2.7l with 33's need to re-gear???
Discussion in '4 Cylinder' started by Mickle, Dec 28, 2010.
  1. Dec 28, 2010 at 8:24 PM
    Mickle
    Mickle [OP] Active Member
    Alex
    San Diego
    99 Tacoma 2.7L
    Dirt Logic 3" coilover lift, All Pro 3" rear lift, K&N intake, Doug Thorley Headers, Flowmaster, ARB bumper, HID's
    I've got a 99 2.7 4x4 5 speed and put a 3" lift and 33x10.5x15 BFG's. Absolutely love the setup but it's an absolute slug on the highway after 3d gear. I've put on Thorley headers, K&N intake and flowmaster muffler to try to get some more power. Although these add-ons help it does nothing for higher speed highway driving. Do I need to re-gear? Has anyone re-geared a setup like this? Thanks for your input.
  2. Dec 28, 2010 at 8:36 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    got any pics ?
  3. Dec 28, 2010 at 8:56 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    Re gear would be recommended
  4. Dec 28, 2010 at 9:04 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    +1
    I have 08 2.7L regular cab with 5speed manual, lift & 31's, 5th is useless, I use it onle as overdrive cruise control gear, any hill or to accelerate on highway, I have to drop it to 3rd to get any speed.
    I would recommend 4.10 gears.
    Jaffa_man and Marcos187 like this.
  5. Dec 28, 2010 at 10:03 PM
    Mickle
    Alex
    San Diego
    99 Tacoma 2.7L
    I figured that would be the answer;expesnive answer. Either gears or get a 6 cyl.
  6. Dec 28, 2010 at 10:29 PM
    907taco
    Bobby
    Alaska
    curious as to how much it would cost to re-gear this also.
  7. Dec 29, 2010 at 12:06 PM
    Mickle
    Alex
    San Diego
    99 Tacoma 2.7L
    [/ATTACH]
    I'll get some prices and post my findings.
  8. Dec 29, 2010 at 12:23 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    According to the original post, he has a 4x4 so he should have a 4.10 rear end anyway. A lot of it depends on the tires. Certain tires are heavier than others. I have the 2.7 with a 5 speed and recently upgraded to the 265/75r16's which is equal to a 31.6" tire. Because it's a 4 cylinder I went with the Hankook Dynapro ATM's in a P metric size. They were only 6 lbs per tire heavier than the stock Dunlops that were equal to a 29" tire. On my old '99 I had the 31" BFG A/T's. They were a lot heavier than these tires but luckily I had the V6. Depending on your offroading requirements (some just use them for street queens), I would consider getting a lighter tire than regearing. Regearing is going to further affect your mpgs.
  9. Dec 29, 2010 at 12:32 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    If your gears are too tall for the job the truck is asked to do, the engine will be running inefficiently and regearing will actually improve MPGs. This was the case for my Ford F150 with the 5.0 and the 3.31 gears.
    However, regearing is expensive (200-400 parts, and 300-500 in labor PER AXLE) and you'd NEVER do it just for mpgs - you'd never make enough back in gas to justify.
    The only reason to regear is because you feel it's subjectively worth it to improve how the truck drives.
    31 to 33 doesn't change the gear ratio all that much. The other factor is the increased rotating mass of the larger wheels and (especially) tires. Lower gearing helps with both of these.
    All that being said, I haven't regeared my 2011 2.7 to account for my 285/70R17s. I can still start the truck from a dead stop by easing out the clutch without any input on the gas, and even though mid range acceleration on the hwy is more sluggish, the mega-bucks required to make the change just isn't worth it to me. If I wanted V6 power, I should have bought the TRD OR with the V6 to begin with.
  10. Dec 29, 2010 at 1:19 PM
    05RedTaco
    Tony
    Scottsdale
    I totally overlooked that he has 4x4 to begin with. If he already has 4.10 gears stock, there is no need to re-gear.
  11. Dec 29, 2010 at 1:25 PM
    RED ICE
    RED ICE Member
    Joe
    Staples Center
    '11 Regularcab 4x4 AT
    Baja pinstripes
    Hey bjmoose I appreciated your OME write-up and pictures. I just bought a '11 regular cab 4x4 Automatic. I wheeled it hard at Gorman OHV yesterday and am thinking I want lower gearing. I am thinking 4.88's with true-tracs running 235/85. I would like 255's but you scared me away from a tall OME set up andd 255 is a tall 33 that will not make my gearing seem any lower. Think I'll go 235's with 5100's set at 1.75' vs. a coilover setup. Your thoughts please on the tires and gearing and also about whether or not I will get a real significant 4-low trail advantage with coilovers vs 1.75" 5100's. My truck is mostly a daily driver, I probably will wheel it only 3 or 4 times a year but I take on some decent trails when I do. Also have you wheeled Gorman and is it the same as Hollister.
  12. Dec 29, 2010 at 1:30 PM
    RED ICE
    RED ICE Member
    Joe
    Staples Center
    Baja pinstripes
    1.75' is a lot of inches
