2 front D-Ring Shackles??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mainewoodsballer, Apr 9, 2015.
  1. Oct 18, 2019 at 9:14 PM
    #41
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Bump, any bolt on options yet?
  2. Jan 11, 2023 at 11:47 AM
    #42
    Redpro87
    Redpro87 Member
  3. Jan 11, 2023 at 12:07 PM
    #43
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    Nipple Rings!!!!!
  4. Jan 11, 2023 at 11:34 PM
    #44
    TacoTuesday1
    SD CA
    20somethingwidataco likes this.
  5. Jan 13, 2023 at 2:18 AM
    #45
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Quite a few of the items posted / discussed / linked earlier in this thread can get somebody badly injured or killed if they fail in an actual off-road recovery scenario. The $65 non-rated Amazon specials can tear right out of the frame if used in more intensive/difficult recoveries. The flying D-rings & remains of the mounting plates will shatter or punch holes in anything in their way as they shoot off at high speed. People occasionally die this way:
    https://www.youtube.com/watch?v=Mb3BkeeXlIo
    The home-built weld-up stuff might do better than expected but I wouldn't trust it unless I had extensively load-tested it under controlled conditions, well in advance of actually needing it in a way-off-road / outback recovery situation.
    There's no problem if you want to have cheap shackles for looks, mayyyyybe possibly for "light duty" easy more or less straight-line recoveries of stock Tacos with empty beds (not loaded w/ cargo etc) on more or less level, flat terrain. So long as people understand the limitations of what they're buying/installing.
    ARB makes a properly-engineered and load-rated Taco recovery point (8 tons.) It's very expensive, probably overpriced, but it's what the market will bear for a piece of metal that will let you pull an overweight 6400 lb overland-rig Taco out of a steep off-angle-stuck situation with relatively low chance of damage to vehicle, or injury to bystanders.
    https://www.amazon.com/ARB-2823010-Recovery-Point-Right/dp/B074S6PK14
    I bought one -- it weighs 27 pounds, without the mounting hardware. There's a reason for all that weight, it's the quantity of steel required to get the job safely and properly done.
  6. Jan 13, 2023 at 6:37 PM
    #46
    TacoTuesday1
    SD CA
    but it’s cheaper to hot glue a coffee cup handle to the bumper cover and paint it red
