2 Gen 2013 transmission issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nmedvedev0202, Jul 11, 2020.
  1. Jul 11, 2020 at 3:00 PM
    nmedvedev0202
    nmedvedev0202 [OP] Member
    nikita
    Washington State
    White 2013 Tacoma TRD Sport
    Hey guys. Wondering if anyone has had this issue and whats been done to fix it. My 2013 tacoma TRD sport with 115K recently stared having transmission issues. Check engine light came on showing solenoid pressure control and solenoid shift. Also shifts hard into drive, 2nd 3rd and 4th gears, and i mean very hard. Trying to avoid expensive repairs, might need a rebuilt or swap but hopefully not.
  2. Jul 11, 2020 at 3:34 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    How is the fluid level?
    Do you have any leaks?
    You may need to physically crawl under and take a look
    What were the code #
  3. Jul 11, 2020 at 3:47 PM
    nmedvedev0202
    nikita
    Washington State
    No leaks. Had the fluid flushed 2 years ago by a shop.
    Codes were
    P2714 pressure control solenoid D
    P0771 shift solenoid E
    P0746 shift control solenoid A
  4. Jul 11, 2020 at 4:14 PM
    TnShooter
    Deogee
    STOCK
    With multiple codes it could be electrical, solenoid, or pump issues.
    @gearcruncher
    gearcruncher likes this.
  5. Jul 11, 2020 at 4:45 PM
    nmedvedev0202
    nikita
    Washington State
    But since it’s shifting hard is it possible that there’s internal damage? Debris in the transmission, shavings from gears, damaged torque coveter.
  6. Jul 11, 2020 at 4:54 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’d pop a new TCC solenoid into that Bitch
  7. Jul 11, 2020 at 5:05 PM
    nmedvedev0202
    nikita
    Washington State
    Will the transmission fluid completely drain out in order to replace the TCC solenoid?
  8. Jul 11, 2020 at 5:08 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I think you have to take the pan off, so yes. Edit: The first time I changed one I was so scared you couldn’t have hammered a finishing nail into my ass but I did it and you can, too!
  9. Jul 13, 2020 at 6:28 AM
    gearcruncher
    Canadain bumper technician
    Always begin your diagnosis by fixing the codes in the order they appear .
    Unusual for multiple codes all at once like this and I am wondering if there is an issue with the wiring harness from the transmission going up to the computer in your truck .
    Your truck is in limp mode and its going to shift hard until the codes are cleared . Limp mode is a built in safety program used to prevent further damage to the transmission .
    What would I do If your truck was in my shop ?
    Clear all the trouble codes after recording them ofcourse , then with the key on but engine not running , perform a re-scan . Do all the codes come back up after you cycle the ignition key ? If they do , I would do a wiring harness wiggle test .
    During an ingition cycle , the computer in your truck sends a message to all the solenoids and sensors in the transmission and expects a quick reply . If the computer doesnt get a reply , you get codes .
    I suspect a loss of connection somewhere in your wiring harness .When this happens , the most likely cause is a dirty connection where the wiring harness case connector bolts to the transmission . Very very common.
