2.85 urd pully is a stand alone end needed ?
Discussion in 'Performance and Tuning' started by Honda400ex66, Mar 2, 2014.
  1. Mar 2, 2014 at 8:00 AM
    Honda400ex66
    Honda400ex66 [OP] Member
    Nova Scotia
    07 tacoma 6" pro comp ,king coils supercharge
    Iv had the pulley for a while now and have not installed it ,dose anyone know the cheapest effective way too tune the 4.0 v6 tacoma for a trd supercharger with 2.85 urd pulley ?i plan on buying a stand alone unit some time in the future but not enuff room in the pocket yet
  2. Mar 2, 2014 at 7:56 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    In most cases, the trd reflash is more than sufficient at handling the 2.85 pulley:cool:
  3. Mar 2, 2014 at 8:11 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The stock tune is rich as a pig. I recommend an AFR gauge to keep an eye on things, but the stock reflash should be more than okay handling the 2.8 pulley.
  4. Mar 2, 2014 at 8:32 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
  5. Mar 2, 2014 at 8:32 PM
    memario1214
    Colton
    Missoula, MT
  6. Mar 2, 2014 at 8:37 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    No need. Just install it and go. I have been running it for 4 years and 50K miles on the standard TRD tune. I have an AFE CAI, Y pipe & cat back exhaust as well. No issues.
  7. Mar 4, 2014 at 5:55 AM
    Honda400ex66
    Nova Scotia
    Thanks a lot that's what I wanted too hear , I'll slap it on and give I a couple pulls on the dyno , just too make sure
  8. Apr 1, 2014 at 3:35 PM
    wheelN4life
    wheelN4life Member
    shane
    New Hampshire
    TRD OFF ROAD
    last week I traded my 2010 off road for a 2014. I went crazy adding a TRD SC a pro-comp lift, tinted the windows and a new sound system. I dropped it off today to have the SC put on. I wanted to know if I put the URD 2.85 pulley on if it would hurt anything.
    what kind of gains did you get with the URD pulley?
  9. Apr 1, 2014 at 8:03 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    2.8 pulley gains of 1-2 psi so roughly 15-20 hp.
  10. Apr 2, 2014 at 7:29 AM
    wheelN4life
    wheelN4life Member
    shane
    New Hampshire
    TRD OFF ROAD
    so is it really worth putting one on? Will the power come on earlier in the RPM range.
  11. Apr 2, 2014 at 7:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You'll definitely have more power per same rpm.
    You should seriously consider a fuel pump upgrade.
  12. Apr 2, 2014 at 1:49 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    From what I hear if you remove the 3.0" pulley, and install the 2.85" , you will Void the factory warranty...URD makes the "Stealth 2.85"pulley that has the OEM pulley numbers stamped into the pulley itself, Toyota is hip to this as well, if you notice on your S/C snout(At least it was on mine), there is a drop of yellow painted weld looking stuff on the snout,and pulley..if you change out pulleys.. try and mimic this with a drop of solder, painted yellow ...dealership will look for this should you have an engine claim.
    EDIT: Make sure you use Torque seal after pulley swap..(mine was yellow)..[​IMG]
    http://urdusa.com/p1260519103/URD-%22Stealth%22-Supercharger-Pulley,-4.0L-TRD-Supercharger-2.85%22/product_info.html
    ^^what Tor said...alot of Guys have had success with the Walbro 255 which you can also get from URD for about $155...last thing you want to do is starve the Blower during Boost... Air/Fuel Ratio Gauge is a Bonus tool as well...
    http://urdusa.com/p1260518592/URD-2005+-Tacoma-V6,-Fuel-Pump/Filter-Upgrade-Kit/product_info.html
  13. Apr 2, 2014 at 4:19 PM
    wheelN4life
    wheelN4life Member
    shane
    New Hampshire
    TRD OFF ROAD
    What kind of intake should I use?
    THANKS to all for your help!
  14. Apr 3, 2014 at 6:14 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
  15. Apr 3, 2014 at 7:43 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    That looks great
  16. Apr 3, 2014 at 8:07 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    that is torque paint. it is used to identify if the hardware has been loosened(by intentional or non intentional means). pretty standard in most industries
  17. Apr 3, 2014 at 8:16 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
    Easily replicated if needed.
  18. Apr 24, 2014 at 7:08 PM
    Mtniner
    Mtniner Well-Known Member
    NW Montana
    Is this what the dealerships use:
    http://dirttricks.com/shop/torque-seal-yellow-marking-paint
    Or does the drop of solder and yellow paint work good enough?
  19. Apr 24, 2014 at 9:45 PM
    AWF ROWD
    Doc
    '13 BLOWN 4X4 Sport
  20. Apr 25, 2014 at 11:17 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I need to get some.
