2" front leveling kit/ tire size question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KrnTaco, Apr 4, 2012.
  1. Apr 4, 2012 at 5:55 PM
    KrnTaco
    KrnTaco [OP] Member
    Nevada
    08Taco4x4TRD
    Stock!
    First things first, I did search but could not find anything so I apologize if this has been covered before.
    The question, I'm getting a 2" front leveling kit from tuff country for my 2008 Tacoma dbl cab 4x4. What's the biggest tire I can go with? I'm planning on putting 285/75/16 with stock rims and BFG all terrains or Toyo open country all terrains. Would that be ok without doing any modifications as in shaving the fenders etc..
    My current tires are TOYO open country all terrain 265/70/16.
    I apologize if this has been covered please give me a break, I'm a noob when it comes to lifts and tires. Thank you.
  2. Apr 4, 2012 at 6:23 PM
    KrnTaco
    KrnTaco [OP] Member
    Nevada
    08Taco4x4TRD
    Stock!
    Anybody?
  3. Apr 4, 2012 at 7:00 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
  4. Apr 4, 2012 at 7:05 PM
    KrnTaco
    KrnTaco [OP] Member
    Nevada
    08Taco4x4TRD
    Stock!
    Ok thanks
  5. Apr 4, 2012 at 7:49 PM
    TacoTimmy
    TacoTimmy Active Member
    Hohenwald, TN
    07 PreRunner SR5
    Believe you will need wheel spacers for the front to run a tire that wide...
  6. Apr 4, 2012 at 7:49 PM
    TacoTimmy
    Hohenwald, TN
    07 PreRunner SR5
    ...on a stock wheel
  7. Apr 4, 2012 at 7:50 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    265/75r16 is the largest tires you can fit with no rubbing issues whatsoever.
    might need spacers on the stockies though, as mentioned before.
  8. Apr 4, 2012 at 8:36 PM
    KrnTaco
    KrnTaco [OP] Member
    Nevada
    08Taco4x4TRD
    Stock!
    Oh really? Like I said I'm new to all this so where can I get some wheel spacers? I went to les schwab and they didn't say anything about wheel spacers. Actually, they told me about running 285/70/16 on a 2" front leveling kit
  9. Apr 4, 2012 at 8:39 PM
    KrnTaco
    KrnTaco [OP] Member
    Nevada
    08Taco4x4TRD
    Stock!
    So, it sounds like its not the 2" leveling kit is the problem, is the stock rim on a 285/70 size tire?
  10. Apr 4, 2012 at 9:15 PM
    Jay9722
    Jay9722 Well-Known Member
    Jay
    South carolina
    2011 Tacoma Access Cab 4wd
    This gives a lot of info:
    http://www.customtacos.com/tech/index.php?article=137#tires
    I have 265/70-16 Goodyear Wrangler Duratracs on stock TRD Beadlock Style wheels and I'm going with a 3inch leveling kit. It looks good with no lift and I have zero rub issues but I think the lift will make It look a lot meaner. I wouldn't have gone any bigger with tires and I have been told by many to avoid spacers if you can. Go with a different wheel and offset if you want a wider stance and bigger tire...I'm no expert, just relaying what some experts have told me.
  11. Apr 4, 2012 at 9:29 PM
    Jay9722
    Jay
    South carolina
    Sorry I meant to say 265/75-16
  12. Apr 4, 2012 at 9:35 PM
    KrnTaco
    KrnTaco [OP] Member
    Nevada
    08Taco4x4TRD
    Stock!
    Ok cool. I keep reading on this forum about the duratracs. They must be good tires. Another noob question, what are the specs on a stock 08 tacoma TRD sport rim?
    Thanks for your info.
