bolted onto it. :thumbsup: Everything else will fall into place.
    www.lceperformance.com Call them up.
  10. Apr 23, 2012 at 1:07 PM
    Doom Elk
    Clinton
    Spokane, WA
    Then you're looking at forced induction or a full NA build. Perhaps some bolt ons like headers, exhaust, and the like.
    Don't get a chip, you'll just waste your money. Its a 4banger truck. Its not gonna be a powerhouse. Realistically, you'll be doing the speed limit just like everyone else, just some people can get to the speed limit faster.
  11. Apr 23, 2012 at 1:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Might "just be a 4 cylinder" doesn't really mean much....Just depends on how far down the rabbit hole the OP feels like going......
    I know of one in particular that making about 1800whp. Little ole 3rz at that.
    I would rock that engine any day.
  12. Apr 23, 2012 at 1:14 PM
    Doom Elk
    Clinton
    Spokane, WA
    You can say "just be a __ cylinder" to anything really. Like you said, it depends on how deep OP's pockets are.
  13. Apr 23, 2012 at 1:17 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Indeed you are correct.
    Rods, pistons, turbo kit, and EMS. 4-5k, and I know that little engine could make some nice power.
  14. Apr 23, 2012 at 1:54 PM
    Doom Elk
    Clinton
    Spokane, WA
    Don't forget having to upgrade the injectors, as well as the engine mounts. Tranny would need to be beefed up, as well as the clutch/flywheel, etc. And once you start pushing power, your diffs are gonna start shearing, as well as your axles.
  15. Apr 23, 2012 at 2:07 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yeah. It is a never ending process. Lol.
