2 Different load ranges on truck...
Discussion in 'Wheels & Tires' started by MyToyTaco, Sep 19, 2020.
  1. Sep 19, 2020 at 5:28 PM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I got some BFG ko2's about 7500 miles ago. I just NOW noticed that the right side has Load range E's and the left side has load range C's.
    Is this bad? Would it affect handling on the highway?
  2. Sep 19, 2020 at 5:31 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    That’s not good!
    Kolter45 likes this.
  3. Sep 19, 2020 at 5:32 PM
    Sharpish
    Brian
    I would match them In pairs front and back. But better to have 4 tires matching!
    Shellshock and Silverlogic like this.
  4. Sep 19, 2020 at 8:43 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    This.
  5. Sep 19, 2020 at 8:44 PM
    Bishop84
    Bishop84 Well-Known Member
    It's not great, but its not dangerous, just pair them to the front and rear and you'll be fine.
    su.b.rat likes this.
  6. Sep 20, 2020 at 7:38 AM
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    Take them back and get the correct tires.
    Mickeydog, AntMan408 and Thatbassguy like this.
  7. Sep 20, 2020 at 7:42 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    I wouldn't accept that. Were they installed new at a tire dealer?
  8. Sep 20, 2020 at 7:45 AM
    AntMan408
    AntMan408 Well-Known Member
    Bay Area, CA
    2021 Toyota 4Runner off-road, 2022 Tacoma Offroad
    4runner: King Shocks Front/Rear SPC UCA’s SPC rear control arms Icon Rear Springs 52700 Icon Panhard Bar SCS 10’s RCI Skids and Sliders CBI Baja Bumper w/Diode dynamic lightbar RCI Roof Rack Tacoma: King Shocks Front/Rear Camburg UCA’s Deaver Expedition Stage 1 Leaf Pack SCS Gen 5 RCI Skids RCI Sliders BAMF Hybrid Bumper RCI Roof Rack
    Return to point of purchase and have them correct the issue. It’s not a huge deal however it will affect how you rotate tires and affect wear and tear. I wouldn’t imagine the shop would cause too much of a stink about fixing their mistake. However if you ordered online and didn’t check when they arrived then that’s your bad as much as their bad. But should be resolved. Your money, should get what you paid for.
    Thatbassguy likes this.
  9. Sep 20, 2020 at 7:49 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Get them changed, pretty sure the tires won't weigh the same(e rated will be heavier). If you had them mounted at a dealer he should have caught that.
  10. Sep 20, 2020 at 7:57 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Point of sale needs to resolve so check your receipt and yes they are dangerous as they flex at much different rates and will cause the suspension to react differently so in an emergency situation your handling will basically be a mess. Whatever store allowed that to happen now needs to exchange all 4 tires for a set with similar wear as your 4x4 will also wear from mismatched sizes (if they only want to do 2 you could but a good store will replace all 4). If a chain remember to mention the power of posting your satisfaction online and that you will call the national number and report this. If a small local dealer they will want a good word of mouth so you should get resolution.
  11. Sep 20, 2020 at 7:58 AM
    su.b.rat
    su.b.rat broken truck
    weird. agree to put the Es out back and Cs up front for normal steering response especially in emergency maneuvers. probably not a huge deal to run it like that for some time to assess if anything feels off.
  12. Sep 20, 2020 at 8:01 AM
    Thatbassguy
    James
    The problem with this is that it won't be possible to rotate them properly. They will wear uneven and premature, and probably get noisy (more than normal).
  13. Sep 20, 2020 at 9:21 AM
    MyToyTaco
    MyToyTaco [OP] ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    They were purchased and installed at a local, big brand shop. I asked if this would affect handling because the truck has been wandering quite a bit on the highway. I actually just had the truck aligned a couple weeks ago (which, the alignment was a bit off).
    I'll go to the tire shop tomorrow to see what they say about it.
  14. Sep 20, 2020 at 9:24 AM
    su.b.rat
    obviously but the point here is to just use up what you got and replace with a new set after chewing these down. and rotations are often overrated.
  15. Sep 20, 2020 at 9:31 AM
    Thatbassguy
    James
    Or, take it back to the shop that installed them and exchange them for a matching set.
    I completely disagree about rotation being overrated. I started rotating my tires regularly with my 2015 Tacoma. I put tires on it around 55-60K miles, and traded in at 102K. The used car manager commented about how good the tires looked.
    I also put 29K on a set of KO2's and only went through 20% of the tread. They also looked like new (even wear).
  16. Sep 20, 2020 at 9:34 AM
    su.b.rat
    ok. but it's tire and driving related and results vary. good it works well for you. i generalized and that wasn't a helpful statement across the board.
    Thatbassguy[QUOTED] likes this.
  17. Sep 20, 2020 at 9:37 AM
    Thatbassguy
    James
    True!
    There are probably exceptions here, but I think with AT's and 4wd religious rotation is well worth the effort.
    If you make it part of your oil change routine, it's not much work.
    su.b.rat[QUOTED] likes this.
  18. Sep 20, 2020 at 9:51 AM
    Sharpish
    Brian
    You can still rotate front to back and side to side, you just have to do it in pairs.
  19. Sep 20, 2020 at 9:57 AM
    Thatbassguy
    James
    Hmm.. Good point. This would actually work with how I rotate mine. I rotate differently than normal though, because I'm convinced that reversing direction is the most important thing.
  20. Sep 20, 2020 at 3:36 PM
    Pete_Patter
    Pete_Patter Well-Known Member
    2018 Calvary Blue Tacoma TRD Pro
    Rotating tires is critical to getting the most out of them. If you don’t rotate your rear tires will wear faster, you will get heal toe tread wear which will increase tire noise, and you will end up replacing the set earlier than you need to.
