2* axle shims....
Discussion in 'Suspension' started by ETaco23, Dec 22, 2011.
  1. Dec 22, 2011 at 8:34 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Im trying to find some 2* degree shims, bc I have a take off shudder that im trying to cure...
    Ive tryed everything! even 3* degree shims, but no luck..
    Ive even tryed BT 1-1/2" CB Drop bracket! didnt help...
    Im ganna trry to take out the CB drop from toytec out and just use a 2* shim to see if that helps....
    where's a good place buy from?
    Thanks!
  2. Dec 22, 2011 at 8:39 PM
    Sunner
    Sunner Well-Known Member
    EEEsssshhh, Hope I dont have to go through all that when I lift, subbed to find out as well
  3. Dec 22, 2011 at 8:50 PM
    ETaco23
    Evan
    PNW
    My vibe isnt too bad.. I only feal it sometimes, I just want to get rid of it..
    anyone?
  4. Dec 22, 2011 at 9:03 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Beuller?
  5. Dec 22, 2011 at 9:25 PM
    ETaco23
    Evan
    PNW
  6. Dec 22, 2011 at 9:27 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  7. Dec 23, 2011 at 5:52 PM
    ETaco23
    Evan
    PNW
    cool! I may have to check it out! thanks!
  8. Dec 23, 2011 at 6:26 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    OP , are you going to sell the Beefed drop ?
  9. Dec 23, 2011 at 7:40 PM
    Sprink669
    Sprink669 Well-Known Member
    summit racing has every * you need
  10. Dec 23, 2011 at 10:34 PM
    ETaco23
    Evan
    PNW
    thaught about it.... you want it?
  11. Dec 23, 2011 at 10:35 PM
    ETaco23
    Evan
    PNW
    Awsome! thanks
  12. Dec 23, 2011 at 10:40 PM
    ETaco23
    Evan
    PNW
    how wide do the shims need to be again? 2"?
    Thanks!
  13. Dec 24, 2011 at 9:53 AM
    ETaco23
    Evan
    PNW
    haha! I was waiting for that reply...
    Im too lazy...:)
  14. Dec 24, 2011 at 10:01 AM
    Sprink669
    i got mine from summit, the only thing i had to do was drill out the hole a little bigger. i picked them up for like 9 bucks
  15. Dec 24, 2011 at 10:18 AM
    ETaco23
    Evan
    PNW
    Which ones did you get? Im looking at getting the Rough Country ones, that come with new center pins...
  16. Dec 24, 2011 at 10:30 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    If you are close to Portland, OAS will custom cut steel shims. Quoted me $15 each.
    http://www.spring-man.com/
    Which way are you facing the shims ?
  17. Dec 24, 2011 at 4:35 PM
    ETaco23
    Evan
    PNW
    the right way... flap down, fat end to the rear.
    I ganna try the ones from summitracing, thanks again!
  18. Feb 20, 2012 at 10:27 AM
    AZtacoma05
    AZtacoma05 Well-Known Member
    Austin, TX
    17 DCSB TRD Off Road
    Did you get your problem fixed? what width did you end up going with for the plates? Just tried to measure mine and looked like 2 1/4".
  19. Feb 20, 2012 at 12:23 PM
    ETaco23
    Evan
    PNW
    I tryed the shims but it made it worse. The thing that got rid of most of my take off vibes was taking out the shims and just lowering the carrier bearing until the drive shaft is almost straight. Or until both shafts are within 1 degree of each other.
