2.7L to 3.4L swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RodW98, Dec 13, 2022.
  1. Dec 13, 2022 at 5:44 PM
    RodW98
    RodW98 [OP] Member
    Brody
    2010 Toyota Tacoma Base
    I have a 2010 2.7l tacoma and am trying to see if a 3.4l swap from a 3rd gen 4runner is doable. Has anyone ever successfully done one? Any tips or things that i will need for the swap? Thanks in advance
  2. Dec 13, 2022 at 9:14 PM
    Miguel_prerunner7
    Miguel_prerunner7 Well-Known Member
    Miguel
    Downey Ca
    Sold 2001 tacoma prerunner 4x4 conversation 09 taco
    Snorkel
    Following ..
    anyone done does ?
  3. Dec 14, 2022 at 6:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's going to be a process. Since they are completely different generational changes.ECU and harness to match the new equipment, at a minimum.
  4. Dec 14, 2022 at 10:12 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Wouldnt be worth your time and energy for a backwards technology swap with minimal power gains.
    Now a 1 or 2UZ ....
  5. Dec 14, 2022 at 5:18 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I really doubt you will find any write up or info on that.
    Of course it's doable, but you would be completely on your own to make up the entire process.
    You would have a much easier time swapping in a 4.0, or even a chevy v8, since those are well documented
    Did you come across a free motor or something??? Free sometimes can cost more...
    Dm93 likes this.
  6. Dec 15, 2022 at 8:00 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    The 2.7L 2TR-FE is the perhaps the better built engine....if you really need power gains I would look at the URD supercharger kit for our trucks. I think that would honestly be cheaper in the long run when you consider time is money.
  7. Dec 15, 2022 at 8:28 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    For minimal gains, and most likely a tired 3.4 V6. Easier to swap in the 4.0 or just boost the 2.7.
  8. Dec 15, 2022 at 7:30 PM
    RodW98
    RodW98 [OP] Member
    Brody
    Ive seen the supercharger kit they have its 5k and always out of stock, not sure if its a built to order product or not. Im starting to think about just putting a turbo on it and call it a day. Not trying make a race truck or make out boost just want something you dont see everyday
  9. Dec 15, 2022 at 7:33 PM
    kidthatsirish
    You drive a manual transmission right? already is something you dont see everyday.
