2.7L powersteering hose repacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Doughnut Spaghetti, May 22, 2023.
  1. May 22, 2023 at 7:07 AM
    Doughnut Spaghetti
    Doughnut Spaghetti [OP] Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    My hose is leaking so I want to swap it out with a new one. I also have a brand new powersteering pump sitting in my garage so that is going in as well.
    How difficult is it to get the old hose off the rack and the new one on? I looks like there one hard line that goes to the rack and a banjo bolt on the pump? But I don't see that I have to flare the lines or anything as it comes all set up. Trying to get everything ready for the job.
    Tired of hearing my old pump whine.
  2. May 22, 2023 at 7:29 AM
    Bishop84
    Bishop84 Well-Known Member
    Because you're in the rust belt there's a huge risk of the line rounding.
    I would suggest is make 100% sure you have the correct line, and if it starts to round: Cut the line and use a 6 point socket, this will greatly reduce the chance of rounding, even with a flare wrench or crows foot.
    fb40dash5 and BassAckwards like this.
  3. May 22, 2023 at 7:54 AM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    That right there is a very good idea... if it's going in the trash can anyway, and I can get at it to cut it off, I'm cutting it if it looks the least bit questionable.
  4. May 22, 2023 at 8:47 AM
    Doughnut Spaghetti
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    Thanks, yes I am worried about this. That's a really good idea! Probably should get under there and hit that spot with some PB blaster right now just to help.
