2.7L RWD - Drain and Fill or Flush?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by barch88, Dec 14, 2023.
  1. Dec 14, 2023 at 10:38 PM
    barch88
    barch88 [OP] Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    Hey everyone, new here and I’ve been looking around getting lots of mixed responses, most of the threads I’ve found have to do with the V6. I own a 2022 SR with the 2.7. It’s only got ~14k miles but was a previous fleet vehicle, so I tried to do all the maintenance (oil, filter, engine and cabin air filters, tire rotation, the usual things you’d expect not to be done by the previous owner).
    Kinda planning ahead, I was thinking about doing my differential and tranny at 30k. I was wondering if I should do a full flush or just a drain and fill? I hear things about not flushing because it may cause more problems, but usually that’s on higher mileage vehicles.
    If I start early what should I be doing? The manual says 60k, but I always like to go about half what the manual says to make my cars last longer.
    Thanks
  2. Dec 14, 2023 at 10:54 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    My opinion (and you are going to get many) - Do the diffs at 30K. Wait on the transmission and just to a couple drain and fills at 50K - 75K miles. Now, if the truck shows signs of abuse or towing, you might consider doing the transmission earlier. But, no need for a 'flush' on a new and well maintained transmission - just drain and fill.
    Chew, barch88[OP] and Wulf like this.
  3. Dec 14, 2023 at 11:02 PM
    barch88
    Michigan, USA
    Thanks for the reply. This may sound like a stupid question, but on my truck, since it’s not 4x4, do I only have the rear differential? Definitely no towing, there is no signs of the previous owner towing anything with this truck (no hitch, no ball in the bumper, no tow hookups). I don’t plan to do any towing either, very light duty stuff (thus the reason for the 2wd).
    thanks for the reply, appreciate any tips and advice to keep this baby running until the frame rots out (yes I did fluid film too).
  4. Dec 14, 2023 at 11:07 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    Yep, you only need to worry about the rear diff then. Other tips would be to change the rad fluid before 100K. I would do it at 75K or so. Just flush and refill with Toyota fluid. Don't use aftermarket fluids there or the transmission. Drive it easy, don't abuse it and you have a truck that will take you places for many years.
    barch88[QUOTED][OP] likes this.
  5. Dec 14, 2023 at 11:22 PM
    barch88
    Michigan, USA
    Thanks again.
    So rear diff at 30k, Transmission drain & fill and radiator flush 60k? Should I be doing the differential every 30k? Probably do all 3 at 60 and do the diff at 30. It’ll take me a VERY long time to hit 60k, I’ll maybe put 5k a year on this truck, but you never know where life will take ya. I foresee that being a solid 8 years out, if not more.
  6. Dec 14, 2023 at 11:25 PM
    TacoTuesday1
    SD CA
    if the miles are low and you change the coolant at 50k you do not need to use a flush product
    replacing the coolant is to prevent it sitting in there worn out being discolored rusty and dirty
    flush is for the guy who's 200k on 1 oil change, motor is knocking, and goes "well doesn't hurt to try this can from the store" that won't work
    or sometimes purchasing used with unknown service history
    barch88[OP] likes this.
  7. Dec 14, 2023 at 11:28 PM
    barch88
    Michigan, USA
    Got it, so a drain and fill/top off is the way to go?
    excuse my ignorance, but when you do a drain and fill do you replace all the fluid with fresh, just not flushing out the system?
  8. Dec 15, 2023 at 12:10 AM
    TacoTuesday1
    SD CA
    there's nothing to flush it's low miles
