2 electrode spark plug gauge
Discussion in '1st Gen. Tacomas (1995-2004)' started by kortiz, Jan 12, 2012.
  1. Jan 12, 2012 at 8:53 PM
    kortiz
    kortiz [OP] New Member
    el paso texas
    2001 tacoma pre runner
    I bought the replacement spark plugs for my 2001 tacoma pre runner. These spark plugs have 2 electrodes and I was wondering how to calibrate them. I read that the gauge has to measure .043 but I want to know how to measure it. Is it vertically in this case since I have 2 electrodes?
    When you have one electrode you measure the gauge horizontally because the electrode sits on top, but in this case the electrodes are kind of in the side so I am wondering/
  2. Jan 12, 2012 at 8:58 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Put them in the way they are.
    Don't really need to worry about plug gap to much with a double (or more) electrode spark plug.
  3. Jan 13, 2012 at 6:10 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Hey check the gap its not always correct ^^^^ thats bullshit!
  4. Jan 13, 2012 at 6:15 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    i think if you use the same general concept as a single ground electrode you will be fine. thats how i did it. actually, yes, measure the same way, it will be fine. but definitely measure because it wont always be correct from the box
  5. Jan 13, 2012 at 7:13 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    I run Bosch Platinum +2 in my wifes car (3rd set) and my understanding is they are set right (or at least close to it) from the factory and should not be gapped. I'm not really sure how you would do it anyway. the "electrode" is fully covered with ceramic and the grounds don't have anything square to reference off off.
    The spark travels differently on that style of plug. It follows down the insulator more before jumping the gap.
  6. Jan 13, 2012 at 7:19 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    This, they are set at the manufacturer & the spark is thrown across the electrode (horizontally) as opposed to standard single electrode plugs (vertical)
  7. Jan 13, 2012 at 7:22 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    & I'm pretty sure this type of plug was chosen because of the 3.4-4.0
    hemispherical "Hemi" combustion chamber heads
  8. Jan 13, 2012 at 7:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Always check the gaps.
  9. Jan 13, 2012 at 7:24 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 1GR uses single electrode plugs, as do many other "hemi" engines. IIRC, the 3.4 uses a "wasted spark" ignition, and the double ground plugs are better in those motors.
  10. Jan 13, 2012 at 7:29 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Engine specific I guess, just like some have had problems when replacing the Denso with Bosch, I'm running Bosch now with no issues, but then again, i'm not running anything 'cause my trans shit itself, hmmmm, may re think the whole Bosch thing if its smoking transmissions:p
  11. Jan 13, 2012 at 8:24 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    :rofl:
    Bosch did NOT run well in my wife's Toyota several years ago. That, along with the fact that Chris said to run OEM plugs, led me to just go with Denso.
    (Like many here, I always do what Chris says... :bowdown:)
  12. Jan 13, 2012 at 8:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!! Im not always right, Ive just found the OEM Denso plugs to run the best. :eek:
  13. Jan 13, 2012 at 9:04 PM
    Norton
    Sacrilege! :eek:
  14. Jan 14, 2012 at 5:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    its happened :(
