2.7L Rough Idle Diagnosing [SOLVED]
Discussion in 'Technical Chat' started by nzbrock, Dec 22, 2016.
  1. Apr 25, 2018 at 12:52 PM
    #41
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Mine is a 5spd, but it does shake when in neutral at a stop. I have noticed the exhaust shaking side to side quite a bit when laying under the truck with it running. This is why I'm thinking I have the same issue that you had.
  2. Aug 31, 2020 at 7:46 PM
    #42
    rickyg2008
    rickyg2008 Well-Known Member
    currently working on my fathers 2.7 5 speed. Very similar issue .. did you ever clamp the exhaust ?
  3. Sep 1, 2020 at 7:32 AM
    #43
    boostedka
    James
    NM
    I ended up selling the truck a couple weeks later before I had a chance to fix it. I have the dude the mount to install but idk how it worked out.
  4. Feb 28, 2021 at 5:58 AM
    #44
    nzbrock
    nzbrock [OP] Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Yes the exhaust bouncing around was the main cause of my vibrations, that in combination with old motor and transmission mounts.
    Cleaning the IAC, throttle body, and MAF are also good ideas, as well as looking for obvious vacuum leaks.
  5. Mar 4, 2021 at 4:33 AM
    #45
    Markcal
    Markcal Well-Known Member
    X2, I agree and appreciate TW members follow up with that "SOLVED".
