2" aal bad vibrations HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by countryboy22, Nov 26, 2009.
  1. Nov 26, 2009 at 9:11 PM
    countryboy22
    countryboy22 [OP] Well-Known Member
    Arizona Mountains
    05 SR5 4x4
    TRD cold air intake, Bilstein 5100's @ 2.5, Toytec 1.5" aal w/rear bilsteins. MBRP tip, Flowmaster Delta Flow 50 series, Toytec axle shims and carrier bearing drop.
    I recently installed a 2" aal from toytec and once i did i got bad driveline vibes especially around 30-40 mph. i then ordered shims and carrier bearing drop after putting these on i still have the vibes. i dont know what else to do i am 99 percent sure they are coming from the driveline.
    Any advice or input would help.
  2. Nov 26, 2009 at 9:22 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    1 piece driveshaft or try some alcan or devar leaf packs instead maybe? i think one piece driveshaft would be your best bet. iv been considering it
    oh and i think the price for those 1 piece are close to what like 300 bucks ???
  3. Nov 26, 2009 at 9:29 PM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    ya i just curious if anyone else is having the problem with 2"aal and if so what they did to fix it
  4. Nov 26, 2009 at 9:45 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Do a carrier bearing drop, that might help. I installed it and my vibes that were from 0-5 mph went away. I had ALWAYS had them, from the second I drove it off of the lot brand new. So I was used to it.
    Also look at buying the differential drop from wheelers offroad or toytech. That will help with the vibes.
  5. Nov 26, 2009 at 10:01 PM
    08pretaco
    az
    Ooh just thought of something, if possible lift the front morey, that might decrease the driveshaft angle therefore iliminating some vibs...
  6. Nov 26, 2009 at 10:40 PM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    what degree shims?
    for mine I used 2 degree shims.
    the carrier drop plus the shims made it worse. so take out the carrier drop
  7. Nov 27, 2009 at 6:13 PM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    i have the shims from toytec i not sure what degree they are. I have tried many things i have tried putting shims in with carrier bearing didnt fix it. i tried puttin just carrier bearing with no shims that didnt work. so i tried putting shims with carrier bearing and adding a couple washers to gap it more that didnt work. i now have it with the shims in and no carrier bearing drop and thats still not working. i honestly dont know what to do i am about ready to buy a 1.5 inch aal and swap it out.
  8. Nov 27, 2009 at 6:54 PM
    drjohnson36
    drjohnson36 Well-Known Member
    09 Pre-Runner SR5 DC
    Lifting the front more will increase the driveline angle.
  9. Nov 27, 2009 at 6:58 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    double check to see if everything is tight?
    the shims are in fat side to the rear, correct?
    I dunno what else? diff drop since you are 4x4?
  10. Nov 27, 2009 at 7:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That vib sounds like the TSB for the tranny mount.
  11. Nov 29, 2009 at 10:13 AM
    countryboy22
    Arizona Mountains
    05 SR5 4x4
    ok chris what does that mean exactly cuz its driving me nuts. i need it fixed
  12. Nov 29, 2009 at 10:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    PM answered. There was a TSB on the tranny mount. Some trucks had vibes related to it.
  13. Nov 30, 2009 at 8:27 AM
    fauskar
    fauskar Active Member
    Rick
    Wisconsin
    SR5
    Hitch
    If it wasn't there before the AAL and is now, assembly is most likely the cause. I just finished adding the 2" AAL and have noticed no problems. I do see several assembly steps that could lead to problems: 1) Centering pin is loose when the U-bolts are torqued down. Likely caused by not getting the leafs pulled together tightly during pin assembly. 2) Centring pin not falling into axle hole. 3) U-bolts tightened unevenly. The amount of thread showing on front/rear/side should be about the same.
  14. Nov 30, 2009 at 8:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    True.
  15. Nov 30, 2009 at 8:41 AM
    08pretaco
    az
    Why would lifting the front cause more of an angle? If you have say nothing up front and a 2"aal in the back your driveshaft looks like this (tranny) - then (this is where the spacer would go) \ (then 3rd member) (haha I know its bad) but say you lift the front some more it would make that rear \ level out more to something flat therefor possibly eliminating some vibs. After all the spacer toytec sells drops it to make the driveshaft more linear, as lifting the front would also.
    I could be wrong though, if I am someone tell me :)
  16. Nov 30, 2009 at 8:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Lifting the front wont help the DS angle.
  17. Nov 30, 2009 at 9:07 AM
    08pretaco
    az
    oh btw chris wanna meet somewhere this morning? let me know time and place and ill be there, i live right across from teds
    then a question: why do ds spacers help?
  18. Nov 30, 2009 at 9:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are for the carrier bearing. Some have vibrations due to pinion angle, and sometimes dropping the carrier bearing will help, sometimes not.
  19. Nov 30, 2009 at 9:24 AM
    08pretaco
    az
    oh duh that doesnt do anything to the ds angle :eek:
  20. Jun 23, 2013 at 2:18 PM
    StreetTaco4Me
    StreetTaco4Me Taco Shot
    Bryan
    Ventura County, So. Cal.
    2001 4runner SR5
    looking to replace shocks and add spacer lift...I do not off road at all just like the height of a lift
