2 Bank Battery Tender Users?
Discussion in 'Boating & Fishing' started by danbow, Sep 30, 2020.
  1. Sep 30, 2020 at 3:11 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    I just bought a boat this summer and am starting to think about Winter storage.
    This boat has a dual battery setup and I was looking into getting a battery tender so I'm not buying batteries in the spring.
    Storage is semi-enclosed with electrical.
    What brand would you recommend?
    Also, I'm considering just leaving the batteries in the boat with the batteries switched off, but on a tender. Temps around here get below freezing, but not really much below that.
    Any advice is appreciated.
    Thanks!
  2. Dec 21, 2020 at 8:45 AM
    mattys010
    mattys010 Well-Known Member
    2010 DCLB TRD Sport
    Battery tender brand. I use it all year long, unless the boat is being used often
    danbow[OP] likes this.
  3. Dec 27, 2020 at 9:45 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If you leave them on a tender you'll be fine with keeping them installed. My ATVs used to sit all winter with temps down to -50° in unheated storage with a cheap trickle charger on them. The same charger kept my snowmachine batteries good all summer. Never lost a battery.
  4. Dec 28, 2020 at 4:47 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Thanks! I’ve had the boat winterized and just got 2 separate chargers since the only dual locally was much more than the 2 singles.
  5. Dec 28, 2020 at 4:52 PM
    aggr0crag
    aggr0crag Well-Known Member
    19 DCSB 4x4 Sport M/T
    I’ve been using a NOCO Genius charger/tender. It’s worked great. They have many variations found on Amazon.
  6. Dec 28, 2020 at 5:07 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    that’s actually the brand I ended up picking up!
    aggr0crag[QUOTED] likes this.
