2" front lift
Discussion in 'Suspension' started by HawkCE, Sep 4, 2015.
  1. Sep 4, 2015 at 9:22 AM
    HawkCE
    HawkCE [OP] Member
    WI
    2015 SR
    I've read so many conflicting ideas, I don't quite know where to go with this question. I simply want to level the front end of my 2015 Tacoma. Is this not possible without doing something to the rear as well? I see many different types of "leveling spacers" but don't know if this is enough level the overall stance or not. I do ZERO of roading...if that helps.
    Ideas?
  2. Sep 4, 2015 at 9:41 AM
    HawkCE
    HawkCE [OP] Member
    WI
    2015 SR
    I'll reveal my inexperience by asking what are 5100's?
  3. Sep 4, 2015 at 9:59 AM
    HawkCE
    HawkCE [OP] Member
    WI
    2015 SR
    Just a set in the front? Or the back as well?
  4. Sep 4, 2015 at 10:08 AM
    HawkCE
    HawkCE [OP] Member
    WI
    2015 SR
    Makes more sense now, thanks for replying...and not in a condecending way like a number of posts I've read on here!:thumbsup:
  5. Sep 4, 2015 at 10:11 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Also get the 1/4" spacer to eliminate the tacoma lean. You can get it at Wheelers along with the 5100's.
  6. Sep 4, 2015 at 11:04 AM
    HawkCE
    HawkCE [OP] Member
    WI
    2015 SR
    Where does said spacer install at?
  7. Sep 4, 2015 at 11:05 AM
    HawkCE
    HawkCE [OP] Member
    WI
    2015 SR
    Duh, never mind, I see the link you attached!
  8. Sep 13, 2015 at 12:54 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    You won't need the aforementioned spacer if you use the stock coils. They are side specific and already compensate for the heavier driver side of the truck. People use the spacers when they install aftermarket coils.
  9. Sep 15, 2015 at 12:09 PM
    HawkCE
    HawkCE [OP] Member
    WI
    2015 SR
    Sounds good. Thanks for the insight.
