2.7l valve job
Discussion in '4 Cylinder' started by todntes, Jun 20, 2010.
  1. Jun 20, 2010 at 9:37 AM
    todntes
    todntes [OP] Member
    Todd
    Seattle
    00 Tacoma SR5
    I took my 2000 Tacoma Extended cab 4wd with a 2.7l engine to a local shop due to loss of power, bad gas mileage and check engine light. They determined there was low compression in the #2 cylinder due to a stuck valve. They estimated $2000 for a valve job and machining of the head. Does this sound accurate? I found a brand new short block online for $2000 with free delivery. Are they trying to take me or am i missing something? Any info would be helpful.
  2. Jun 20, 2010 at 9:56 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    That price is WAY too high. Also you could remove the head and take it to a machine shop to get the work done, that would save you some money.
  3. Jun 20, 2010 at 10:00 AM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    x2 they are screwing you.
  4. Jun 20, 2010 at 10:03 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    $2000!? cmon you really need to ask if you are getting screwed here.
  5. Jun 20, 2010 at 2:34 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    Times are tough everywhere, the bottom feeders try to find suckers behind every rock.
    I'd push a couple cans of Sea Foam through it before doing anything.
  6. Jun 21, 2010 at 5:32 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    for $3000 LCE will sell you a ported head and brand its new
  7. Jun 28, 2010 at 8:25 PM
    todntes
    todntes [OP] Member
    Todd
    Seattle
    00 Tacoma SR5
    I am tearing down the engine in the driveway now but still deciding weather I should order a rebuilt head for $375 or take mine to a machine shop and have it re-one. Does anyone know an estimate of what they charge for valves / machining?
  8. Jun 30, 2010 at 10:10 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    It cost be $130 for a total breakdown of my head, bead blast and valve seals. For a 3 angle valve job, new seals and maybe a couple valves should only run 400..
  9. Jun 30, 2010 at 2:58 PM
    Barnone
    Barnone Guest
    I would test the compression myself or get a second opinion before I tore into it. You can get a inexpensive compression tester at Harbor Freight.
  10. Jul 2, 2010 at 7:01 AM
    2000yota
    2000yota Toyota FTW
    Garrett
    Hernando, MS
    2006 TRD Sport
    heckkkk naww i got a guy down here in MS that can get me a whole new motor and install it to for 1500
