2.7L Valve Clearance Check
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaJim, Dec 1, 2017.
  1. Dec 1, 2017 at 6:06 AM
    ToyotaJim
    ToyotaJim [OP] Well-Known Member
    Jimmy
    1999 Tacoma SR5
    I've been reading about these engines and reading about how they are interference engines and I have quite a few miles on mine, without knowing if it has had the valve clearance checked on it anytime recent, I have been wondering how often do you guys check valve clearance and could the valves come so out of adjustment that the engine catastrophically fails?
  2. Dec 1, 2017 at 7:37 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Most owners probably never check them. Even my Toyota dealer rarely does a clearance check. I have not done mine, and I'm at 165K, but I do plan on checking.
    There was a thread recently about starting a clearance tool kit with shims that members could pass along to each other, but I've not seen an update lately. You would take the shims you need, and add your unused shims back to the kit. It should work except maybe for shims on the extreme ends of the range.
  3. Dec 1, 2017 at 7:53 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You don't need the shims just to CHECK the clearances, only to ADJUST them.
    Checking is done the traditional way, with a feeler gauge and appropriate rotations of the motor ( keeping your fingers crossed :D ).
    Adjusting is a pain, even with the special tools. After checking mine (they were off), I paid to have them adjusted ($$$ :( ).
    Luckily, my old Corolla (also with shim/bucket valve train) checked out fine, and did not need adjusting.
  4. Dec 1, 2017 at 8:00 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I don't have personal experience with this. What I've gathered is that the valves end up too tight as they wear and aren't adjusted. This excessive tightness can cause hairline stress fractures in the aluminum head. So as to catastrophic failure, prolly not. But a possible expensive failure, yes.
    cruxofthebisquit and tan4x4 like this.
  5. Dec 1, 2017 at 11:50 AM
    Glamisman
    Glamisman Well-Known Member
    cruiserguy has it right... if an exhaust valve is not just right I will make the effort to get it right, sometimes it is a battle to get the right shim given a limited selection in your supply, they guy next to you, the guy next to him, your parts department, the next Toyota dealership over. The job only pays so much and the shop foreman, service manager, service writer, customer want it YESTERDAY and for next to free. Damn, I am gonna have nightmares over all of that BS I walked away from years ago.
    cruxofthebisquit likes this.
  6. Dec 2, 2017 at 2:04 AM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    I just recently checked mine for the first time (230k miles). I had 5 valves out of spec and most of the other ones were just barely within spec. It's not a hard job its just time consuming. Some guys on here recommend checking them every 50k miles.
  7. Dec 2, 2017 at 5:44 AM
    rybern
    rybern Well-Known Member
    N Alabama
    2025 TRD OR & 2000 SR5
    I checked and adjusted mine at 290k. All of the intake clearance was within spec and only half of the exhaust valves were slightly(.002") under spec. I ended up surface grinding all of my exhaust shims to the upper end of the spec. Here's the thread: https://www.tacomaworld.com/threads/valve-lash-results-290k-miles.495565/
    Like folks have said, checking it is pretty easy and provides an excellent opportunity to replace the valve cover gasket.
    How many miles on your truck?
  8. Dec 2, 2017 at 8:53 AM
    ToyotaJim
    Jimmy
    1999 Tacoma SR5
    280k
  9. Dec 2, 2017 at 11:01 AM
    rybern
    N Alabama
    I'd say its time to check.
  10. Apr 24, 2018 at 7:01 AM
    Gsarge
    Gsarge New Member
    1995.5 Tacoma 4x4
  11. Apr 24, 2018 at 8:20 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
  12. Apr 24, 2018 at 8:22 AM
    Gsarge
    Gsarge New Member
    1995.5 Tacoma 4x4
    Russianman92[QUOTED] likes this.
  13. Apr 24, 2018 at 9:19 AM
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
  14. Apr 24, 2018 at 8:13 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I've wondered about this ever since I got my Taco. Everyone on this forum says they wear tight. I know a guy that was a Toyota mechanic at a dealer for 20+ years and he says they wear loose. The service manager at my local Toyota dealer also says they wear loose. He says that Toyota told them to not mess with the valve adjustment unless they are making noise.
    This explains my confusion on the subject. The service manager at the dealer did say that it's not impossible for a valve to get tight with miles but the chances of it are basically slim to none. Therefore, since this is my only vehicle and DD I'm going to just have to arrange a day where I can take it to the dealer and have them check everything out. Which isn't cheap. It's a very time consuming job and something I simply don't have the time to do outside since I have no access to a garage. Not that I would want to mess with it even if I had access to a garage.
    If everyone on this forum is right and the service manager and the mechanic I know are wrong then I'll just remain confused on the subject until I have the dealer get in there and measure everything. Mine has 171,800 on it now. The reason I trust this particular dealer is because they have talked me out of every single part I ever wanted to buy that I thought I could keep around in stock for the day I need one. That would be u-joints, radiator hoses, thermostat, alternator, starter, covers for the CV joints. The starter was the only thing they said will need replacement some day. Clearly, they have been right. This Tacoma has needed very little since I bought it 4 years ago with 119,000 miles on it.
  15. Apr 24, 2018 at 9:19 PM
    Gsarge
    Gsarge New Member
    1995.5 Tacoma 4x4
    They run tight.. I replaced all my values just over 100k.. I burnt them up because they got tight.. I heard the same thing and paid the price.. just trying to help you out!
  16. Apr 25, 2018 at 7:07 AM
    Texasdynaryder
    Chance
    Paris, Tx
    I only have 205k on mine and just burnt a valve on Cyl 3. I didn't realize these required the attention that the other Toyota engines don't, but lesson learned.
  17. Apr 25, 2018 at 12:42 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    My ex-local dealer told me the same info. "In 30 years I have never seen a vehicle that needed a valve adjustment". I made them check the clearance and they were tight. "This is a first for me". I ended up adjusting them myself.
  18. Apr 25, 2018 at 12:48 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
  19. Apr 25, 2018 at 9:13 PM
    mxjagracer
    mxjagracer Well-Known Member
    Asheville NC
    2000 Tacoma 4x4
    So, what were the symptoms of the tight valves?
  20. Apr 26, 2018 at 2:33 AM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    I'm not sure what the symptoms are but I know my truck ran a lot better after I adjusted them. If they're too tight for too long you could get "burnt valves".
