2 brands, same weight for differential ok?
Discussion in 'Technical Chat' started by schleygo, May 17, 2011.
  1. May 17, 2011 at 11:08 AM
    schleygo
    schleygo [OP] Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    Just did my rear differential. I bought 2 quarts of Valvoline dino 80w-90 thinking I had 1 quart at home.
    Get home, it is Oreilly's auto parts brand 80w-90 gear lube. Was mad at myself.
    Both brands are dino 80w-90, will this be ok?
  2. May 17, 2011 at 11:10 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just me but I wouldn't mix them. Different companies use different additives. No telling how they'll react. Most likely you'd never know the difference and there would be no adverse affects but I would chance it over the cost of a quart of oil.
    Edit: I should add I'm probably a little more obsessive about maintenance than I need to be...
  3. May 17, 2011 at 11:18 AM
    schleygo
    Daniel
    Ft Worth TX
    sorry, it was valvoline. 5.99 a quart, non synthetic
